Part Number: TDA2E
Other Parts Discussed in Thread: TDA2
Hello
We are currently using the TDA2 SDK version number 03_07_00_00 (downloaded from TI PROCESSOR_SDK_RADAR_03_07_00_00.exe).
I have followed the steps mentioned in the VisionSDK_UserGuide_TDA2xx.pdf section 2 (system requirements). My compilation works on windows environment.
After doing the above step I try to compile the project tda2xx_cascade_bios_radar by using the following steps (i put this in one batch file)
1) Go to the folder C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build
2) Make a batch file compile.bat with following lines
set PATH=C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;%PATH%
set MAKEAPPNAME=apps
set MAKECONFIG=tda2xx_cascade_bios_radar
gmake -s -j8 depend >proto.txt
gmake -s -j8
After about half an hour later i get following warning message on my console
which i guess is not important and can be ignored for TDA2 Radar SDK compilation
"C:/PROCESSOR_SDK_RADAR_03_07_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! () "
The console logs detailing what is the error i am facing
C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build>Compile.bat
C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build>set PATH=C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\os_tools\windows\xdctools_3_32_01_22_core;C:\Anaconda2;C:\Anaconda2\Library\mingw-w64\bin;C:\Anaconda2\Library\usr\bin;C:\Anaconda2\Library\bin;C:\Anaconda2\Scripts;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Gemalto\Access Client\v5\;C:\Program Files (x86)\Gemalto\Access Client\v5\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Sennheiser\SoftphoneSDK\;C:\Program Files\MATLAB\R2018a\bin;C:\Program Files\Git\cmd;C:\Strawberry\c\bin;C:\Strawberry\perl\site\bin;C:\Strawberry\perl\bin;C:\Program Files\TortoiseGit\bin;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\dotnet\;C:\PROCESSOR_SDK_RADAR_03_07_00_00\ti_components\cg_tools\windows\gcc-arm-none-eabi-4_9-2015q3\bin;C:\Users\djoshi\AppData\Local\Microsoft\WindowsApps;C:\Users\djoshi\AppData\Local\Programs\Microsoft VS Code\bin;D:\Todo Backup\bin\x64\
C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build>set MAKEAPPNAME=apps
C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build>set MAKECONFIG=tda2xx_cascade_bios_radar
C:\PROCESSOR_SDK_RADAR_03_07_00_00\vision_sdk\build>gmake -s -j8 depend 1>proto.txt
/cygdrive/c/PROCESSOR_SDK_RADAR_03_07_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_07_00_00/vision_sdk/links_fw/include/config': File exists
/cygdrive/c/PROCESSOR_SDK_RADAR_03_07_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_07_00_00/vision_sdk/links_fw/include/config/apps': File exists
/cygdrive/c/PROCESSOR_SDK_RADAR_03_07_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_07_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_cascade_bios_radar': File exists
MAKEFILE.MK:33: warning: overriding commands for target `apps'
MAKEFILE.MK:33: warning: ignoring old commands for target `apps'
MAKEFILE.MK:56: warning: overriding commands for target `apps_eve1'
MAKEFILE.MK:56: warning: ignoring old commands for target `apps_eve1'
MAKEFILE.MK:67: warning: overriding commands for target `apps_eve2'
MAKEFILE.MK:67: warning: ignoring old commands for target `apps_eve2'
MAKEFILE.MK:78: warning: overriding commands for target `apps_eve3'
MAKEFILE.MK:78: warning: ignoring old commands for target `apps_eve3'
MAKEFILE.MK:89: warning: overriding commands for target `apps_eve4'
MAKEFILE.MK:89: warning: ignoring old commands for target `apps_eve4'
MAKEFILE.MK:105: warning: overriding commands for target `apps_ipu1_1'
MAKEFILE.MK:105: warning: ignoring old commands for target `apps_ipu1_1'
MAKEFILE.MK:116: warning: overriding commands for target `apps_dsp1'
MAKEFILE.MK:116: warning: ignoring old commands for target `apps_dsp1'
MAKEFILE.MK:151: warning: overriding commands for target `apps_ipu1_0'
MAKEFILE.MK:151: warning: ignoring old commands for target `apps_ipu1_0'
MAKEFILE.MK:168: warning: overriding commands for target `libs'
MAKEFILE.MK:168: warning: ignoring old commands for target `libs'
MAKEFILE.MK:171: warning: overriding commands for target `clean_files'
MAKEFILE.MK:171: warning: ignoring old commands for target `clean_files'
MAKEFILE.MK:184: warning: overriding commands for target `clean'
MAKEFILE.MK:184: warning: ignoring old commands for target `clean'
MAKEFILE.MK:267: warning: overriding commands for target `depend'
MAKEFILE.MK:267: warning: ignoring old commands for target `depend'
MAKEFILE.MK:274: warning: overriding commands for target `header'
MAKEFILE.MK:274: warning: ignoring old commands for target `header'
MAKEFILE.MK:279: warning: overriding commands for target `footer'
MAKEFILE.MK:279: warning: ignoring old commands for target `footer'
MAKEFILE.MK:285: warning: overriding commands for target `all'
MAKEFILE.MK:285: warning: ignoring old commands for target `all'
gmake[3]: *** No rule to make target `;'. Stop.
gmake[2]: *** [depend] Error 2
gmake[1]: *** [links_fw_depend] Error 2
gmake: *** [depend] Error 2
gmake[5]: *** No rule to make target `;'. Stop.
gmake[4]: *** [links_common_algorithm] Error 2
gmake[3]: *** [libs] Error 2
gmake[2]: *** [links_fw_libs] Error 2
gmake[1]: *** [apps] Error 2
gmake: *** [vision_sdk] Error 2
Also Attached is the logs of Proto.txt( Generated in this step (gmake -s -j8 depend >proto.txt)
Is it possibel can someone tell me whats happening here. I tried this step on various windows machine and everywhere i struck up in this step.
Br
Deepak Joshi
Proto.txt
