Other Parts Discussed in Thread: PMP, DRA722, TMP102
Tool/software: Linux
We are working on AM5718 processor using ti-processor-sdk-linux-am57xx-evm-05.02.00.10. we are able to enter into the root by using bootable SD card, but the kernal modules are not loaded properly and the following statements have occurred in the log mentioned below.
U-Boot SPL 2018.01-00558-gca1e85ecb5-dirty (Apr 23 2019 - 09:28:24)
DRA722-GP ES2.0
DRA722-GP ES2.0
Trying to boot from MMC1
no pinctrl state for default mode
U-Boot 2018.01-00558-gca1e85ecb5-dirty (Apr 23 2019 - 09:28:24 +0530)
CPU : DRA722-GP ES2.0
Model: TI AM5718 IDK
Board: AM571x IDRAM: 1 GiB
MMC: prop_name: pinctrl-0 mode: default index: 0
OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
board revision is null
Entered into partition size
Got the mmc device
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: Could not get PHY for ethernet@48484000: addr 0
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
1490 bytes read in 3 ms (484.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
1 bytes read in 2 ms (0 Bytes/s)
Already setup.
3912192 bytes read in 228 ms (16.4 MiB/s)
93375 bytes read in 37 ms (2.4 MiB/s)
Loading Device Tree to 8ffe6000, end 8ffffcbe ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-gbde58ab01e (toradex@medha) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 PREEMPT Wed Apr 10 9
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5718 IDK
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] Hit pending asynchronous external abort (FSR=0x00000211) during first unmask, this is most likely caused by a firmware/bootloa.
[ 0.000000] CPU: All CPU(s) started in HYP mode.
[ 0.000000] CPU: Virtualization extensions available.
[ 0.000000] DRA722 ES2.0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 210496
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=1df8a9d4-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 800580K/848896K available (8192K kernel code, 355K rwdata, 2524K rodata, 2048K init, 272K bss, 23740K reserved, 24576K)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1058e90 ( 356 kB)
[ 0.000000] .bss : 0xc105a000 - 0xc109e10c ( 273 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000015] Switching to timer-based delay loop, resolution 162ns
[ 0.000337] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000344] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000741] Console: colour dummy device 80x30
[ 0.000755] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000760] This ensures that you still see kernel messages. Please
[ 0.000765] update your kernel commandline.
[ 0.000781] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000793] pid_max: default: 32768 minimum: 301
[ 0.000887] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000899] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001313] CPU: Testing write buffer coherency: ok
[ 0.001342] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001653] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.001728] Hierarchical SRCU implementation.
[ 0.001943] EFI services will not be available.
[ 0.002206] devtmpfs: initialized
[ 0.015654] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[ 0.015849] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.015999] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.016012] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.016549] pinctrl core: initialized pinctrl subsystem
[ 0.016892] DMI not present or invalid.
[ 0.017072] NET: Registered protocol family 16
[ 0.017783] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.018329] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.080512] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.178966] cpuidle: using governor ladder
[ 0.178989] cpuidle: using governor menu
[ 0.185477] OMAP GPIO hardware version 0.1
[ 0.186963] omap_gpio 48059000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio4_pins_default, deferring pe
[ 0.187256] omap_gpio 4805b000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio5_pins_default, deferring pe
[ 0.205536] No ATAGs?
[ 0.205549] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.205560] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.205896] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.205904] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.206268] OMAP DMA hardware revision 0.0
[ 0.213715] edma 43300000.edma: memcpy is disabled
[ 0.216229] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.221616] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.222236] evm_5v0: supplied by evm_12v0
[ 0.222449] evm_3v6: supplied by evm_5v0
[ 0.222653] vsys_3v3: supplied by evm_12v0
[ 0.222865] evm_3v3: supplied by vsys_3v3
[ 0.223071] evm_3v3_sd: supplied by evm_3v3
[ 0.223942] V3_3D: supplied by VMAIN
[ 0.224280] vtt_fixed: supplied by V3_3D
[ 0.226199] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.226353] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.226526] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.226708] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.229025] palmas 0-0058: IRQ missing: skipping irq request
[ 0.250356] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[ 0.251597] SMPS1: supplied by evm_3v3_sd
[ 0.253139] SMPS2: supplied by evm_3v3_sd
[ 0.254661] SMPS3: supplied by evm_3v3_sd
[ 0.256174] SMPS4: supplied by evm_3v3_sd
[ 0.257641] SMPS5: supplied by evm_3v3_sd
[ 0.258761] SMPS12: supplied by evm_3v3_sd
[ 0.259676] LDO1: supplied by evm_3v3_sd
[ 0.260150] ldo1: Bringing 3000000uV into 3300000-3300000uV
[ 0.270445] random: fast init done
[ 0.270926] LDO2: supplied by evm_3v3_sd
[ 0.272002] LDO3: supplied by evm_3v3_sd
[ 0.280675] LDO4: supplied by evm_3v3_sd
[ 0.290698] LDO5: supplied by evm_3v3_sd
[ 0.301193] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.301344] media: Linux media interface: v0.10
[ 0.301375] Linux video capture interface: v2.00
[ 0.301438] pps_core: LinuxPPS API ver. 1 registered
[ 0.301445] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.301460] PTP clock support registered
[ 0.301482] EDAC MC: Ver: 3.0.0
[ 0.301687] dmi: Firmware registration failed.
[ 0.302020] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.302181] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.302439] Advanced Linux Sound Architecture Driver Initialized.
[ 0.302981] clocksource: Switched to clocksource arch_sys_counter
[ 0.308561] missing cooling_device property
[ 0.308572] failed to build thermal zone board_thermal: -2
[ 0.308679] NET: Registered protocol family 2
[ 0.309070] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.309130] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.309231] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.309289] UDP hash table entries: 512 (order: 1, 8192 bytes)
[ 0.309313] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[ 0.309411] NET: Registered protocol family 1
[ 0.309605] RPC: Registered named UNIX socket transport module.
