Linux/AM3358: Early printk on beaglebone black
Part Number: AM3358
Tool/software: Linux
I am trying to get Early printk to work on a BBB, but I don't think I see what I should.
I have a beaglebone black and I have compiled u-boot and Linux using the complete SDK "ti-processor-sdk-linux-am335x-evm-05.03.00.07"
In u-boot am335x_evm_defconfig I defined:
CONFIG_USE_BOOTARGS=y
CONFIG_BOOTARGS="earlyprintk"
In linux tisdk_am335x-evm_defconfig I defined:
CONFIG_DEBUG_LL=y
CONFIG_DEBUG_AM33XXUART1=y
CONFIG_DEBUG_OMAP2PLUS_UART=y
CONFIG_EARLY_PRINTK=y
I made the SD-Card using the ./create-sdcard.sh script and later I have used these command:
make clean
make u-boot
make linux
make linux-dtbs
make linux_install
In the "Rules.make" I updated the location of my SD card "RootFS partition" so that "make linux_install" will copy all files to the SD card. After that I manually copied the "MLO" and "U-Boot.img" to the boot partition as well.
When I boot from SD-Card on the BBB holding the button "S2" I can see that the BBB is booting properly into Linux.
Now I get this output:
U-Boot SPL 2018.01-00569-g7b4e473-dirty (May 03 2019 - 15:06:03)
Trying to boot from MMC1
*** Warning - bad CRC, using default environment
U-Boot 2018.01-00569-g7b4e473-dirty (May 03 2019 - 15:06:03 +0400)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
<ethaddr> not set. Validating first E-fuse MAC
Net:   cpsw, usb_ether
Hit any key to stop autoboot:  5  4  3  2  1  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
3871232 bytes read in 278 ms (13.3 MiB/s)
36805 bytes read in 32 ms (1.1 MiB/s)
   Loading Device Tree to 8fff4000, end 8fffffc4 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.79-ge669d52447 (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Fri May 3 14:47:11 +04 2019
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] cma: Reserved 48 MiB at 0x9d000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=6efe0a9a-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 456928K/524288K available (8192K kernel code, 319K rwdata, 2484K rodata, 1024K init, 267K bss, 18208K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0900000   (9184 kB)
[    0.000000]       .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
[    0.000000]       .data : 0xc0d00000 - 0xc0d4fd80   ( 320 kB)
[    0.000000]        .bss : 0xc0d4fd80 - 0xc0d92acc   ( 268 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000031] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000041] OMAP clocksource: timer1 at 24000000 Hz
[    0.000190] timer_probe: no matching timers found
[    0.000377] Console: colour dummy device 80x30
[    0.000403] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000409] This ensures that you still see kernel messages. Please
[    0.000414] update your kernel commandline.
[    0.000441] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.089222] pid_max: default: 32768 minimum: 301
[    0.089390] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.089403] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.090100] CPU: Testing write buffer coherency: ok
[    0.090160] CPU0: Spectre v2: using BPIALL workaround
[    0.090781] Setting up static identity map for 0x80100000 - 0x80100060
[    0.090914] Hierarchical SRCU implementation.
[    0.091215] EFI services will not be available.
[    0.092426] devtmpfs: initialized
[    0.098969] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[    0.099518] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.099804] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.099824] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.103147] pinctrl core: initialized pinctrl subsystem
[    0.103804] DMI not present or invalid.
[    0.104180] NET: Registered protocol family 16
[    0.106139] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.118934] omap_hwmod: debugss: _wait_target_disable failed
[    0.171326] cpuidle: using governor ladder
[    0.171358] cpuidle: using governor menu
[    0.175137] OMAP GPIO hardware version 0.1
[    0.183923] No ATAGs?
[    0.183940] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.195220] edma 49000000.edma: TI EDMA DMA engine driver
[    0.197940] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[    0.197999] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[    0.198107] media: Linux media interface: v0.10
[    0.198146] Linux video capture interface: v2.00
[    0.198239] pps_core: LinuxPPS API ver. 1 registered
[    0.198246] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.198266] PTP clock support registered
[    0.198297] EDAC MC: Ver: 3.0.0
[    0.198763] dmi: Firmware registration failed.
[    0.199142] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.199606] Advanced Linux Sound Architecture Driver Initialized.
[    0.200663] clocksource: Switched to clocksource timer1
[    0.207570] NET: Registered protocol family 2
[    0.208232] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.208277] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.208315] TCP: Hash tables configured (established 4096 bind 4096)
[    0.208404] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.208421] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.208560] NET: Registered protocol family 1
[    0.208972] RPC: Registered named UNIX socket transport module.
[    0.208988] RPC: Registered udp transport module.
