Linux/AM5728: Thermal issue, board not booting
Part Number: AM5728
Other Parts Discussed in Thread: BEAGLEBOARD-X15, PMP, DRA752, TMP102, TMDSEVM572X
Tool/software: Linux
Hi ,
AM5728 development board is not booting. The logs shows the thermal issue . I am attaching the logs.
U-Boot 2018.01-00444-g17164f4-dirty (Apr 18 2019 - 17:26:05 +0530)
CPU : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: AM572x EVM REV A.3A
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
1490 bytes read in 2 ms (727.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
1 bytes read in 1 ms (1000 Bytes/s)
Already setup.
4010496 bytes read in 294 ms (13 MiB/s)
147729 bytes read in 66 ms (2.1 MiB/s)
Loading Device Tree to 8ffd8000, end 8ffff110 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.67-gd315a9bb00 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Sat Oct 6 02:39:21 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5728 EVM
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 15 pages/cpu @eed29000 s31308 r8192 d21940 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=82dda4a0-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1675556K/1897472K available (8192K kernel code, 346K rwdata, 2616K rodata, 2048K init, 299K bss, 33500K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1056ba8 ( 347 kB)
[ 0.000000] .bss : 0xc1058000 - 0xc10a2c3c ( 300 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000357] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000365] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000872] Console: colour dummy device 80x30
[ 0.000889] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000896] This ensures that you still see kernel messages. Please
[ 0.000903] update your kernel commandline.
[ 0.000925] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000940] pid_max: default: 32768 minimum: 301
[ 0.001064] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001077] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001595] CPU: Testing write buffer coherency: ok
[ 0.001817] /cpus/cpu@0 missing clock-frequency property
[ 0.001836] /cpus/cpu@1 missing clock-frequency property
[ 0.001849] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039848] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059858] Hierarchical SRCU implementation.
[ 0.080046] EFI services will not be available.
[ 0.099916] smp: Bringing up secondary CPUs ...
[ 0.170234] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.170326] smp: Brought up 1 node, 2 CPUs
[ 0.170340] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.170348] CPU: All CPU(s) started in HYP mode.
[ 0.170354] CPU: Virtualization extensions available.
[ 0.170874] devtmpfs: initialized
[ 0.190861] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.191110] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.191302] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.191318] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.195009] pinctrl core: initialized pinctrl subsystem
[ 0.195448] DMI not present or invalid.
[ 0.195697] NET: Registered protocol family 16
[ 0.196740] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.197669] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.306672] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.405487] cpuidle: using governor ladder
[ 0.405520] cpuidle: using governor menu
[ 0.414102] OMAP GPIO hardware version 0.1
[ 0.442533] No ATAGs?
[ 0.442606] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.442619] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.443002] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.443014] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.443535] OMAP DMA hardware revision 0.0
[ 0.453014] edma 43300000.edma: memcpy is disabled
[ 0.456105] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.462675] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.463976] evm_5v0: supplied by main_12v0
[ 0.464393] com_3v6: supplied by evm_5v0
[ 0.467292] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.467499] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.467733] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.467965] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.468328] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.468532] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.468772] iommu: Adding device 58820000.ipu to group 1
[ 0.468851] iommu: Adding device 55020000.ipu to group 2
[ 0.468993] iommu: Adding device 40800000.dsp to group 0
[ 0.469237] iommu: Adding device 41000000.dsp to group 3
[ 0.471505] palmas 0-0058: Irq flag is 0x00000008
[ 0.502068] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.503577] SMPS12: supplied by regulator-dummy
[ 0.505242] SMPS3: supplied by regulator-dummy
[ 0.506886] SMPS45: supplied by regulator-dummy
[ 0.508680] SMPS6: supplied by regulator-dummy
[ 0.510098] SMPS7: supplied by regulator-dummy
[ 0.511524] SMPS8: supplied by regulator-dummy
[ 0.512775] SMPS9: supplied by regulator-dummy
[ 0.513489] LDO1: supplied by regulator-dummy
[ 0.521293] LDO2: supplied by regulator-dummy
[ 0.531142] LDO3: supplied by regulator-dummy
[ 0.531200] random: fast init done
[ 0.541180] LDO4: supplied by regulator-dummy
[ 0.551177] LDO5: supplied by regulator-dummy
[ 0.551894] LDO6: supplied by regulator-dummy
[ 0.552598] LDO7: supplied by regulator-dummy
[ 0.553302] LDO8: supplied by regulator-dummy
[ 0.554029] LDO9: supplied by regulator-dummy
[ 0.561220] LDOLN: supplied by regulator-dummy
[ 0.571226] LDOUSB: supplied by regulator-dummy
[ 0.583817] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.584358] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.584868] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.585050] media: Linux media interface: v0.10
[ 0.585085] Linux video capture interface: v2.00
[ 0.585165] pps_core: LinuxPPS API ver. 1 registered
[ 0.585174] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.585196] PTP clock support registered
[ 0.585223] EDAC MC: Ver: 3.0.0
[ 0.590682] dmi: Firmware registration failed.