[ 0.309612] RPC: Registered udp transport module.
[ 0.309618] RPC: Registered tcp transport module.
[ 0.309624] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.310365] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.310426] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.311140] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.314295] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.314737] NFS: Registering the id_resolver key type
[ 0.314755] Key type id_resolver registered
[ 0.314762] Key type id_legacy registered
[ 0.314792] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.315911] bounce: pool size: 64 pages
[ 0.315951] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.315959] io scheduler noop registered
[ 0.315965] io scheduler deadline registered
[ 0.316096] io scheduler cfq registered (default)
[ 0.316104] io scheduler mq-deadline registered
[ 0.316110] io scheduler kyber registered
[ 0.319562] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.319671] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.319731] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 0.319740] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.322203] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.323852] vdd_3v3: supplied by ldo1
[ 0.324088] aic_dvdd_fixed: supplied by vdd_3v3
[ 0.355966] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.357941] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
[ 1.267385] console [ttyS0] enabled
[ 1.271476] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 44, base_baud = 3000000) is a 8250
[ 1.280795] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 45, base_baud = 3000000) is a 8250
[ 1.290096] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 46, base_baud = 3000000) is a 8250
[ 1.300374] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 1.307316] DSS: OMAP DSS rev 6.1
[ 1.311577] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.328205] brd: module loaded
[ 1.335079] loop: module loaded
[ 1.340227] libphy: Fixed MDIO Bus: probed
[ 1.403002] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.410693] davinci_mdio 48485000.mdio: no live phy, scanning all
[ 1.418144] davinci_mdio: probe of 48485000.mdio failed with error -5
[ 1.425055] cpsw 48484000.ethernet: No slave[1] phy_id, phy-handle, or fixed-link property
[ 1.433386] cpsw 48484000.ethernet: Detected MACID = 98:5d:ad:99:8a:8e
[ 1.439992] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 1.446386] cpsw 48484000.ethernet: ALE Table size 1024
[ 1.451640] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 1.458672] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 1.466742] i2c /dev entries driver
[ 1.470749] IR NEC protocol handler initialized
[ 1.475318] IR RC5(x/sz) protocol handler initialized
[ 1.480389] IR RC6 protocol handler initialized
[ 1.484943] IR JVC protocol handler initialized
[ 1.489488] IR Sony protocol handler initialized
[ 1.494129] IR SANYO protocol handler initialized
[ 1.498848] IR Sharp protocol handler initialized
[ 1.503575] IR MCE Keyboard/mouse protocol handler initialized
[ 1.509428] IR XMP protocol handler initialized
[ 1.515530] tmp102 0-0049: initialized
[ 1.521396] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[ 1.528948] sdhci: Secure Digital Host Controller Interface driver
[ 1.535163] sdhci: Copyright(c) Pierre Ossman
[ 1.539910] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.546237] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 1.551051] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
[ 1.560072] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[ 1.566574] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[ 1.572955] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[ 1.579359] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[ 1.585764] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[ 1.592144] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[ 1.598271] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[ 1.604397] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 1.663111] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 1.670918] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[ 1.677686] sdhci-omap 480b4000.mmc: no pinctrl state for hs mode
[ 1.684925] sdhci-omap 480b4000.mmc: no pinctrl state for hs mode
[ 1.693072] sdhci-omap 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[ 1.740027] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.748149] mmc0: new SDHC card at address 1234
[ 1.752885] mmcblk0: mmc0:1234 SA16G 14.5 GiB
[ 1.757369] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 1.757796] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.768046] NET: Registered protocol family 10
[ 1.768608] Segment Routing with IPv6
[ 1.768655] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.769008] NET: Registered protocol family 17
[ 1.769146] Key type dns_resolver registered
[ 1.769255] omap_voltage_late_init: Voltage driver support not added
[ 1.769258] Power Management for TI OMAP4+ devices.
[ 1.769438] Registering SWP/SWPB emulation handler
[ 1.822324] dmm 4e000000.dmm: workaround for errata i878 in use
[ 1.828435] mmcblk0: p1 p2
[ 1.836533] dmm 4e000000.dmm: initialized all PAT entries
[ 1.843042] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.849772] [drm] No driver support for vblank timestamp query.
[ 1.859377] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 1.867654] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.876738] hctosys: unable to open rtc device (rtc0)
[ 1.882410] ldo2: disabling
[ 1.885664] ldo4: disabling
[ 1.888726] ALSA device list:
[ 1.891704] No soundcards found.
[ 1.913546] mmc1: new MMC card at address 0001
[ 1.918226] mmcblk1: mmc1:0001 P1XXXX 3.60 GiB
[ 1.922872] mmcblk1boot0: mmc1:0001 P1XXXX partition 1 16.0 MiB
[ 1.929303] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.937565] mmcblk1boot1: mmc1:0001 P1XXXX partition 2 16.0 MiB
[ 1.937652] mmcblk1rpmb: mmc1:0001 P1XXXX partition 3 128 KiB
[ 1.943957] mmcblk1: p1 p2
[ 1.945185] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.962584] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.972408] devtmpfs: mounted
[ 1.976557] Freeing unused kernel memory: 2048K
[ 2.571553] systemd[1]: System time before build time, advancing clock.
[ 2.653367] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GC)
[ 2.674528] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[ 2.714241] systemd[1]: Set hostname to <am57xx-evm>.
[ 3.222850] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.235902] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 3.263094] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.269864] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.379377] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.386218] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.423183] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.453262] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.494385] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.523209] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
Mounting Kernel Debug File System...
[ OK ] Created slice system-getty.slice.
Mounting POSIX Message Queue File System...
[ OK ] Reached target Slices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
[ OK ] Listening on Journal Socket.
Starting Load Kernel Modules...
[ 3.932096] cmemk: disagrees about version of symbol module_layout
Starting Journal Service...
[ 3.951336] cryptodev: disagrees about version of symbol module_layout
Starting Remount Root and Kernel File Systems...
