Linux/TDA2EVM5777: No video output using 6-channel camera
Part Number: TDA2EVM5777
Tool/software: Linux
I want to use a 6-channel camera to collect data and store the data in a file. The usecase used is UC_lvds_vip_multi_cam_vpe_enc_null, gChains_usecaseCfg.numLvdsCh = 6; NDK_PROC_TO_USE=none, the problem occurs at runtime:
[HOST] [IPU2  ]     81.937046 s:  CHAINS: ChainsCommon_MultiCam_StartCaptureDevice
 [HOST] [IPU2  ]     81.937625 s:  VIDEO_SENSOR: INST1 : I2C1 : I2C Addr = 0x38
 [HOST] [IPU2  ]     82.287622 s:  VIDEO_SENSOR: VIP 0: DRV ID 1205 (I2C ADDR 0x38): a635:0000:7fa2
 [HOST] [IPU2  ]     82.288171 s:  VIDEO_SENSOR: INST2 : I2C1 : I2C Addr = 0x39
 [HOST] [IPU2  ]     82.638107 s:  VIDEO_SENSOR: VIP 2: DRV ID 1205 (I2C ADDR 0x39): a635:0000:7fa2
 [HOST] [IPU2  ]     82.638809 s:  VIDEO_SENSOR: INST3 : I2C1 : I2C Addr = 0x3a
 [HOST] [IPU2  ]     82.988928 s:  VIDEO_SENSOR: VIP 4: DRV ID 1205 (I2C ADDR 0x3a): a635:0000:7fa2
 [HOST] [IPU2  ]     82.989507 s:  VIDEO_SENSOR: INST4 : I2C1 : I2C Addr = 0x3b
 [HOST] [IPU2  ]     83.339840 s:  VIDEO_SENSOR: VIP 8: DRV ID 1205 (I2C ADDR 0x3b): a635:0000:7fa2
 [HOST] [IPU2  ]     83.340389 s:  VIDEO_SENSOR: INST6 : I2C1 : I2C Addr = 0x3d
 [HOST] [IPU2  ]     83.675379 s:  VIDEO_SENSOR: VIP 10: DRV ID 1205 (I2C ADDR 0x3d): a635:0000:7fa2
 [HOST] [IPU2  ]     83.675959 s:  VIDEO_SENSOR: INST5 : I2C1 : I2C Addr = 0x3c
[   77.147569] davinci_mdio 48485000.mdio: timed out waiting for user access
[   77.247564] davinci_mdio 48485000.mdio: timed out waiting for user access
[   77.447564] davinci_mdio 48485000.mdio: timed out waiting for idle
 [HOST] [IPU2  ]     84.419599 s: src/bsp_deviceI2c.c @ Line 386:
 [HOST] [IPU2  ]     84.419691 s:  I2C1: DEV 0x78: RD 0x01 ... ERROR !!!
 [HOST] [IPU2  ]     84.419782 s: src/bsp_deviceI2c.c @ Line 412:
 [HOST] [IPU2  ]     84.419874 s:  I2C1: Error timeout 648 ms!!!
 [HOST] [IPU2  ]     84.419965 s: src/bsputils_lvds.c @ Line 919:
 [HOST] [IPU2  ]     84.420026 s:  device address - 78 i2c error - -21
 [HOST] [IPU2  ]     84.678734 s:  VIDEO_SENSOR: VIP 7: DRV ID 1205 (I2C ADDR 0x3c): a635:0000:7fa2
 [HOST] [IPU2  ]     84.687244 s:  CAPTURE: Create in progress !!!
 [HOST] [IPU2  ]     84.687671 s:  CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     84.808363 s:  CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     84.929238 s:  CAPTURE: VIP2 Slice0 PortA capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     85.050082 s:  CAPTURE: VIP3 Slice0 PortA capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     85.170896 s:  CAPTURE: VIP3 Slice1 PortA capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     85.291770 s:  CAPTURE: VIP2 Slice1 PortB capture mode is [ 8-bit] !!!
 [HOST] [IPU2  ]     85.412737 s:  CAPTURE: Create Done !!!
    What else do I need to set?
    As i can see there are some I2C address is failing. So this could be coming due to loose connectivity of camera.
    Also in order to use 6 channel from capture link you need to change something in dts file also,
    I will share the changes shortly.
    Anuj
    The project is urgent, I look forward to your update dts file as soon as possible.
  • It seems one of the serializer is not accessible, can you please check your connections?
    Brijesh
    Can you tell me which sequence program is not accessible? Is it this one?
