Other Parts Discussed in Thread: AM5718, SYSBIOS
I am using TMDXIDK5718 eval board. I want to create a project to manage/communicate all the available cores in AM5718(Run RTOS on A15, bare metal code on IPU1-C0, C1; IPU2-C0, C1; DSP). I wanted a reference project or procedure to implement this design and how IPC will be implemented?
As I am trying to use the TI-RTOS sdk, but I am faing errors in generating the example projects under the pdk folder. I am able to build the entire sdk and pdk directories but pdkProjectCreate.bat is failed(attached error file for ref).
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\ti\pdk_am57xx_1_0_15\packages>pdksetupenv.bat
Environment Configuration:
SDK_INSTALL_PATH : C:/ti
GMAKE_INSTALL_PATH : C:/ti/xdctools_3_51_01_18_core
RULES_MAKE : C:/ti/pdk_am57xx_1_0_15/packages/Rules.make
C:\ti\pdk_am57xx_1_0_15\packages>pdkProjectCreate.bat AM571x all
Configuration:
SOC : AM571x
BOARD : all
ENDIAN : little
MODULE : all
PROJECT_TYPE : all
PROCESSOR : arm
PDK_SHORT_NAME : C:\ti\PDK_AM~1\packages\
Checking Configuration...
Complete
PDK_PARTNO : AM571X
PDK_ECLIPSE_ID : com.ti.pdk.am57xx
RTSC_PLATFORM_NAME : ti.platforms.idkAM571X
RTSC_TARGET : gnu.targets.arm.A15F
CCS_DEVICE : "Cortex A.AM5728_RevA"
Detecting all projects in PDK and importing them in the workspace C:\ti\PDK_AM~1
\packages\\MyExampleProjects
Detected Test Project: EMAC_BasicExample_idkAM571x_armBiosExampleProject
The system cannot find the path specified.
Copying macro.ini
0 file(s) copied.
Detected Test Project: GPIO_LedBlink_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_BasicExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: I2C_BasicExample_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_BasicExample_idkAM571x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_BasicExample_idkAM571x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_SwitchExample_idkAM571x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: ICSS_EMAC_SwitchExample_idkAM571x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCASP_DeviceLoopback_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_FatfsConsole_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_FatfsConsole_idkAM571x_DMA_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM571x_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM571x_DMA_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM571x_EMMC_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MMCSD_idkAM571x_EMMC_DMA_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PCIE_idkAM571x_wSoCFile_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PCIE_idkAM571x_wSoCLib_armEdmaPktExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PCIE_idkAM571x_wSoCLib_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PRUSS_BasicExample_idkAM571x_wSoCFile_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: PRUSS_BasicExample_idkAM571x_wSoCLib_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_Loopback_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_SlaveMode_MasterExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_SlaveMode_SlaveExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: QSPI_BasicExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_Dma_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: MCSPI_BasicExample_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: QSPI_BasicExample_idkAM571x_armDmaTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: QSPI_BasicExample_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: UART_BasicExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: UART_BasicExample_idkAM571x_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: UART_BasicExample_idkAM571x_DMA_armTestproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: USB_DevBulk_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: USB_HostMsc_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: vps_loopbackExample_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: FATFS_Console_idkAM571x_armExampleProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: OSAL_BasicExample_idkAM571x_armTestProject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_BasicExample_idkAM571x_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_CCLinkMaster_idkAM571x_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_CCLinkSlave_idkAM571x_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_FtpExample_idkAM571x_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_ICSS_BasicExample_idkAM571x_wSoCLib_armExampleprojec
t
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_ICSS_CCLinkMaster_idkAM571x_wSoCLib_armExampleprojec
t
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_ICSS_CCLinkSlave_idkAM571x_wSoCLib_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: NIMU_ICSS_FtpExample_idkAM571x_wSocLib_armExampleproject
Copying macro.ini
0 file(s) copied.
Detected Test Project: timeSync_BasicExample_idkAM571x_wSocLib_armExampleproject
Copying macro.ini
0 file(s) copied.
No projects detected
Project generation complete
Naveen.