[ 3.974353] gdbserverproxy: disagrees about version of symbol module_layout
Starting Create list of required st��…ce nodes for the current kernel...
[ 4.028622] usb_common: disagrees about version of symbol module_layout
[ 4.049686] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Reached target Paths.
[ 4.066830] usb_common: disagrees about version of symbol module_layout
[ 4.088061] uio: disagrees about version of symbol module_layout
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
Starting Rebuild Hardware Database...
Starting Create System Users...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Create System Users.
[ 4.588384] systemd-journald[70]: Received request to flush runtime journal from PID 1
Starting Create Static Device Nodes in /dev...
[ 4.616343] sch_fq_codel: disagrees about version of symbol module_layout
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Journal Catalog...
Starting Create Volatile Files and Directories...
Starting Rebuild Dynamic Linker Cache...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Rebuild Hardware Database.
Starting udev Coldplug all Devices...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Network Service...
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activati[ 12.629467] crypto_engine: disagrees about version of symbol module_layout
on Socket.
[ OK ] Listening on dropbear.socket.
[ 12.729942] crypto_engine: disagrees about version of symbol module_layout
[ 12.788687] can_dev: disagrees about version of symbol module_layout
[ 12.800395] snd_soc_tlv320aic3x: disagrees about version of symbol module_layout
[ 12.811709] snd_soc_tlv320aic3x: disagrees about version of symbol module_layout
[ 12.820021] can_dev: disagrees about version of symbol module_layout
[ 13.065727] rtc_omap: disagrees about version of symbol module_layout
[ 13.071364] dwc3_omap: disagrees about version of symbol module_layout
[ 13.102773] rtc_omap: disagrees about version of symbol module_layout
[ 13.115249] dwc3_omap: disagrees about version of symbol module_layout
[ 13.129795] dwc3_omap: disagrees about version of symbol module_layout
[ 13.148121] ti_vpdma: disagrees about version of symbol module_layout
[ 13.167661] dwc3_omap: disagrees about version of symbol module_layout
[ 13.201081] ti_vpdma: disagrees about version of symbol module_layout
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting RPC Bind Service...
[ 13.618588] phy_omap_usb2: disagrees about version of symbol module_layout
[ OK ] Started Job spooling tools.
[ 13.628433] phy_omap_usb2: disagrees about version of symbol module_layout
[ 13.628533] phy_omap_usb2: disagrees about version of symbol module_layout
[ 13.657670] phy_omap_usb2: disagrees about version of symbol module_layout
[ 13.704655] phy_omap_usb2: disagrees about version of symbol module_layout
[ 14.003868] omap_wdt: disagrees about version of symbol module_layout
[ 14.013377] can_dev: disagrees about version of symbol module_layout
[ 14.019946] omap_sham: disagrees about version of symbol module_layout
[ 14.037701] omap_wdt: disagrees about version of symbol module_layout
[ 14.050989] omap_sham: disagrees about version of symbol module_layout
[ 14.057258] can_dev: disagrees about version of symbol module_layout
[ 14.137360] crypto_engine: disagrees about version of symbol module_layout
[ 14.139860] crypto_engine: disagrees about version of symbol module_layout
[ 14.157591] crypto_engine: disagrees about version of symbol module_layout
[ 14.186825] crypto_engine: disagrees about version of symbol module_layout
[ 14.338196] extcon_usb_gpio: disagrees about version of symbol module_layout
[ 14.369810] extcon_usb_gpio: disagrees about version of symbol module_layout
[ 14.380316] extcon_usb_gpio: disagrees about version of symbol module_layout
[ 14.406682] extcon_usb_gpio: disagrees about version of symbol module_layout
[ 14.645867] EXT4-fs (mmcblk1p2): recovery complete
[ 14.645879] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
Starting TI IPC Daemon...
[ 14.806097] phy_omap_usb2: disagrees about version of symbol module_layout
[ OK ] Reached target Containers.
[ 14.840681] phy_omap_usb2: disagrees about version of symbol module_layout
[ 14.896868] phy_omap_usb2: disagrees about version of symbol module_layout
[ 15.991506] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
[ OK ] Started System Logging Service.
Starting Login Service...
[ 16.071504] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
Starting Avahi mDNS/DNS-SD Stack...
Starting uim-sysfs.service...
[ 16.170853] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
[ 16.390733] random: crng init done
[ 16.394264] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 16.599585] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Print notice about GPLv3 packages...
[ OK ] Started Daily Cleanup of Temporary Directorie[ 16.966713] net eth0: initializing cpsw version 1.15 (0)
s.
[ OK ] Reached target Timers.
[ 17.083773] libphy: PHY 48485000.mdio:09 not found
[ 17.088593] net eth0: phy "48485000.mdio:09" not found on slave 0, err -19
[ OK ] Started Kernel Logging Service.
Starting TI MultiCore Tools Daemon...
[ 17.253040] libphy: PHY not found
[ 17.256465] net eth0: phy "" not found on slave 1, err -19
[ OK ] Started Network Service.
[ 17.438794] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started RPC Bind Service.
[ OK ] Started TI IPC Daemon.
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[ OK ] Found device /dev/ttyS0.
[ OK ] Found device /dev/ttyS2.
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Simple Network Management Protocol (SNMP) Daemon....
Starting Permit User Sessions...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started Redis In-Memory Data Store.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started uim-sysfs.service.
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
Starting rc.pvr.service...
[ 20.971956] pvrsrvkm: disagrees about version of symbol module_layout
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
binutils-dev
binutils
bison-dev
bison
cifs-utils
cpio
cpp-symlinks
cpp
dosfstools
elfutils-dev
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gettext
glmark2
gstreamer1.0-libav
gzip
hidapi
libasm1
libcairo-perf-utils
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm4
libgettextlib
libgettextsrc
libgmp10
libidn11
libmavconn
libmpc3
libmpfr4
libreadline-dev
libreadline7
libunistring2
m4-dev
m4
make
mavlink
mavros-extras
mavros-msgs
mavros
nettle
parted
python3-pycairo
socketcan-interface
swig-dev
swig
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ 22.926689] pvrsrvkm: disagrees about version of symbol module_layout
[ OK ] Started rc.pvr.service.
