Hi all,
I am Using VSDK 3.07
we need to develop a use-case in hlos.
I have changed the the default primary core to IPU1_0 and successfully execute the nullsrc-decode_display use case in hlos
I have created a custom link in IPU1 and Included in the usecase. as a standalone link.
now after running apps.out i am getting error XDC ASSERT please find the log.
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
 [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb6924000 of size 0x00100000
 [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa3d24000 of size 0x12c00000
 [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa3c64000 of size 0x00040000
 [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3ca4000 of size 0x00080000
 [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
 [HOST] OSA: IPU1-0 Remote Log Shared Memory @ 0xa0200000
 [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
 418.337729] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[ 418.377400] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[ HOST] [IPU1-0] 17.832916 s: ***** IPU1_0 Firmware build tie 20:04:45 Apr 23 2020
 [HOST] [IPU1-0] 17.833099 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
 [HOST] [IPU1-0] 17.835966 s: SYSTEM: System Common Init in progress !!!
 [HOST] [IPU1-0] 17.844994 s: UTILS: CIO: Init Done !!!
 [HOST] [IPU1-0] 17.845086 s: SYSTEM: IPC init in progress !!!
 [HOST] [IPU1-0] 17.845177 s: SYSTEM: Notify init done !!!
 [HOST] [IPU1-0] 17.846885 s: SYSTEM: MsgQ init done !!!
 [HOST] [IPU1-0] 17.847831 s: RpmsgInit in progress...
 [HOST] [IPU1-0] 17.847922 s: Connection established with HLOS, calling rpmsgInit
 [HOST] [IPU1-0] 17.848624 s: SYSTEM: IPC init DONE !!!
 [HOST] [IPU1-0] 17.855182 s: SYSTEM: System Common Init Done !!!
 [HOST] [IPU1-0] 17.855273 s: SYSTEM: System Init in progress !!!
 [HOST] [IPU1-0] 17.855395 s: SYSTEM: BSP Common Init in progress !!!
 [HOST] [IPU1-0] 17.855456 s: SYSTEM: BSP Common Init Done !!!
 [HOST] [IPU1-0] 17.855517 s: SYSTEM: BSP Platform Init in progress !!!
 [HOST] [IPU1-0] 17.855609 s: SYSTEM: BSP Platform Init Done !!!
 [HOST] [IPU1-0] 17.855670 s: SYSTEM: FVID2 Init in progress !!!
 [HOST] [IPU1-0] 17.855822 s: SYSTEM: FVID2 Init Done !!!
 [HOST] [IPU1-0] 17.855883 s: SYSTEM: VPS Init in progress !!!
 [HOST] [IPU1-0] 17.855944 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
 [HOST] [IPU1-0] 17.858689 s: *** VPDMA Firmware Loading... ***
 [HOST] [IPU1-0] 17.858811 s: VPDMA Firmware Address = 0xa035b5c0
 [HOST] [IPU1-0] 17.858903 s: VPDMA Load Address = 0x4897d004
 [HOST] [IPU1-0] 17.858994 s: VPDMA Firmware Version = 0x4d0001b8
 [HOST] [IPU1-0] 17.859086 s: VPDMA List Busy Status = 0x00000000
 [HOST] [IPU1-0] 17.859147 s: *** VPDMA Firmware Load Success ***
 [HOST] [IPU1-0] 17.859513 s: *** VPDMA Firmware Loading... ***
 [HOST] [IPU1-0] 17.859574 s: VPDMA Firmware Address = 0xa035b5c0
 [HOST] [IPU1-0] 17.859665 s: VPDMA Load Address = 0x4899d004
 [HOST] [IPU1-0] 17.859757 s: VPDMA Firmware Version = 0x4d0001b8
 [HOST] [IPU1-0] 17.859848 s: VPDMA List Busy Status = 0x00000000
 [HOST] [IPU1-0] 17.859940 s: *** VPDMA Firmware Load Success ***
 [HOST] [IPU1-0] 17.860245 s: *** VPDMA Firmware Loading... ***
 [HOST] [IPU1-0] 17.860336 s: VPDMA Firmware Address = 0xa035b5c0
 [HOST] [IPU1-0] 17.860428 s: VPDMA Load Address = 0x489dd004
 [HOST] [IPU1-0] 17.860519 s: VPDMA Firmware Version = 0x4d0001b8
 [HOST] [IPU1-0] 17.860611 s: VPDMA List Busy Status = 0x00000000
 [HOST] [IPU1-0] 17.860672 s: *** VPDMA Firmware Load Success ***
 [HOST] [IPU1-0] 17.928811 s: SYSTEM: VPS Init Done !!!
 [HOST] [IPU1-0] 17.929665 s: UTILS: DMA: HWI Create for INT34 !!!
 [HOST] [IPU1-0] 17.929909 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
 [HOST] [IPU1-0] 17.930031 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260640 B (254 KB)
 [HOST] [IPU1-0] 17.930183 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
 [HOST] [IPU1-0] 17.930366 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB)
 [HOST] [IPU1-0] 17.930549 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
 [HOST] [IPU1-0] 17.930702 s: SYSTEM: Initializing Links !!!