    [  735.757556] davinci_mdio 48485000.mdio: timed out waiting for user access
    [  735.867554] davinci_mdio 48485000.mdio: timed out waiting for user access
    [  736.067549] davinci_mdio 48485000.mdio: timed out waiting for idle
    What does this log mean? This log only appears when using a 6-way camera, and there is no video output. This print log does not appear when using a 4-way camera, and there is normal video output
  • No this is the one
    Rgds,
    Brijesh
    [HOST] [IPU2  ]     71.769383 s:  CHAINS: ChainsCommon_MultiCam_StartCaptureDevice
     [HOST] [IPU2  ]     71.769962 s:  VIDEO_SENSOR: INST1 : I2C1 : I2C Addr = 0x38
     [HOST] [IPU2  ]     72.120020 s:  VIDEO_SENSOR: VIP 0: DRV ID 1205 (I2C ADDR 0x38): a635:0000:7fa2
     [HOST] [IPU2  ]     72.120569 s:  VIDEO_SENSOR: INST2 : I2C1 : I2C Addr = 0x39
     [HOST] [IPU2  ]     72.471176 s:  VIDEO_SENSOR: VIP 2: DRV ID 1205 (I2C ADDR 0x39): a635:0000:7fa2
     [HOST] [IPU2  ]     72.471725 s:  VIDEO_SENSOR: INST3 : I2C1 : I2C Addr = 0x3a
     [HOST] [IPU2  ]     72.822241 s:  VIDEO_SENSOR: VIP 4: DRV ID 1205 (I2C ADDR 0x3a): a635:0000:7fa2
     [HOST] [IPU2  ]     72.822759 s:  VIDEO_SENSOR: INST4 : I2C1 : I2C Addr = 0x3b
     [HOST] [IPU2  ]     73.173366 s:  VIDEO_SENSOR: VIP 8: DRV ID 1205 (I2C ADDR 0x3b): a635:0000:7fa2
     [HOST] [IPU2  ]     73.173915 s:  VIDEO_SENSOR: INST6 : I2C1 : I2C Addr = 0x3d
     [HOST] [IPU2  ]     73.510339 s:  VIDEO_SENSOR: VIP 10: DRV ID 1205 (I2C ADDR 0x3d): a635:0000:7fa2
     [HOST] [IPU2  ]     73.510919 s:  VIDEO_SENSOR: INST5 : I2C1 : I2C Addr = 0x3c
    [   67.037382] davinci_mdio 48485000.mdio: timed out waiting for idle
     [HOST] [IPU2  ]     73.845330 s:  VIDEO_SENSOR: VIP 7: DRV ID 1205 (I2C ADDR 0x3c): a635:0000:7fa2
     [HOST] [IPU2  ]     73.854724 s:  CAPTURE: Create in progress !!!
     [HOST] [IPU2  ]     73.855121 s:  CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]     73.976087 s:  CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]     74.097053 s:  CAPTURE: VIP2 Slice0 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]     74.218416 s:  CAPTURE: VIP3 Slice0 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]     74.339809 s:  CAPTURE: VIP3 Slice1 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]     74.461294 s:  CAPTURE: VIP2 Slice1 PortB capture mode is [ 8-bit] !!!
    [   67.887375] davinci_mdio 48485000.mdio: timed out waiting for user access
    loaded module : gbm_pvr.so
    found valid GBM backend : gbm_pvr.so
     [HOST] [HOST  ]     74.584090 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [HOST  ]     74.584700 s:  IPC_IN_0   : Create Done !!!
     [HOST] [HOST  ]     74.585097 s:  SGXFRMCPY: Create in progress for resolution: 1920x1080 !!!
     [HOST] [HOST  ]     74.585127 s:  SYSTEM_PVRSCOPE: FIFO /opt/vision_sdk/gpufifo opened successfully
     [HOST] [IPU2  ]     74.582809 s:  CAPTURE: Create Done !!!
     [HOST] [IPU2  ]     74.583389 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [IPU2  ]     74.583724 s:  IPC_OUT_0   : Create Done !!!
     [HOST] [HOST  ]     74.598487 s:  EGL: version 1.4
     [HOST] [HOST  ]     74.606783 s:  EGL: GL Version = (null)
     [HOST] [HOST  ]     74.606783 s:  EGL: GL Vendor = (null)
     [HOST] [HOST  ]     74.606813 s:  EGL: GL Renderer = (null)
     [HOST] [HOST  ]     74.606813 s:  EGL: GL Extensions = (null)
    [   67.987535] davinci_mdio 48485000.mdio: timed out waiting for user access
    [ HOST] [HOST  ]     74.648356 s:  SGXFRMCPY: Create Done for reslution: 1920x1080 !!!