Starting weston.service...
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am57xx-evm ttyS0
Arago 2018.10 am57xx-evm ttyS0
am57xx-evm login: root (automatic login)
root@am57xx-evm:~# lsmod
Module Size Used by
root@am57xx-evm:~# uname -r
4.14.79-gbde58ab01e
Linux
root@am57xx-evm:~# depmod -a
root@am57xx-evm:~# depmod rtc_omap
depmod: ERROR: Bad version passed rtc_omap
root@am57xx-evm:~#
In the process of removing the disagree statements we tried the following thing and we have encountered the highligthed parts due to which the modules were not loaded and the same scenario continued. Please suggest us what is happening and what we have to do to remove those statements. Also have a glance at the entire log and suggest us is there any issue other than this module related thing.
root@medha:/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/board-support/linux-4.14.79+gitAUTOINC+bde58ab01e-gbde58ab01e# export PATH=/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/:$PATH
root@medha:/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/board-support/linux-4.14.79+gitAUTOINC+bde58ab01e-gbde58ab01e# export ARCH=arm
root@medha:/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/board-support/linux-4.14.79+gitAUTOINC+bde58ab01e-gbde58ab01e# make ARCH=arm CROSS_COMPILE=/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- modules
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK scripts/mod/devicetable-offsets.h
Building modules, stage 2.
MODPOST 440 modules
root@medha:/home/toradex/ti-processor-sdk-linux-am57xx-evm-05.02.00.10/board-support/linux-4.14.79+gitAUTOINC+bde58ab01e-gbde58ab01e# sudo make ARCH=arm INSTALL_MOD_PATH=/media/toradex/rootfs/ modules_install
INSTALL arch/arm/crypto/aes-arm-bs.ko
INSTALL arch/arm/crypto/aes-arm-ce.ko
INSTALL arch/arm/crypto/aes-arm.ko
INSTALL arch/arm/crypto/chacha20-neon.ko
INSTALL arch/arm/crypto/crc32-arm-ce.ko
INSTALL arch/arm/crypto/ghash-arm-ce.ko
INSTALL arch/arm/crypto/sha1-arm-ce.ko
INSTALL arch/arm/crypto/sha1-arm-neon.ko
INSTALL arch/arm/crypto/sha1-arm.ko
INSTALL arch/arm/crypto/sha2-arm-ce.ko
INSTALL arch/arm/crypto/sha256-arm.ko
INSTALL arch/arm/crypto/sha512-arm.ko
INSTALL arch/arm/lib/xor-neon.ko
INSTALL crypto/af_alg.ko
INSTALL crypto/algif_aead.ko
INSTALL crypto/algif_hash.ko
INSTALL crypto/algif_rng.ko
INSTALL crypto/algif_skcipher.ko
INSTALL crypto/arc4.ko
INSTALL crypto/authenc.ko
INSTALL crypto/authencesn.ko
INSTALL crypto/cbc.ko
INSTALL crypto/ccm.ko
INSTALL crypto/chacha20_generic.ko
INSTALL crypto/cmac.ko
INSTALL crypto/cryptd.ko
INSTALL crypto/crypto_engine.ko
INSTALL crypto/crypto_simd.ko
INSTALL crypto/crypto_user.ko
INSTALL crypto/ctr.ko
INSTALL crypto/des_generic.ko
INSTALL crypto/drbg.ko
INSTALL crypto/ecb.ko
INSTALL crypto/ecdh_generic.ko
INSTALL crypto/echainiv.ko
INSTALL crypto/gcm.ko
INSTALL crypto/gf128mul.ko
INSTALL crypto/ghash-generic.ko
INSTALL crypto/hmac.ko
INSTALL crypto/jitterentropy_rng.ko
INSTALL crypto/md4.ko
INSTALL crypto/md5.ko
INSTALL crypto/seqiv.ko
INSTALL crypto/sha1_generic.ko
INSTALL crypto/sha256_generic.ko
INSTALL crypto/sha512_generic.ko
INSTALL crypto/tcrypt.ko
INSTALL crypto/xor.ko
INSTALL drivers/ata/ahci.ko
INSTALL drivers/ata/ahci_dm816.ko
INSTALL drivers/ata/ahci_platform.ko
INSTALL drivers/ata/libahci.ko
INSTALL drivers/ata/libahci_platform.ko
INSTALL drivers/ata/libata.ko
INSTALL drivers/ata/sata_mv.ko
INSTALL drivers/bluetooth/btmrvl.ko
INSTALL drivers/bluetooth/btmrvl_sdio.ko
INSTALL drivers/cdrom/cdrom.ko
INSTALL drivers/crypto/omap-aes-driver.ko
INSTALL drivers/crypto/omap-crypto.ko
INSTALL drivers/crypto/omap-des.ko
INSTALL drivers/crypto/omap-sham.ko
INSTALL drivers/crypto/virtio/virtio_crypto.ko
INSTALL drivers/edac/ti_edac.ko
INSTALL drivers/extcon/extcon-palmas.ko
INSTALL drivers/extcon/extcon-usb-gpio.ko
INSTALL drivers/firmware/efi/capsule-loader.ko
INSTALL drivers/firmware/efi/efi-pstore.ko
INSTALL drivers/firmware/efi/efivars.ko
INSTALL drivers/gpio/gpio-pisosr.ko
INSTALL drivers/gpio/gpio-tpic2810.ko
INSTALL drivers/hid/hid-multitouch.ko
INSTALL drivers/hid/usbhid/usbhid.ko
INSTALL drivers/hwmon/ina2xx.ko
INSTALL drivers/hwmon/ntc_thermistor.ko
INSTALL drivers/hwmon/pwm-fan.ko
INSTALL drivers/i2c/busses/i2c-emev2.ko
INSTALL drivers/i2c/muxes/i2c-arb-gpio-challenge.ko
INSTALL drivers/iio/adc/ti_am335x_adc.ko
INSTALL drivers/iio/adc/vf610_adc.ko
