AM4372: TPS65218D0 with RTC disabled
Genius 13655 points
Part Number: AM4372
Other Parts Discussed in Thread: TPS65218D0
Hello Champions,
Can TPS65218D0 be used to power AM4372 when disabling RTC?
Customer has read below appication note.
Powering the AM335x, AM437x, and AM438x with TPS65218 (Rev. B)
http://www.ti.com/lit/ug/slvuaa9b/slvuaa9b.pdf
But the document only describes how to use TPS65218D0 to power AM4372 when enabing RTC. He doesn't want to use RTC and found the TPS65218D0 power up sequence doesn't match the AM4372 power sequence requirement.
Below are the power sequence for AM4372 and TPS65218D0 for your reference.
AM437x ( not using RTC, only power IO 3.3V):DCDC4→LDO1→LS1→DCDC1)
TPS65218D0: LDO1→LS1→DCDC4→DCDC1
AM4372的Simplified Power Sequencing With RTC Feature Disabled, Dual-Voltage IOs Configured as 3.3 V.
TPS65218D0 power sequencing
Thanks.
Rgds
Shine