     [HOST] [HOST  ]     74.648417 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [HOST  ]     74.648447 s:  IPC_OUT_0   : Create Done !!!
     [HOST] [IPU2  ]     74.648630 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [IPU2  ]     74.649789 s:  IPC_IN_0   : Create Done !!!
     [HOST] [IPU2  ]     74.650308 s:  DISPLAY: Create in progress !!!
     [HOST] [IPU2  ]     74.650826 s:  DISPLAY: Create Done !!!
     [HOST] [IPU2  ]     74.651345 s:  GRPXSRC: Create in progress !!!
    [   68.207370] davinci_mdio 48485000.mdio: timed out waiting for idle
     [HOST] [IPU2  ]     76.090251 s:  GRPXSRC: Create Done !!!
     [HOST] [IPU2  ]     76.090770 s:  DISPLAY: Create in progress !!!
     [HOST] [IPU2  ]     76.091441 s:  DISPLAY: Create Done !!!
     [HOST] [IPU2  ]     76.094857 s:  *** UTILS: CPU KHz = 20000 Khz ***
     [HOST] [DSP1  ]     76.192277 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [DSP1  ]     76.192307 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP1  ]     76.192368 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516016 B (503 KB)
     [HOST] [DSP2  ]     76.192582 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [DSP2  ]     76.192643 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP2  ]     76.192673 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516016 B (503 KB)
     [HOST] [EVE1  ]     76.193192 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [EVE1  ]     76.193497 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE1  ]     76.194046 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248 KB)
     [HOST] [EVE2  ]     76.195052 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [EVE2  ]     76.195357 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE2  ]     76.195967 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248 KB)
     [HOST] [EVE3  ]     76.197004 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [HOST  ]     76.206063 s:  SGXFRMCPY: Start in progress !!!
     [HOST] [HOST  ]     76.206063 s:  SGXFRMCPY: Start Done !!!
     [HOST] [EVE3  ]     76.197309 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE3  ]     76.197858 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248 KB)
     [HOST] [EVE4  ]     76.198865 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [EVE4  ]     76.199139 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE4  ]     76.199688 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248 KB)
     [HOST] [IPU2  ]     76.200573 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
     [HOST] [IPU2  ]     76.200695 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 248352 B (242 KB)
     [HOST] [IPU2  ]     76.200847 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
     [HOST] [IPU2  ]     76.201061 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 227481600 B (216 MB)
     [HOST] [IPU2  ]     76.201244 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB)
     [HOST] [IPU2  ]     76.201701 s:  DISPLAY: Start in progress !!!
     [HOST] [IPU2  ]     76.201762 s:  DISPLAY: Start Done !!!
     [HOST] [IPU2  ]     76.205423 s:  DISPLAY: Start in progress !!!
     [HOST] [IPU2  ]     76.205514 s:  DISPLAY: Start Done !!!
     [HOST] [IPU2  ]     76.206582 s:  CAPTURE: Start in progress !!!
     [HOST] [IPU2  ]     76.218233 s:  CAPTURE: Start Done !!!
    using a 6-way camera,  no video output
    Can you press p after 1 min and share the log.
    Just want to check whether any data is coming on capture link or not.
    Anuj
    [HOST] [IPU2  ]    358.591624 s:  CAPTURE: VIP1 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    358.591715 s:  CAPTURE: VIP1 Slice1 PortA FRAME MODE
     [HOST] [IPU2  ]    358.591807 s:  CAPTURE: VIP2 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    358.591868 s:  CAPTURE: VIP3 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    358.591959 s:  CAPTURE: VIP3 Slice1 PortA FRAME MODE
     [HOST] [IPU2  ]    358.592020 s:  CAPTURE: VIP2 Slice1 PortB FRAME MODE
     [HOST] [IPU2  ]    358.592112 s:
     [HOST] [IPU2  ]    358.592173 s:  [ CAPTURE ] Link Statistics,
     [HOST] [IPU2  ]    358.592234 s:  ******************************
     [HOST] [IPU2  ]    358.592295 s:
     [HOST] [IPU2  ]    358.592356 s:  Elapsed time       = 197424 msec
     [HOST] [IPU2  ]    358.592417 s:
     [HOST] [IPU2  ]    358.592447 s:  New data Recv      = 150.30 fps
     [HOST] [IPU2  ]    358.592539 s:  Get Full Buf Cb    =   0.15 fps
     [HOST] [IPU2  ]    358.592600 s:  Driver/Notify Cb   = 150.30 fps