INSTALL drivers/iio/light/cm36651.ko
INSTALL drivers/input/input-polldev.ko
INSTALL drivers/input/keyboard/matrix_keypad.ko
INSTALL drivers/input/keyboard/qt1070.ko
INSTALL drivers/input/keyboard/samsung-keypad.ko
INSTALL drivers/input/matrix-keymap.ko
INSTALL drivers/input/misc/adxl34x-i2c.ko
INSTALL drivers/input/misc/adxl34x-spi.ko
INSTALL drivers/input/misc/adxl34x.ko
INSTALL drivers/input/misc/gpio_decoder.ko
INSTALL drivers/input/mouse/cyapatp.ko
INSTALL drivers/input/touchscreen/atmel_mxt_ts.ko
INSTALL drivers/input/touchscreen/edt-ft5x06.ko
INSTALL drivers/input/touchscreen/goodix.ko
INSTALL drivers/input/touchscreen/mms114.ko
INSTALL drivers/input/touchscreen/pixcir_i2c_ts.ko
INSTALL drivers/input/touchscreen/st1232.ko
INSTALL drivers/input/touchscreen/ti_am335x_tsc.ko
INSTALL drivers/leds/led-class-flash.ko
INSTALL drivers/media/common/v4l2-tpg/v4l2-tpg.ko
INSTALL drivers/media/i2c/adv7180.ko
INSTALL drivers/media/i2c/ml86v7667.ko
INSTALL drivers/media/i2c/mt9t11x.ko
INSTALL drivers/media/i2c/ov1063x.ko
INSTALL drivers/media/i2c/ov2659.ko
INSTALL drivers/media/i2c/ov490.ko
INSTALL drivers/media/platform/soc_camera/soc_camera.ko
INSTALL drivers/media/platform/soc_camera/soc_camera_platform.ko
INSTALL drivers/media/platform/soc_camera/soc_mediabus.ko
INSTALL drivers/media/platform/ti-vpe/ti-cal.ko
INSTALL drivers/media/platform/ti-vpe/ti-csc.ko
INSTALL drivers/media/platform/ti-vpe/ti-sc.ko
INSTALL drivers/media/platform/ti-vpe/ti-vip.ko
INSTALL drivers/media/platform/ti-vpe/ti-vpdma.ko
INSTALL drivers/media/platform/ti-vpe/ti-vpe.ko
INSTALL drivers/media/platform/vivid/vivid.ko
INSTALL drivers/media/usb/gspca/gspca_main.ko
INSTALL drivers/media/usb/uvc/uvcvideo.ko
INSTALL drivers/media/v4l2-core/v4l2-fwnode.ko
INSTALL drivers/media/v4l2-core/videobuf2-vmalloc.ko
INSTALL drivers/mfd/ti_am335x_tscadc.ko
INSTALL drivers/misc/eeprom/at24.ko
INSTALL drivers/misc/pci_endpoint_test.ko
INSTALL drivers/mtd/tests/mtd_nandbiterrs.ko
INSTALL drivers/mtd/tests/mtd_nandecctest.ko
INSTALL drivers/mtd/tests/mtd_oobtest.ko
INSTALL drivers/mtd/tests/mtd_pagetest.ko
INSTALL drivers/mtd/tests/mtd_readtest.ko
INSTALL drivers/mtd/tests/mtd_speedtest.ko
INSTALL drivers/mtd/tests/mtd_stresstest.ko
INSTALL drivers/mtd/tests/mtd_subpagetest.ko
INSTALL drivers/mtd/tests/mtd_torturetest.ko
INSTALL drivers/net/can/c_can/c_can.ko
INSTALL drivers/net/can/c_can/c_can_platform.ko
INSTALL drivers/net/can/can-dev.ko
INSTALL drivers/net/can/m_can/m_can.ko
INSTALL drivers/net/can/rcar/rcar_can.ko
INSTALL drivers/net/can/spi/mcp251x.ko
INSTALL drivers/net/dummy.ko
INSTALL drivers/net/ethernet/broadcom/tg3.ko
INSTALL drivers/net/ethernet/intel/e1000/e1000.ko
INSTALL drivers/net/ethernet/intel/e1000e/e1000e.ko
INSTALL drivers/net/ethernet/marvell/skge.ko
INSTALL drivers/net/ethernet/ti/ti_prueth.ko
INSTALL drivers/net/macvlan.ko
INSTALL drivers/net/usb/asix.ko
INSTALL drivers/net/usb/ax88179_178a.ko
INSTALL drivers/net/usb/cdc_ether.ko
INSTALL drivers/net/usb/cdc_ncm.ko
INSTALL drivers/net/usb/cdc_subset.ko
INSTALL drivers/net/usb/net1080.ko
INSTALL drivers/net/usb/pegasus.ko
INSTALL drivers/net/usb/r8152.ko
INSTALL drivers/net/usb/smsc75xx.ko
INSTALL drivers/net/usb/smsc95xx.ko
INSTALL drivers/net/usb/usbnet.ko
INSTALL drivers/net/usb/zaurus.ko
INSTALL drivers/net/veth.ko
INSTALL drivers/net/vxlan.ko
INSTALL drivers/net/wireless/broadcom/b43/b43.ko
INSTALL drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
INSTALL drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
INSTALL drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
INSTALL drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
INSTALL drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex.ko
INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex_sdio.ko
INSTALL drivers/net/wireless/ralink/rt2x00/rt2800lib.ko
INSTALL drivers/net/wireless/ralink/rt2x00/rt2800usb.ko
INSTALL drivers/net/wireless/ralink/rt2x00/rt2x00lib.ko
INSTALL drivers/net/wireless/ralink/rt2x00/rt2x00usb.ko
INSTALL drivers/net/wireless/ti/wl18xx/wl18xx.ko
INSTALL drivers/net/wireless/ti/wlcore/wlcore.ko
INSTALL drivers/net/wireless/ti/wlcore/wlcore_sdio.ko
INSTALL drivers/phy/ti/phy-omap-usb2.ko
INSTALL drivers/power/supply/max17040_battery.ko
INSTALL drivers/power/supply/max17042_battery.ko
INSTALL drivers/pwm/pwm-fsl-ftm.ko
INSTALL drivers/remoteproc/omap_remoteproc.ko