[    0.208993] RPC: Registered tcp transport module.
[    0.208999] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.209980] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    0.210090] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.211538] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.215186] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.215970] NFS: Registering the id_resolver key type
[    0.216013] Key type id_resolver registered
[    0.216020] Key type id_legacy registered
[    0.216063] ntfs: driver 2.1.32 [Flags: R/O].
[    0.217891] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.217912] io scheduler noop registered
[    0.217919] io scheduler deadline registered
[    0.218106] io scheduler cfq registered (default)
[    0.218116] io scheduler mq-deadline registered
[    0.218122] io scheduler kyber registered
[    0.219207] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.263079] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.265799] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    0.899782] console [ttyS0] enabled
[    0.904982] omap_rng 48310000.rng: Random Number Generator ver. 20
[    0.922208] brd: module loaded
[    0.931170] loop: module loaded
[    0.936134] libphy: Fixed MDIO Bus: probed
[    1.010745] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.018447] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    1.025844] libphy: 4a101000.mdio: probed
[    1.029886] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    1.039978] cpsw 4a100000.ethernet: Detected MACID = 80:30:dc:54:7d:cc
[    1.046756] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.053231] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.058518] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.066984] i2c /dev entries driver
[    1.071014] IR NEC protocol handler initialized
[    1.075569] IR RC5(x/sz) protocol handler initialized
[    1.080637] IR RC6 protocol handler initialized
[    1.085217] IR JVC protocol handler initialized
[    1.089764] IR Sony protocol handler initialized
[    1.094409] IR SANYO protocol handler initialized
[    1.099129] IR Sharp protocol handler initialized
[    1.103860] IR MCE Keyboard/mouse protocol handler initialized
[    1.109713] IR XMP protocol handler initialized
[    1.115652] cpuidle: enable-method property 'ti,am3352' found operations
[    1.122782] sdhci: Secure Digital Host Controller Interface driver
[    1.128989] sdhci: Copyright(c) Pierre Ossman
[    1.134110] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.238051] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.248164] mmc0: new high speed SDHC card at address 59b4
[    1.253927] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.255300] ledtrig-cpu: registered to indicate activity on CPUs
[    1.264695] NET: Registered protocol family 10
[    1.265707] Segment Routing with IPv6
[    1.265768] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.266378] NET: Registered protocol family 17
[    1.266641] Key type dns_resolver registered
[    1.266821] omap_voltage_late_init: Voltage driver support not added
[    1.307439] mmcblk0: mmc0:59b4 NCard 14.7 GiB
[    1.313738]  mmcblk0: p1 p2
[    1.355420] random: fast init done
[    1.363777] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.404461] mmc1: new high speed MMC card at address 0001
[    1.410400] mmcblk1: mmc1:0001 S10004 3.56 GiB
[    1.415197] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[    1.421378] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[    1.427462] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB
[    1.434467]  mmcblk1: p1 p2
[    1.513049] tda998x 0-0070: found TDA19988
[    1.518341] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[    1.524439] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.531091] [drm] No driver support for vblank timestamp query.
[    1.537414] [drm] Cannot find any crtc or sizes
[    1.542534] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    1.550080] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.557537] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    1.565271] hctosys: unable to open rtc device (rtc0)
[    1.570983] ALSA device list:
[    1.573974]   No soundcards found.
[    2.561453] [drm] Cannot find any crtc or sizes
[    2.720135] EXT4-fs (mmcblk0p2): recovery complete
[    2.728373] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.737434] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.749843] devtmpfs: mounted
[    2.755846] Freeing unused kernel memory: 1024K
[    3.079284] systemd[1]: System time before build time, advancing clock.
[    3.153503] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
[    3.175002] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[    3.214500] systemd[1]: Set hostname to <am335x-evm>.
[    3.590182] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service'
[    3.899342] random: systemd: uninitialized urandom read (16 bytes read)
[    3.917542] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.951167] random: systemd: uninitialized urandom read (16 bytes read)
[    3.957967] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.991356] random: systemd: uninitialized urandom read (16 bytes read)
[    3.998909] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.037680] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    4.075229] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.116760] systemd[1]: Starting Remount Root and Kernel File Systems...
[  OK  ] Created slice User and Session Slice.
[    4.185532] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
         Mounting POSIX Message Queue File System...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Load Kernel Modules...
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.426139] cryptodev: loading out-of-tree module taints kernel.
[    4.451479] cryptodev: driver 1.9 loaded.
         Mounting Kernel Debug File System...
[  OK  ] Created slice system-getty.slice.
[    4.493445] usbcore: registered new interface driver usbfs
[    4.499058] usbcore: registered new interface driver hub
[    4.504775] usbcore: registered new device driver usb
[  OK  ] Reached target Slices.