     [HOST] [IPU2  ]    358.592692 s:
     [HOST] [IPU2  ]    358.592722 s:  Input Statistics,
     [HOST] [IPU2  ]    358.592783 s:
     [HOST] [IPU2  ]    358.592814 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    358.592905 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    358.592966 s:  --------------------------------------------------
     [HOST] [IPU2  ]    358.593058 s:
     [HOST] [IPU2  ]    358.593088 s:  Output Statistics,
     [HOST] [IPU2  ]    358.593180 s:
     [HOST] [IPU2  ]    358.593210 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [IPU2  ]    358.593302 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [IPU2  ]    358.593363 s:  ---------------------------------------------
     [HOST] [IPU2  ]    358.593454 s:   0 |  0      0. 3     0. 0      0. 0
     [HOST] [IPU2  ]    358.593576 s:   1 |  0      0. 3     0. 0      0. 0
     [HOST] [IPU2  ]    358.593698 s:   2 |  0      0. 3     0. 0      0. 0
     [HOST] [IPU2  ]    358.593820 s:   3 |  0      0. 3     0. 0      0. 0
     [HOST] [IPU2  ]    358.593912 s:   4 |  0      0. 3     0. 0      0. 0
     [HOST] [IPU2  ]    358.594095 s:
     [HOST] [IPU2  ]    358.594186 s:  [VIP1 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    358.594247 s:  ==============================
     [HOST] [IPU2  ]    358.594308 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.594400 s:  Number of request dequeued: 6
     [HOST] [IPU2  ]    358.594461 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.594552 s:
     [HOST] [IPU2  ]    358.594583 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.594735 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.594857 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.595193 s:   00.0.00 |       6       6    5935    5935       0     30    30     0  1280/1280    720/720      5929       0       0     0
     [HOST] [IPU2  ]    358.595345 s:
     [HOST] [IPU2  ]    358.595376 s:
     [HOST] [IPU2  ]    358.595406 s:  [VIP1 Slice1 PortA] Statistics
     [HOST] [IPU2  ]    358.595498 s:  ==============================
     [HOST] [IPU2  ]    358.595559 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.595620 s:  Number of request dequeued: 6
     [HOST] [IPU2  ]    358.595681 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.595742 s:
     [HOST] [IPU2  ]    358.595772 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.595925 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.596047 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.596352 s:   02.0.00 |       6       6    5935    5935       0     30    30     0  1280/1280    720/720      5929       0       0     0
     [HOST] [IPU2  ]    358.596474 s:
     [HOST] [IPU2  ]    358.596535 s:
     [HOST] [IPU2  ]    358.596565 s:  [VIP2 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    358.596626 s:  ==============================
     [HOST] [IPU2  ]    358.596687 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.596779 s:  Number of request dequeued: 6
     [HOST] [IPU2  ]    358.596840 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.596901 s:
     [HOST] [IPU2  ]    358.596931 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.597084 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.597206 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.597511 s:   04.0.00 |       6       6    5935    5935       0     30    30     0  1280/1280    720/720      5929       0       0     0
     [HOST] [IPU2  ]    358.597633 s:
     [HOST] [IPU2  ]    358.597694 s:
     [HOST] [IPU2  ]    358.597724 s:  [VIP3 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    358.597785 s:  ==============================
     [HOST] [IPU2  ]    358.597846 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.597938 s:  Number of request dequeued: 6
     [HOST] [IPU2  ]    358.597999 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.598060 s:
     [HOST] [IPU2  ]    358.598090 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.598243 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.598365 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.598761 s:   08.0.00 |       6       6    5935    5935       0     30    30     0  1280/1280    720/720      5929       0       0     0
     [HOST] [IPU2  ]    358.598883 s:
     [HOST] [IPU2  ]    358.598914 s:
     [HOST] [IPU2  ]    358.598975 s:  [VIP3 Slice1 PortA] Statistics
     [HOST] [IPU2  ]    358.599158 s:  ==============================