INSTALL drivers/remoteproc/pru_rproc.ko
INSTALL drivers/remoteproc/pruss.ko
INSTALL drivers/remoteproc/pruss_intc.ko
INSTALL drivers/remoteproc/pruss_soc_bus.ko
INSTALL drivers/remoteproc/remoteproc.ko
INSTALL drivers/rpmsg/rpmsg-rpc.ko
INSTALL drivers/rpmsg/rpmsg_core.ko
INSTALL drivers/rpmsg/rpmsg_pru.ko
INSTALL drivers/rpmsg/virtio_rpmsg_bus.ko
INSTALL drivers/rtc/rtc-ds1307.ko
INSTALL drivers/rtc/rtc-efi.ko
INSTALL drivers/rtc/rtc-omap.ko
INSTALL drivers/rtc/rtc-palmas.ko
INSTALL drivers/rtc/rtc-tps6586x.ko
INSTALL drivers/rtc/rtc-tps65910.ko
INSTALL drivers/scsi/scsi_mod.ko
INSTALL drivers/scsi/sd_mod.ko
INSTALL drivers/scsi/sr_mod.ko
INSTALL drivers/spi/spi-bitbang.ko
INSTALL drivers/spi/spi-gpio.ko
INSTALL drivers/ssb/ssb.ko
INSTALL drivers/uio/uio.ko
INSTALL drivers/usb/class/cdc-acm.ko
INSTALL drivers/usb/common/usb-common.ko
INSTALL drivers/usb/core/usbcore.ko
INSTALL drivers/usb/dwc3/dwc3-of-simple.ko
INSTALL drivers/usb/dwc3/dwc3-omap.ko
INSTALL drivers/usb/dwc3/dwc3.ko
INSTALL drivers/usb/gadget/function/u_audio.ko
INSTALL drivers/usb/gadget/function/u_ether.ko
INSTALL drivers/usb/gadget/function/u_serial.ko
INSTALL drivers/usb/gadget/function/usb_f_acm.ko
INSTALL drivers/usb/gadget/function/usb_f_ecm.ko
INSTALL drivers/usb/gadget/function/usb_f_ecm_subset.ko
INSTALL drivers/usb/gadget/function/usb_f_eem.ko
INSTALL drivers/usb/gadget/function/usb_f_fs.ko
INSTALL drivers/usb/gadget/function/usb_f_hid.ko
INSTALL drivers/usb/gadget/function/usb_f_mass_storage.ko
INSTALL drivers/usb/gadget/function/usb_f_midi.ko
INSTALL drivers/usb/gadget/function/usb_f_ncm.ko
INSTALL drivers/usb/gadget/function/usb_f_obex.ko
INSTALL drivers/usb/gadget/function/usb_f_printer.ko
INSTALL drivers/usb/gadget/function/usb_f_rndis.ko
INSTALL drivers/usb/gadget/function/usb_f_serial.ko
INSTALL drivers/usb/gadget/function/usb_f_ss_lb.ko
INSTALL drivers/usb/gadget/function/usb_f_uac1.ko
INSTALL drivers/usb/gadget/function/usb_f_uac2.ko
INSTALL drivers/usb/gadget/function/usb_f_uvc.ko
INSTALL drivers/usb/gadget/legacy/g_acm_ms.ko
INSTALL drivers/usb/gadget/legacy/g_audio.ko
INSTALL drivers/usb/gadget/legacy/g_cdc.ko
INSTALL drivers/usb/gadget/legacy/g_dbgp.ko
INSTALL drivers/usb/gadget/legacy/g_ether.ko
INSTALL drivers/usb/gadget/legacy/g_ffs.ko
INSTALL drivers/usb/gadget/legacy/g_hid.ko
INSTALL drivers/usb/gadget/legacy/g_mass_storage.ko
INSTALL drivers/usb/gadget/legacy/g_midi.ko
INSTALL drivers/usb/gadget/legacy/g_multi.ko
INSTALL drivers/usb/gadget/legacy/g_ncm.ko
INSTALL drivers/usb/gadget/legacy/g_printer.ko
INSTALL drivers/usb/gadget/legacy/g_serial.ko
INSTALL drivers/usb/gadget/legacy/g_webcam.ko
INSTALL drivers/usb/gadget/legacy/g_zero.ko
INSTALL drivers/usb/gadget/legacy/gadgetfs.ko
INSTALL drivers/usb/gadget/libcomposite.ko
INSTALL drivers/usb/gadget/udc/udc-core.ko
INSTALL drivers/usb/host/ehci-hcd.ko
INSTALL drivers/usb/host/ehci-omap.ko
INSTALL drivers/usb/host/ehci-pci.ko
INSTALL drivers/usb/host/ehci-platform.ko
INSTALL drivers/usb/host/ohci-hcd.ko
INSTALL drivers/usb/host/ohci-pci.ko
INSTALL drivers/usb/host/ohci-platform.ko
INSTALL drivers/usb/host/r8a66597-hcd.ko
INSTALL drivers/usb/host/xhci-hcd.ko
INSTALL drivers/usb/host/xhci-pci.ko
INSTALL drivers/usb/host/xhci-plat-hcd.ko
INSTALL drivers/usb/isp1760/isp1760.ko
INSTALL drivers/usb/misc/usbtest.ko
INSTALL drivers/usb/musb/am35x.ko
INSTALL drivers/usb/musb/musb_am335x.ko
INSTALL drivers/usb/musb/musb_dsps.ko
INSTALL drivers/usb/musb/musb_hdrc.ko
INSTALL drivers/usb/musb/omap2430.ko
INSTALL drivers/usb/phy/phy-am335x-control.ko
INSTALL drivers/usb/phy/phy-am335x.ko
INSTALL drivers/usb/phy/phy-generic.ko
INSTALL drivers/usb/phy/phy-gpio-vbus-usb.ko
INSTALL drivers/usb/phy/phy-isp1301.ko
INSTALL drivers/usb/serial/ftdi_sio.ko
INSTALL drivers/usb/serial/usbserial.ko
INSTALL drivers/usb/storage/usb-storage.ko
INSTALL drivers/w1/masters/omap_hdq.ko
INSTALL drivers/w1/wire.ko
INSTALL drivers/watchdog/omap_wdt.ko
INSTALL fs/btrfs/btrfs.ko
INSTALL fs/cifs/cifs.ko
INSTALL fs/efivarfs/efivarfs.ko
INSTALL fs/overlayfs/overlay.ko
INSTALL lib/crc-ccitt.ko
INSTALL lib/crc-itu-t.ko
INSTALL lib/libcrc32c.ko
INSTALL lib/raid6/raid6_pq.ko
INSTALL lib/ts_bm.ko
INSTALL lib/ts_fsm.ko
INSTALL lib/ts_kmp.ko
INSTALL lib/xxhash.ko
INSTALL lib/zstd/zstd_compress.ko
INSTALL lib/zstd/zstd_decompress.ko
INSTALL net/802/p8022.ko
INSTALL net/802/psnap.ko
INSTALL net/802/stp.ko