 [HOST] [IPU1-0] 18.234581 s:
 [HOST] [IPU1-0] ********************* CANLINK: link init************************
 [HOST] [IPU1-0] 18.234764 s:
 [HOST] [IPU1-0] ############################## CANLINK: Link Registered ########################
 [HOST] [IPU1-0] 18.238455 s: SYSTEM: Initializing Links ... DONE !!!
 [HOST] [IPU1-0] 18.239370 s: CHAINS: Application Started !!!
 [HOST] [IPU1-0] 18.253431 s: BOARD: Board Init in progress !!!
 [HOST] [IPU1-0] 18.253919 s: BOARD: Board Init Done !!!
 [HOST] [IPU1-0] 18.264259 s:
 [HOST] [HOST ] 428.376105 s: SYSTEM: System A15 Init in progress !!!
 [HOST] [HOST ] 428.376197 s: SYSTEM: IPC: Init in progress !!!
 [HOST] [HOST ] 428.376197 s: SYSTEM: IPC: Notify init in progress !!!
 [HOST] [HOST ] 428.377508 s: SYSTEM: IPC: [IPU1-0] socket bind success !!! (dst vproc = 0, endpt = 81)
 [HOST] [HOST ] 428.377539 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
 [HOST] [HOST ] 428.377600 s: SYSTEM: IPC: [IPU1-0] socket connect success !!! (dst vproc = 0, endpt = 80)
 [HOST] [HOST ] 428.377600 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
 [HOST] [HOST ] 428.377752 s: SYSTEM: IPC: Notify init DONE !!!
 [HOST] [HOST ] 428.377752 s: SYSTEM: MSGQ: MsgQ init in progress !!!
 [HOST] [HOST ] 428.377874 s: SYSTEM: MSGQ: MsgQ init DONE !!!
 [HOST] [HOST ] 428.377874 s: SYSTEM: IPC: Init DONE !!!
 [HOST] [HOST ] 428.377874 s: SYSTEM: Initializing A15 Links !!!
 [HOST] [HOST ] 428.377996 s: IPC_OUT_0 : Init done - linkid-0x2000000
 [HOST] [HOST ] 428.378149 s: IPC_OUT_1 : Init done - linkid-0x2000001
 [HOST] [HOST ] 428.378240 s: IPC_OUT_2 : Init done - linkid-0x2000002
 [HOST] [HOST ] 428.378332 s: IPC_OUT_3 : Init done - linkid-0x2000003
 [HOST] [HOST ] 428.378423 s: IPC_OUT_4 : Init done - linkid-0x2000004
 [HOST] [HOST ] 428.378606 s: IPC_IN_0 : Init done - linkid-0x200000a
 [HOST] [HOST ] 428.378728 s: IPC_IN_1 : Init done - linkid-0x200000b
 [HOST] [HOST ] 428.378850 s: IPC_IN_2 : Init done - linkid-0x200000c
 [HOST] [HOST ] 428.378972 s: IPC_IN_3 : Init done - linkid-0x200000d
 [HOST] [HOST ] 428.379186 s: IPC_IN_4 : Init done - linkid-0x200000e
 [HOST] [HOST ] 428.379338 s: IPC_IN_5 : Init done - linkid-0x200000f
 [HOST] [HOST ] 428.379430 s: IPC_IN_6 : Init done - linkid-0x2000010
 [HOST] [HOST ] 428.379552 s: NULL_0 : Init done - linkid-0x2000014
 [HOST] [HOST ] 428.379735 s: NULL_1 : Init done - linkid-0x2000015
 [HOST] [HOST ] 428.379918 s: NULL_SRC_0 : Init done - linkid-0x2000039
 [HOST] [HOST ] 428.380040 s: DISP_DIST_SRC_0 : Init done - linkid-0x2000062
 [HOST] [HOST ] 428.380162 s: DISP_DIST_SRC_1 : Init done - linkid-0x2000063
 [HOST] [HOST ] 428.380253 s: DISP_DIST_SRC_2 : Init done - linkid-0x2000064
 [HOST] [HOST ] 428.380345 s: DISP_DIST_SRC_3 : Init done - linkid-0x2000065
 [HOST] [HOST ] 428.380467 s: ALGORITHM_0 : Init done - linkid-0x2000031
 [HOST] [HOST ] 428.380589 s: ALGORITHM_1 : Init done - linkid-0x2000032
 [HOST] [HOST ] 428.380711 s: ALGORITHM_2 : Init done - linkid-0x2000033
 [HOST] [HOST ] 428.380833 s: ALGORITHM_3 : Init done - linkid-0x2000034
 [HOST] [HOST ] 428.380924 s: ALGORITHM_4 : Init done - linkid-0x2000035
 [HOST] [HOST ] 428.381046 s: ALGORITHM_5 : Init done - linkid-0x2000036
 [HOST] [HOST ] 428.381168 s: ALGORITHM_6 : Init done - linkid-0x2000037
 [HOST] [HOST ] 428.381260 s: ALGORITHM_7 : Init done - linkid-0x2000038
 [HOST] [HOST ] 428.381443 s: DUP0 : Init done - linkid-0x0
 [HOST] [HOST ] 428.381626 s: DUP1 : Init done - linkid-0x0
 [HOST] [HOST ] 428.381809 s: DUP2 : Init done - linkid-0x0
 [HOST] [HOST ] 428.381992 s: DUP3 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382144 s: DUP4 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382266 s: SYNC_0 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382388 s: SYNC_1 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382571 s: SYNC_2 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382724 s: SYNC_3 : Init done - linkid-0x0
 [HOST] [HOST ] 428.382937 s: MERGE_0 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383120 s: MERGE_1 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383273 s: MERGE_2 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383425 s: MERGE_3 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383578 s: MERGE_4 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383730 s: SELECT_0 : Init done - linkid-0x0
 [HOST] [HOST ] 428.383913 s: SELECT_1 : Init done - linkid-0x0
 [HOST] [HOST ] 428.384035 s: GATE_0 : Init done - linkid-0x0
 [HOST] [HOST ] 428.384188 s: GATE_1 : Init done - linkid-0x0
 [HOST] [HOST ] 428.384310 s: GATE_2 : Init done - linkid-0x0
 [HOST] [HOST ] 428.384462 s: GATE_3 : Init done - linkid-0x0
 [HOST] [HOST ] 428.384584 s: SGXFRMCPY_0 : Init done - linkid-0x200004a
 [HOST] [HOST ] 428.384615 s: SYSTEM: Initializing A15 Links ... DONE !!!