     [HOST] [IPU2  ]    358.599249 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.599310 s:  Number of request dequeued: 6
     [HOST] [IPU2  ]    358.599371 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.599432 s:
     [HOST] [IPU2  ]    358.599493 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.599615 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.599737 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.600042 s:   10.0.00 |       6       6    5935    5935       0     30    30     0  1280/1280    720/720      5929       0       0     0
     [HOST] [IPU2  ]    358.600195 s:
     [HOST] [IPU2  ]    358.600256 s:
     [HOST] [IPU2  ]    358.600286 s:  [VIP2 Slice1 PortB] Statistics
     [HOST] [IPU2  ]    358.600347 s:  ==============================
     [HOST] [IPU2  ]    358.600408 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    358.600469 s:  Number of request dequeued: 0
     [HOST] [IPU2  ]    358.600530 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    358.600591 s:
     [HOST] [IPU2  ]    358.600652 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    358.600774 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    358.600988 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    358.601323 s:   07.0.00 |       6       0       0       0       0      0     0     0     0/0         0/0           0       0       0     0
     [HOST] [IPU2  ]    358.601476 s:
     [HOST] [IPU2  ]    358.602086 s:
     [HOST] [IPU2  ]    358.602177 s:  [ SYNC_LINK_0 ] Link Statistics,
     [HOST] [IPU2  ]    358.602238 s:  ******************************
     [HOST] [IPU2  ]    358.602299 s:
     [HOST] [IPU2  ]    358.602360 s:  Elapsed time       = 197443 msec
     [HOST] [IPU2  ]    358.602421 s:
     [HOST] [IPU2  ]    358.602452 s:  New data Recv      =  30.44 fps
     [HOST] [IPU2  ]    358.602543 s:  Driver/Notify Cb   =  30.29 fps
     [HOST] [IPU2  ]    358.602604 s:
     [HOST] [IPU2  ]    358.602665 s:  Input Statistics,
     [HOST] [IPU2  ]    358.602696 s:
     [HOST] [IPU2  ]    358.602757 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    358.602818 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    358.602909 s:  --------------------------------------------------
     [HOST] [IPU2  ]    358.602970 s:   0 |   0. 3      0. 0      0. 0           0. 0
     [HOST] [IPU2  ]    358.603153 s:   1 |   0. 3      0. 0      0. 0           0. 0
     [HOST] [IPU2  ]    358.603275 s:   2 |   0. 3      0. 0      0. 0           0. 0
     [HOST] [IPU2  ]    358.603397 s:   3 |   0. 3      0. 0      0. 0           0. 0
     [HOST] [IPU2  ]    358.603550 s:   4 |   0. 3      0. 0      0. 0           0. 0
     [HOST] [IPU2  ]    358.603672 s:
     [HOST] [IPU2  ]    358.603702 s:  Output Statistics,
     [HOST] [IPU2  ]    358.603763 s:
     [HOST] [IPU2  ]    358.603794 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [IPU2  ]    358.603885 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [IPU2  ]    358.603946 s:  ---------------------------------------------
     [HOST] [IPU2  ]    358.604068 s:
     [HOST] [IPU2  ]    358.604160 s:  [ SYNC_LINK_0 ] LATENCY,
     [HOST] [IPU2  ]    358.604221 s:  ********************
     [HOST] [IPU2  ]    358.604282 s:
     [HOST] [IPU2  ]    358.604831 s:
     [HOST] [IPU2  ]    358.604892 s:  [ ALG_DMA_SWMS ] Link Statistics,
     [HOST] [IPU2  ]    358.604953 s:  ******************************
     [HOST] [IPU2  ]    358.605014 s:
     [HOST] [IPU2  ]    358.605044 s:  Elapsed time       = 200506 msec
     [HOST] [IPU2  ]    358.605166 s:
     [HOST] [IPU2  ]    358.605197 s:
     [HOST] [IPU2  ]    358.605227 s:  Input Statistics,
     [HOST] [IPU2  ]    358.605288 s:
     [HOST] [IPU2  ]    358.605319 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    358.605410 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    358.605471 s:  --------------------------------------------------
     [HOST] [IPU2  ]    358.605563 s:
     [HOST] [IPU2  ]    358.605624 s:  Output Statistics,
     [HOST] [IPU2  ]    358.605654 s:
     [HOST] [IPU2  ]    358.605715 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [IPU2  ]    358.605776 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [IPU2  ]    358.605868 s:  ---------------------------------------------
     [HOST] [IPU2  ]    358.606051 s:
     [HOST] [IPU2  ]    358.606081 s:  [ ALG_DMA_SWMS ] LATENCY,
     [HOST] [IPU2  ]    358.606173 s:  ********************
     [HOST] [IPU2  ]    358.606234 s:
     [HOST] [IPU2  ]    358.606569 s:
     [HOST] [IPU2  ]    358.606600 s:  [ ENCODE ] Link Statistics,
     [HOST] [IPU2  ]    358.606661 s:  ******************************
     [HOST] [IPU2  ]    358.606752 s:
     [HOST] [IPU2  ]    358.606783 s:  Elapsed time       = 199050 msec
     [HOST] [IPU2  ]    358.606844 s:
     [HOST] [IPU2  ]    358.606905 s:
     [HOST] [IPU2  ]    358.606935 s:  Input Statistics,
     [HOST] [IPU2  ]    358.606996 s:
     [HOST] [IPU2  ]    358.607027 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    358.607088 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    358.607210 s:  --------------------------------------------------
     [HOST] [IPU2  ]    358.607332 s:  ENCODE: Num process reqest count for chId: 0 = 0
     [HOST] [IPU2  ]    358.607423 s:  ENCODE: Num process complete count for chId: 0 = 0
     [HOST] [IPU2  ]    358.607515 s:
     [HOST] [IPU2  ]    358.607545 s:  [ ENCODE ] LATENCY,
     [HOST] [IPU2  ]    358.607606 s:  ********************
     [HOST] [IPU2  ]    358.607637 s:
     [HOST] [IPU2  ]    358.607698 s:  HDVICP-ID: 0
     [HOST] [IPU2  ]    358.607759 s:
     [HOST] [IPU2  ]    358.608094 s:
     [HOST] [IPU2  ]    358.608186 s:  [ IPC_OUT_0 ] Link Statistics,
     [HOST] [IPU2  ]    358.608247 s:  ******************************
     [HOST] [IPU2  ]    358.608308 s:
     [HOST] [IPU2  ]    358.608338 s:  Elapsed time       = 199051 msec
     [HOST] [IPU2  ]    358.608430 s:
     [HOST] [IPU2  ]    358.608460 s:  Driver/Notify Cb   =  33.6 fps
     [HOST] [IPU2  ]    358.608552 s:
     [HOST] [IPU2  ]    358.608582 s:  Input Statistics,
     [HOST] [IPU2  ]    358.608643 s:
     [HOST] [IPU2  ]    358.608674 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    358.608735 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    358.608826 s:  --------------------------------------------------
     [HOST] [IPU2  ]    358.608918 s:
     [HOST] [IPU2  ]    358.608948 s:  Output Statistics,
     [HOST] [IPU2  ]    358.609009 s:
     [HOST] [IPU2  ]    358.609040 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [IPU2  ]    358.609131 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [IPU2  ]    358.609223 s:  ---------------------------------------------
     [HOST] [IPU2  ]    358.609406 s:
     [HOST] [IPU2  ]    358.609467 s:  [ IPC_OUT_0 ] LATENCY,
     [HOST] [IPU2  ]    358.609497 s:  ********************
     [HOST] [IPU2  ]    358.609558 s:
     [HOST] [HOST  ]    358.610443 s:
     [HOST] [HOST  ]    358.610443 s:  [ IPC_IN_0 ] Link Statistics,
     [HOST] [HOST  ]    358.610443 s:  ******************************
     [HOST] [HOST  ]    358.610473 s:  Elapsed time       = 199053 msec
     [HOST] [HOST  ]    358.610473 s:  Input Statistics,
     [HOST] [HOST  ]    358.610473 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [HOST  ]    358.610473 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [HOST  ]    358.610504 s:  --------------------------------------------------
     [HOST] [HOST  ]    358.610504 s:  Output Statistics,
     [HOST] [HOST  ]    358.610504 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [HOST  ]    358.610534 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [HOST  ]    358.610534 s:  ---------------------------------------------
     [HOST] [HOST  ]    358.610534 s:  [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> HOST ] ,
     [HOST] [HOST  ]    358.610565 s:  ***************************************************************
     [HOST] [HOST  ]    358.610565 s:  IPC One-way Buffer Passing Latency   (usecs) : Avg =      0, Min =     -1, Max =      0
     [HOST] [HOST  ]    358.610565 s:  IPC One-way Notify Interrupt Latency (usecs) : Avg =      0, Min =     -1, Max =      0
    Please check attached patch zip file.
    You might need to port this patch  with your vsdk version
    Anuj6CAM_Patch.tar
    I copied the file to the corresponding folder, or no image output,
    I checked my file and found that only this file does not (0001-dra7xx-mux_data-Add-pinmux-iodelay-for-VIN4B), the rest of the files are Yes, and the settings are
    the same. I am using PROCESSOR_SDK_VISION_03_05_00_00_setuplinux.bin
    this is a separate patch file which needs to be applied for u-boot
    after applying board/ti/dra7xx/mux_data.h files will change.
    Anuj
    I added the file to the corresponding folder, compile and run, camera6 still has no output, camera1-5 output normally.
    Can you tell me which configuration needs to be changed to use the 6-way camera?