INSTALL net/8021q/8021q.ko
INSTALL net/bluetooth/bluetooth.ko
INSTALL net/bridge/br_netfilter.ko
INSTALL net/bridge/bridge.ko
INSTALL net/bridge/netfilter/ebt_802_3.ko
INSTALL net/bridge/netfilter/ebt_among.ko
INSTALL net/bridge/netfilter/ebt_arp.ko
INSTALL net/bridge/netfilter/ebt_arpreply.ko
INSTALL net/bridge/netfilter/ebt_dnat.ko
INSTALL net/bridge/netfilter/ebt_ip.ko
INSTALL net/bridge/netfilter/ebt_ip6.ko
INSTALL net/bridge/netfilter/ebt_limit.ko
INSTALL net/bridge/netfilter/ebt_log.ko
INSTALL net/bridge/netfilter/ebt_mark.ko
INSTALL net/bridge/netfilter/ebt_mark_m.ko
INSTALL net/bridge/netfilter/ebt_nflog.ko
INSTALL net/bridge/netfilter/ebt_pkttype.ko
INSTALL net/bridge/netfilter/ebt_redirect.ko
INSTALL net/bridge/netfilter/ebt_snat.ko
INSTALL net/bridge/netfilter/ebt_stp.ko
INSTALL net/bridge/netfilter/ebt_vlan.ko
INSTALL net/bridge/netfilter/ebtable_broute.ko
INSTALL net/bridge/netfilter/ebtable_filter.ko
INSTALL net/bridge/netfilter/ebtable_nat.ko
INSTALL net/bridge/netfilter/ebtables.ko
INSTALL net/can/can-bcm.ko
INSTALL net/can/can-gw.ko
INSTALL net/can/can-raw.ko
INSTALL net/can/can.ko
INSTALL net/dsa/dsa_core.ko
INSTALL net/ipv4/ah4.ko
INSTALL net/ipv4/esp4.ko
INSTALL net/ipv4/ipcomp.ko
INSTALL net/ipv4/netfilter/arp_tables.ko
INSTALL net/ipv4/netfilter/arpt_mangle.ko
INSTALL net/ipv4/netfilter/arptable_filter.ko
INSTALL net/ipv4/netfilter/ip_tables.ko
INSTALL net/ipv4/netfilter/ipt_MASQUERADE.ko
INSTALL net/ipv4/netfilter/iptable_filter.ko
INSTALL net/ipv4/netfilter/iptable_nat.ko
INSTALL net/ipv4/netfilter/nf_conntrack_ipv4.ko
INSTALL net/ipv4/netfilter/nf_defrag_ipv4.ko
INSTALL net/ipv4/netfilter/nf_nat_ipv4.ko
INSTALL net/ipv4/netfilter/nf_nat_masquerade_ipv4.ko
INSTALL net/ipv4/udp_tunnel.ko
INSTALL net/ipv4/xfrm4_mode_beet.ko
INSTALL net/ipv4/xfrm4_mode_transport.ko
INSTALL net/ipv4/xfrm4_mode_tunnel.ko
INSTALL net/ipv4/xfrm4_tunnel.ko
INSTALL net/ipv6/ah6.ko
INSTALL net/ipv6/esp6.ko
INSTALL net/ipv6/ip6_tunnel.ko
INSTALL net/ipv6/ip6_udp_tunnel.ko
INSTALL net/ipv6/ipcomp6.ko
INSTALL net/ipv6/mip6.ko
INSTALL net/ipv6/tunnel6.ko
INSTALL net/ipv6/xfrm6_tunnel.ko
INSTALL net/key/af_key.ko
INSTALL net/llc/llc.ko
INSTALL net/mac80211/mac80211.ko
INSTALL net/netfilter/ipvs/ip_vs.ko
INSTALL net/netfilter/ipvs/ip_vs_rr.ko
INSTALL net/netfilter/nf_conntrack.ko
INSTALL net/netfilter/nf_conntrack_ftp.ko
INSTALL net/netfilter/nf_conntrack_tftp.ko
INSTALL net/netfilter/nf_nat.ko
INSTALL net/netfilter/nf_nat_ftp.ko
INSTALL net/netfilter/nf_nat_tftp.ko
INSTALL net/netfilter/x_tables.ko
INSTALL net/netfilter/xt_CLASSIFY.ko
INSTALL net/netfilter/xt_IDLETIMER.ko
INSTALL net/netfilter/xt_addrtype.ko
INSTALL net/netfilter/xt_comment.ko
INSTALL net/netfilter/xt_conntrack.ko
INSTALL net/netfilter/xt_cpu.ko
INSTALL net/netfilter/xt_iprange.ko
INSTALL net/netfilter/xt_ipvs.ko
INSTALL net/netfilter/xt_length.ko
INSTALL net/netfilter/xt_limit.ko
INSTALL net/netfilter/xt_mac.ko
INSTALL net/netfilter/xt_mark.ko
INSTALL net/netfilter/xt_multiport.ko
INSTALL net/netfilter/xt_nat.ko
INSTALL net/netfilter/xt_pkttype.ko
INSTALL net/netfilter/xt_policy.ko
INSTALL net/netfilter/xt_sctp.ko
INSTALL net/netfilter/xt_tcpudp.ko
INSTALL net/rpmsg/rpmsg_proto.ko
INSTALL net/sched/act_csum.ko
INSTALL net/sched/act_gact.ko
INSTALL net/sched/act_ipt.ko
INSTALL net/sched/act_mirred.ko
INSTALL net/sched/act_nat.ko
INSTALL net/sched/act_pedit.ko
INSTALL net/sched/act_police.ko
INSTALL net/sched/act_simple.ko
INSTALL net/sched/act_skbedit.ko
INSTALL net/sched/cls_basic.ko
INSTALL net/sched/cls_cgroup.ko
INSTALL net/sched/cls_flow.ko
INSTALL net/sched/cls_fw.ko
INSTALL net/sched/cls_route.ko
INSTALL net/sched/cls_rsvp.ko
INSTALL net/sched/cls_rsvp6.ko
INSTALL net/sched/cls_tcindex.ko
INSTALL net/sched/cls_u32.ko
INSTALL net/sched/em_cmp.ko
INSTALL net/sched/em_meta.ko
INSTALL net/sched/em_nbyte.ko
INSTALL net/sched/em_text.ko
INSTALL net/sched/em_u32.ko
INSTALL net/sched/sch_cbq.ko
INSTALL net/sched/sch_choke.ko
INSTALL net/sched/sch_codel.ko
INSTALL net/sched/sch_drr.ko
INSTALL net/sched/sch_dsmark.ko
INSTALL net/sched/sch_fq_codel.ko
INSTALL net/sched/sch_gred.ko
INSTALL net/sched/sch_hfsc.ko
INSTALL net/sched/sch_htb.ko
INSTALL net/sched/sch_ingress.ko
INSTALL net/sched/sch_mqprio.ko
INSTALL net/sched/sch_multiq.ko
INSTALL net/sched/sch_netem.ko
INSTALL net/sched/sch_prio.ko
INSTALL net/sched/sch_qfq.ko