[    4.519307] usbcore: registered new interface driver usbserial
[    4.539433] usbcore: registered new interface driver ftdi_sio
[  OK  ] Listening on Network Service Netlink Socket.[    4.547372] usbserial: USB Serial support registered for FTDI USB Serial Device
[  OK  ] Listening on Syslog Socket.
[  OK  ] Reached target Swap.
         Mounting Temporary Directory (/tmp)...
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Paths.
         Starting Journal Service...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Starting Rebuild Hardware Database...
         Starting Create System Users...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Journal Service.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[    5.321776] systemd-journald[77]: Received request to flush runtime journal from PID 1
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Rebuild Journal Catalog...
         Starting Rebuild Dynamic Linker Cache...
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Rebuild Dynamic Linker Cache.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Rebuild Hardware Database.
         Starting Update is Completed...
         Starting udev Coldplug all Devices...
[  OK  ] Started Update is Completed.
[   10.380919] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[  OK  ] Found device /dev/ttyS0.
[   10.602183] omap_rtc 44e3e000.rtc: registered as rtc0
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   10.761054] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting uim-sysfs.service...
[  OK  ] Started D-Bus System Message Bus.
[   11.561394] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   11.759601] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   11.814290] omap-aes 53500000.aes: will run requests pump with realtime priority
[   11.830130] remoteproc remoteproc0: wkup_m3 is available
[   11.892391] remoteproc remoteproc0: powering up wkup_m3
[   11.916542] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224628
[   11.916795] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   11.916824] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   11.931214] PM: bootloader does not support rtc-only!
[  OK  ] Reached target Containers.
[   12.510170] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1
[  OK  ] Started Periodic Command Scheduler.
         Starting Print notice about GPLv3 packages...
[  OK  ] Started Job spooling tools.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting Login Service...
[   13.219174] random: crng init done
[   13.376971] hdmi-audio-codec hdmi-audio-codec.0.auto: ASoC: no source widget found for Playback
[   13.376981] hdmi-audio-codec hdmi-audio-codec.0.auto: ASoC: Failed to add route Playback -> direct -> TX
[   13.377706] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[   13.377733] asoc-simple-card sound: ASoC: no DMI vendor name!
         Starting RPC Bind Service...
[   13.969940] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started System Logging Service.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Started Kernel Logging Service.
         Starting Network Service...
[  OK  ] Started RPC Bind Service.
[   14.672735] EXT4-fs (mmcblk1p2): recovery complete
[   14.677593] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   14.787625] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.083252] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Started Network Service.
[   15.725999] net eth0: initializing cpsw version 1.12 (0)
[  OK  ] Found device /dev/ttyS3.
[   15.932024] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[   16.237778] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  OK  ] Found device /dev/mmcblk0p1.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Start USB gadget...
[  OK  ] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
         Starting Permit User Sessions...
[  OK  ] Started Redis In-Memory Data Store.
         Starting Simple Network Management Protocol (SNMP) Daemon....
         Starting Enable and configure wl18xx bluetooth stack...
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started uim-sysfs.service.
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[   19.182802] udc-core: couldn't find an available UDC - added [g_multi] to list of pending drivers
[  OK  ] Started Network Name Resolution.
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[   20.543049] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[   20.763606] using random self ethernet address
[   20.771690] using random host ethernet address
[   20.819372] using host ethernet address: 80:30:DC:54:7D:CE
[   20.819440] using random self ethernet address
[   20.928736] using random host ethernet address
[   20.969035] using host ethernet address: 80:30:DC:54:7D:CE
[   20.978538] usb0: HOST MAC 80:30:dc:54:7d:ce
[   21.067524] usb0: MAC 06:72:a3:53:13:32
[   21.188803] Mass Storage Function, version: 2009/09/11
[   21.220521] LUN: removable file: (no medium)
[   21.261269] LUN: removable read only file: /dev/mmcblk0p1
[   21.315082] Number of LUNs=1
[   21.344977] g_multi gadget: Multifunction Composite Gadget
[   21.398392] g_multi gadget: g_multi ready
[   21.443660] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[   21.519068] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[   21.573129] pruss 4a300000.pruss: creating PRU cores and other child platform devices
[   21.704288] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[   21.774006] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   21.843173] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   21.850445] usb usb1: Product: MUSB HDRC host driver
[   21.952251] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd
[   22.028911] remoteproc remoteproc1: 4a334000.pru is available
[   22.028986] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully
[   22.057431] remoteproc remoteproc2: 4a338000.pru is available
[   22.057515] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully
[   22.261667] usb usb1: SerialNumber: musb-hdrc.1
[   22.289584] hub 1-0:1.0: USB hub found
[   22.306108] hub 1-0:1.0: 1 port detected
[   22.764829] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[  OK  ] Found device /dev/ttyGS0.