[ 0.591073] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.591349] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.591688] Advanced Linux Sound Architecture Driver Initialized.
[ 0.600755] clocksource: Switched to clocksource arch_sys_counter
[ 0.608398] NET: Registered protocol family 2
[ 0.608912] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.608975] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.609101] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.609169] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.609201] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.609324] NET: Registered protocol family 1
[ 0.609608] RPC: Registered named UNIX socket transport module.
[ 0.609617] RPC: Registered udp transport module.
[ 0.609625] RPC: Registered tcp transport module.
[ 0.609632] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.610555] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.610795] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.611800] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.615770] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.616262] NFS: Registering the id_resolver key type
[ 0.616294] Key type id_resolver registered
[ 0.616303] Key type id_legacy registered
[ 0.616341] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.617642] bounce: pool size: 64 pages
[ 0.617685] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.617695] io scheduler noop registered
[ 0.617704] io scheduler deadline registered
[ 0.617847] io scheduler cfq registered (default)
[ 0.617857] io scheduler mq-deadline registered
[ 0.617865] io scheduler kyber registered
[ 0.623212] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.626895] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.3
[ 0.627255] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.627290] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.627312] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.627586] dra7-pcie 51000000.pcie: phy link never came up
[ 1.627712] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.627725] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.627735] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.627745] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.628051] PCI: bus0: Fast back to back transfers disabled
[ 1.628141] PCI: bus1: Fast back to back transfers enabled
[ 1.628178] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.628197] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.628503] pcieport 0000:00:00.0: Signaling PME with IRQ 174
[ 1.628626] pcieport 0000:00:00.0: AER enabled with IRQ 174
[ 1.629475] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.632090] vdd_3v3: supplied by regen1
[ 1.632358] aic_dvdd_fixed: supplied by vdd_3v3
[ 1.632430] vtt_fixed: supplied by smps3
[ 1.673115] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.675621] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
[ 2.772309] console [ttyS2] enabled
[ 2.776544] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 46, base_baud = 3000000) is a 8250
[ 2.787221] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.794330] DSS: OMAP DSS rev 6.1
[ 2.799302] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.807735] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.818067] panel-dpi display: display supply vcc not found, using dummy regulator
[ 2.836031] brd: module loaded
[ 2.844473] loop: module loaded
[ 2.850583] libphy: Fixed MDIO Bus: probed
[ 2.910783] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.918480] libphy: 48485000.mdio: probed
[ 2.927420] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 2.937164] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[ 2.947436] cpsw 48484000.ethernet: Detected MACID = 7c:38:66:7c:e7:34
[ 2.954070] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.960456] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.965756] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 2.972804] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.980658] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:38:66:7c:e7:35
[ 2.988879] i2c /dev entries driver
[ 2.993316] IR NEC protocol handler initialized
[ 2.997866] IR RC5(x/sz) protocol handler initialized
[ 3.002965] IR RC6 protocol handler initialized
[ 3.007516] IR JVC protocol handler initialized
[ 3.012085] IR Sony protocol handler initialized
[ 3.016721] IR SANYO protocol handler initialized
[ 3.021751] IR Sharp protocol handler initialized
[ 3.026477] IR MCE Keyboard/mouse protocol handler initialized
[ 3.032351] IR XMP protocol handler initialized
[ 3.039191] gpio-fan gpio_fan: GPIO fan initialized
[ 3.045259] tmp102 0-0048: initialized
[ 3.050428] thermal thermal_zone3: critical temperature reached (118 C), shutting down
[ 3.058533] reboot: Failed to start orderly shutdown: forcing the issue
[ 3.066980] sdhci: Secure Digital Host Controller Interface driver
[ 3.073255] sdhci: Copyright(c) Pierre Ossman
[ 3.075440] Emergency Sync complete
[ 3.082054] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.088724] reboot: Power down
[ 3.089229] sdhci-omap 4809c000.mmc: Got CD GPIO