    The camera capture status is now as follows
    [HOST] [IPU2  ]    956.347282 s:  CAPTURE: VIP1 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    956.347373 s:  CAPTURE: VIP1 Slice1 PortA FRAME MODE
     [HOST] [IPU2  ]    956.347465 s:  CAPTURE: VIP2 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    956.347678 s:  CAPTURE: VIP3 Slice0 PortA FRAME MODE
     [HOST] [IPU2  ]    956.347739 s:  CAPTURE: VIP3 Slice1 PortA FRAME MODE
     [HOST] [IPU2  ]    956.347831 s:  CAPTURE: VIP2 Slice1 PortB FRAME MODE
     [HOST] [IPU2  ]    956.347922 s:
     [HOST] [IPU2  ]    956.347953 s:  [ CAPTURE ] Link Statistics,
     [HOST] [IPU2  ]    956.348014 s:  ******************************
     [HOST] [IPU2  ]    956.348105 s:
     [HOST] [IPU2  ]    956.348136 s:  Elapsed time       = 406830 msec
     [HOST] [IPU2  ]    956.348197 s:
     [HOST] [IPU2  ]    956.348258 s:  New data Recv      = 150.30 fps
     [HOST] [IPU2  ]    956.348502 s:  Get Full Buf Cb    = 149.13 fps
     [HOST] [IPU2  ]    956.348746 s:  Put Empty Buf Cb   = 149.13 fps
     [HOST] [IPU2  ]    956.348807 s:  Driver/Notify Cb   = 150.30 fps
     [HOST] [IPU2  ]    956.348898 s:
     [HOST] [IPU2  ]    956.348929 s:  Input Statistics,
     [HOST] [IPU2  ]    956.348990 s:
     [HOST] [IPU2  ]    956.349051 s:  CH | In Recv | In Drop | In User Drop | In Process
     [HOST] [IPU2  ]    956.349112 s:     | FPS     | FPS     | FPS          | FPS
     [HOST] [IPU2  ]    956.349203 s:  --------------------------------------------------
     [HOST] [IPU2  ]    956.349295 s:   0 |  30. 6      0. 0      0. 0          30. 6
     [HOST] [IPU2  ]    956.349447 s:   1 |  30. 5      0. 0      0. 0          30. 5
     [HOST] [IPU2  ]    956.349600 s:   2 |  30. 6      0. 0      0. 0          30. 6
     [HOST] [IPU2  ]    956.349752 s:   3 |  30. 6      0. 0      0. 0          30. 6
     [HOST] [IPU2  ]    956.349905 s:   4 |  30. 6      0. 0      0. 0          30. 6
     [HOST] [IPU2  ]    956.350027 s:
     [HOST] [IPU2  ]    956.350088 s:  Output Statistics,
     [HOST] [IPU2  ]    956.350118 s:
     [HOST] [IPU2  ]    956.350179 s:  CH | Out | Out     | Out Drop | Out User Drop
     [HOST] [IPU2  ]    956.350240 s:     | ID  | FPS     | FPS      | FPS
     [HOST] [IPU2  ]    956.350332 s:  ---------------------------------------------
     [HOST] [IPU2  ]    956.350423 s:   0 |  0     30. 6     0. 0      0. 0
     [HOST] [IPU2  ]    956.350545 s:   1 |  0     30. 6     0. 0      0. 0
     [HOST] [IPU2  ]    956.350698 s:   2 |  0     30. 6     0. 0      0. 0
     [HOST] [IPU2  ]    956.350820 s:   3 |  0     30. 5     0. 0      0. 0
     [HOST] [IPU2  ]    956.350942 s:   4 |  0     30. 5     0. 0      0. 0
     [HOST] [IPU2  ]    956.351125 s:
     [HOST] [IPU2  ]    956.351155 s:  [VIP1 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    956.351247 s:  ==============================
     [HOST] [IPU2  ]    956.351308 s:  Number of request queued  : 22617
     [HOST] [IPU2  ]    956.351369 s:  Number of request dequeued: 22616
     [HOST] [IPU2  ]    956.351460 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.351521 s:
     [HOST] [IPU2  ]    956.351552 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.351735 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.351888 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.352193 s:   00.0.00 |   22622   22616   22616   22616       0     30    30     0  1280/1280    720/720         0       0       0     0
     [HOST] [IPU2  ]    956.352345 s:
     [HOST] [IPU2  ]    956.352376 s:
     [HOST] [IPU2  ]    956.352437 s:  [VIP1 Slice1 PortA] Statistics
     [HOST] [IPU2  ]    956.352498 s:  ==============================
     [HOST] [IPU2  ]    956.352559 s:  Number of request queued  : 22616
     [HOST] [IPU2  ]    956.352650 s:  Number of request dequeued: 22616
     [HOST] [IPU2  ]    956.352742 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.352803 s:
     [HOST] [IPU2  ]    956.352925 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.353077 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.353199 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.353504 s:   02.0.00 |   22621   22616   22616   22616       0     30    30     0  1280/1280    720/720         0       0       0     0