[  OK  ] Reached target Sound Card.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Serial Getty on ttyGS0.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting rc.pvr.service...
[  OK  ] Started Synchronize System and HW clocks.
[   25.135362] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
NOTICE: This file system contains the following GPLv3 packages:
	autoconf
	bash-dev
	bash
	binutils
	cifs-utils
	cpio
	cpp-symlinks
	cpp
	dosfstools
	elfutils
	findutils
	g++-symlinks
	g++
	gawk
	gcc-symlinks
	gcc
	gdb
	gdbserver
	gettext
	glmark2
	gstreamer1.0-libav
	gzip
	hidapi
	libdw1
	libelf1
	libgdbm-compat4
	libgdbm-dev
	libgdbm4
	libgettextlib
	libgettextsrc
	libgmp10
	libidn11
	libmavconn
	libmpc3
	libmpfr4
	libreadline-dev
	libreadline7
	libunistring2
	m4-dev
	m4
	make
	mavlink
	mavros-extras
	mavros-msgs
	mavros
	nettle
	python3-pycairo
	socketcan-interface
	which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Started weston.service.
         Starting telnetd.service...
         Starting Matrix GUI...
[  OK  ] Started telnetd.service.
         Starting thttpd.service...
         Starting busybox-udhcpd.service...
[  OK  ] Started Matrix GUI.
[  OK  ] Started thttpd.service.
[  OK  ] Started busybox-udhcpd.service.
         Starting rng-tools.service...
[  OK  ] Started rng-tools.service.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2018.10 am335x-evm ttyS0
am335x-evm login:
Is this an expected output when using Early printk? I am expecting more to be honest directly after "Starting kernel".
Thank you.
    Well, I'm seeing about the same as you. Here's a diff of my .config vs. tisdk_am335x-evm_defconfig:
    < # CONFIG_DEBUG_LL is not set
    < CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
    < # CONFIG_DEBUG_UART_8250 is not set
    > CONFIG_DEBUG_LL=y
    > # CONFIG_DEBUG_OMAP2UART1 is not set
    > # CONFIG_DEBUG_OMAP2UART2 is not set
    > # CONFIG_DEBUG_OMAP2UART3 is not set
    > # CONFIG_DEBUG_OMAP3UART3 is not set
    > # CONFIG_DEBUG_OMAP4UART3 is not set
    > # CONFIG_DEBUG_OMAP3UART4 is not set
    > # CONFIG_DEBUG_OMAP4UART4 is not set
    > # CONFIG_DEBUG_TI81XXUART1 is not set
    > # CONFIG_DEBUG_TI81XXUART2 is not set
    > # CONFIG_DEBUG_TI81XXUART3 is not set
    > # CONFIG_DEBUG_ZOOM_UART is not set
    > # CONFIG_DEBUG_ICEDCC is not set
    > # CONFIG_DEBUG_SEMIHOSTING is not set
    > # CONFIG_DEBUG_LL_UART_8250 is not set
    > # CONFIG_DEBUG_LL_UART_PL01X is not set
    > CONFIG_DEBUG_LL_INCLUDE="debug/8250.S"
    > CONFIG_DEBUG_UART_8250=y
    > CONFIG_DEBUG_UART_PHYS=0x44e09000
    > CONFIG_DEBUG_UART_VIRT=0xf9e09000
    > CONFIG_DEBUG_UART_8250_SHIFT=2
    > # CONFIG_DEBUG_UART_8250_WORD is not set
    > # CONFIG_DEBUG_UART_8250_PALMCHIP is not set
    > # CONFIG_DEBUG_UART_8250_FLOW_CONTROL is not set
    > CONFIG_DEBUG_UNCOMPRESS=y
    5566a5590
    There are a few differences here like the use of the 8250 driver that we have switched to.
    I don't think you are getting earlyprintk to your kernel command line and this is probably causing some trouble. I used U-Boot environment to add earlyprintk to mine with this command:
    setenv args_mmc 'run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype} earlyprintk'
    As a result, I believe I'm seeing some differences as listed below:
    root@am335x-evm:~# dmesg | grep console
    [ 0.000000] bootconsole [earlycon0] enabled
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=0003f594-02 rw rootfstype=ext4 rootwait earlyprintk
    [ 0.032789] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.651153] console [ttyS0] enabled
    [ 0.658367] bootconsole [earlycon0] disabled
    The earlycon0 stuff seems to be added by earlyprintk.
    Hopefully this helps you get it enabled and with some expectations.
    Thanks.
  • Yes, same result as me.
    Thanks!