INSTALL net/sched/sch_red.ko
INSTALL net/sched/sch_sfb.ko
INSTALL net/sched/sch_sfq.ko
INSTALL net/sched/sch_tbf.ko
INSTALL net/sched/sch_teql.ko
INSTALL net/sctp/sctp.ko
INSTALL net/sctp/sctp_diag.ko
INSTALL net/wireless/cfg80211.ko
INSTALL net/xfrm/xfrm_algo.ko
INSTALL net/xfrm/xfrm_ipcomp.ko
INSTALL net/xfrm/xfrm_user.ko
INSTALL sound/core/snd-hwdep.ko
INSTALL sound/core/snd-rawmidi.ko
INSTALL sound/soc/codecs/snd-soc-spdif-rx.ko
INSTALL sound/soc/codecs/snd-soc-spdif-tx.ko
INSTALL sound/soc/codecs/snd-soc-tlv320aic31xx.ko
INSTALL sound/soc/codecs/snd-soc-tlv320aic3x.ko
INSTALL sound/soc/generic/snd-soc-simple-card-utils.ko
INSTALL sound/soc/generic/snd-soc-simple-card.ko
INSTALL sound/soc/generic/snd-soc-simple-scu-card.ko
INSTALL sound/soc/omap/snd-soc-omap-hdmi-audio.ko
INSTALL sound/usb/snd-usb-audio.ko
INSTALL sound/usb/snd-usbmidi-lib.ko
DEPMOD 4.14.79-gbde58ab01e
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/cls_rsvp6.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/cls_rsvp6.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/net/ethernet/marvell/skge.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/net/ethernet/marvell/skge.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/net/ethernet/marvell/skge.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/net/ethernet/marvell/skge.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/net/ethernet/marvell/skge.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol __per_cpu_offset
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol del_timer_sync
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol nr_cpu_ids
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol cpumask_next
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/netfilter/ipvs/ip_vs.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_multiq.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_multiq.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/hid/hid-multitouch.ko needs unknown symbol del_timer_sync
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_skbedit.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_skbedit.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_skbedit.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_mirred.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_mirred.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebt_limit.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebt_limit.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_teql.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_teql.ko needs unknown symbol _raw_spin_trylock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_teql.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol _raw_write_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol _raw_read_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol _raw_read_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol _raw_write_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol nr_cpu_ids
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/bridge/netfilter/ebtables.ko needs unknown symbol cpumask_next
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_police.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_police.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_police.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/galcore.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/galcore.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/galcore.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_dsmark.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/sch_dsmark.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/usb/gadget/function/usb_f_uvc.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/drivers/usb/gadget/function/usb_f_uvc.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_csum.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_csum.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/4.14.79-gbde58ab01e/kernel/net/sched/act_csum.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol cpu_up
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol nr_cpu_ids
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol cpumask_next
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /media/toradex/rootfs//lib/modules/4.14.79-gbde58ab01e/extra/driver/jailhouse.ko needs unknown symbol cpu_down
P. Venkata Prasad