     [HOST] [IPU2  ]    956.353779 s:
     [HOST] [IPU2  ]    956.353840 s:
     [HOST] [IPU2  ]    956.353901 s:  [VIP2 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    956.353962 s:  ==============================
     [HOST] [IPU2  ]    956.354023 s:  Number of request queued  : 22617
     [HOST] [IPU2  ]    956.354084 s:  Number of request dequeued: 22616
     [HOST] [IPU2  ]    956.354175 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.354236 s:
     [HOST] [IPU2  ]    956.354267 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.354419 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.354541 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.354877 s:   04.0.00 |   22622   22616   22616   22616       0     30    30     0  1280/1280    720/720         0       0       0     0
     [HOST] [IPU2  ]    956.354999 s:
     [HOST] [IPU2  ]    956.355060 s:
     [HOST] [IPU2  ]    956.355090 s:  [VIP3 Slice0 PortA] Statistics
     [HOST] [IPU2  ]    956.355151 s:  ==============================
     [HOST] [IPU2  ]    956.355212 s:  Number of request queued  : 22616
     [HOST] [IPU2  ]    956.355273 s:  Number of request dequeued: 22615
     [HOST] [IPU2  ]    956.355365 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.355426 s:
     [HOST] [IPU2  ]    956.355456 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.355609 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.355761 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.356036 s:   08.0.00 |   22621   22615   22616   22616       0     30    30     0  1280/1280    720/720         0       0       0     0
     [HOST] [IPU2  ]    956.356188 s:
     [HOST] [IPU2  ]    956.356219 s:
     [HOST] [IPU2  ]    956.356280 s:  [VIP3 Slice1 PortA] Statistics
     [HOST] [IPU2  ]    956.356341 s:  ==============================
     [HOST] [IPU2  ]    956.356402 s:  Number of request queued  : 22616
     [HOST] [IPU2  ]    956.356463 s:  Number of request dequeued: 22615
     [HOST] [IPU2  ]    956.356524 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.356615 s:
     [HOST] [IPU2  ]    956.356646 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.356798 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.356920 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.357225 s:   10.0.00 |   22621   22615   22616   22616       0     30    30     0  1280/1280    720/720         0       0       0     0
     [HOST] [IPU2  ]    956.357347 s:
     [HOST] [IPU2  ]    956.357408 s:
     [HOST] [IPU2  ]    956.357439 s:  [VIP2 Slice1 PortB] Statistics
     [HOST] [IPU2  ]    956.357500 s:  ==============================
     [HOST] [IPU2  ]    956.357561 s:  Number of request queued  : 1
     [HOST] [IPU2  ]    956.357652 s:  Number of request dequeued: 0
     [HOST] [IPU2  ]    956.357713 s:  Overflow Count            : 0
     [HOST] [IPU2  ]    956.357774 s:
     [HOST] [IPU2  ]    956.357835 s:     CH    |     Q      DQ     Total   Top     Bot    Total  Top    Bot   Min/Max     Min/Max   Dropped  Repeat   Fid   Desc
     [HOST] [IPU2  ]    956.357957 s:  (I/S/CH) |   Count   Count  Fields  Fields  Fields   FPS   FPS    FPS    Width       Height   Frames   Frames  Repeat Error
     [HOST] [IPU2  ]    956.358079 s:  ---------------------------------------------------------------------------------------------------------------------------
     [HOST] [IPU2  ]    956.358506 s:   07.0.00 |       6       0       0       0       0      0     0     0     0/0         0/0           0       0       0     0
     [HOST] [IPU2  ]    956.358659 s:
    File storage size is as follows
    -rw-r--r-- root     root     71565312 Jul 30, 2019 17:50 stream0.h264
    -rw-r--r-- root     root     75055104 Jul 30, 2019 17:50 stream1.h264
    -rw-r--r-- root     root     68288512 Jul 30, 2019 17:50 stream2.h264
    -rw-r--r-- root     root     75186176 Jul 30, 2019 17:50 stream3.h264
    -rw-r--r-- root     root     74903552 Jul 30, 2019 17:50 stream4.h264
    -rw-r--r-- root     root            0 Jul 30, 2019 17:48 stream5.h264
    First can you please check if VIP port you are trying to enable is the one where you have connected camera? Also please check if the pinmux for this sixth channel is enabled/set correctly?
    Rgds,
    Brijesh