 [HOST] [HOST ] 428.385011 s: OSA: Adjusting global time, timeH by 0 units!!!
 [HOST] [HOST ] 428.385011 s: SYSTEM: System A15 Init Done !!!
 [HOST] [HOST ] 428.385194 s: NETWORK_CTRL: Starting Server (port=5000) !!!
 [HOST] [HOST ] 428.385255 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
 [HOST] [HOST ] 428.936924 s:
 [HOST] [HOST ]
 [HOST] [HOST ] ====================
 [HOST] [HOST ] Vision SDK Usecases
 [HOST] [HOST ] 1: Single Camera Usecases
 [HOST] [HOST ] 2: Multi-Camera LVDS Usecases
 [HOST] [HOST ] 3: Open-Compute Usecases
 [HOST] [HOST ] 5: ISS Usecases, (TDA2Px ONLY)
 [HOST] [HOST ] 6: Radar Usecases
 [HOST] [HOST ]
 [HOST] [HOST ] 7: PCIe SSD card Write Test
 [HOST] [HOST ] p: CPU Status
 [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
 [HOST] [HOST ]
 [HOST] [HOST ] s: System Settings
 [HOST] [HOST ]
 [HOST] [HOST ] x: Exit
 [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
 [HOST] [HOST ]
 [HOST] [HOST ] Enter Choice:
 [HOST] [HOST ]
1
 [HOST] [HOST ] 434.435795 s:
 [HOST] [HOST ]
 [HOST] [HOST ] Single Camera Usecases
 [HOST] [HOST ] ------------------------
 [HOST] [HOST ] 5: NullSrc + Decode + Display + CANLink
 [HOST] [HOST ]
 [HOST] [HOST ]
 [HOST] [HOST ]
 [HOST] [HOST ] 434.435826 s:
 [HOST] [HOST ] 434.435826 s: Unsupported option '
 [HOST] [HOST ] '. Please try again
 [HOST] [HOST ]
 [HOST] [HOST ]
 [HOST] [HOST ]
 [HOST] [HOST ]
5
 [HOST] [HOST ] 437.872476 s:
 [HOST] [HOST ] 437.872506 s:
 [HOST] [HOST ]
 [HOST] [HOST ] =========================================
 [HOST] [HOST ] Chains Run-time Codec Type Selection Menu
 [HOST] [HOST ]
 [HOST] [HOST ] Enter '0' for MJPEG
 [HOST] [HOST ]
 [HOST] [HOST ] Enter '1' for H.264
 [HOST] [HOST ]
 [HOST] [HOST ]
1
 [HOST] [IPU1-0] 440.954279 s: IPC_IN_0 : Create in progress !!!
 [HOST] [IPU1-0] 440.955468 s: IPC_IN_0 : Create Done !!!
 [HOST] [IPU1-0] 440.955895 s: DECODE: Create in progress ... !!!
 [HOST] [HOST ] 440.954065 s: IPC_OUT_0 : Create in progress !!!
 [HOST] [HOST ] 440.954126 s: IPC_OUT_0 : Create Done !!!
 [HOST] [IPU1-0] 441.161989 s: DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
 [HOST] [IPU1-0] 441.162965 s: DECODE: All CH Create ... DONE !!!
 [HOST] [IPU1-0] 441.165039 s: DECODE: Create ... DONE !!!
 [HOST] [IPU1-0] 441.165466 s: VPE: Create in progress !!!
[ 431.250108] omap_l3_noc 44000000.ocp: L3 application error: target 22 mod:1 (unclearable)
 [HOST] [IPU1-0] 441.296376 s: VPE: Loading Down-scaling Co-effs
 [HOST] [IPU1-0] 441.296620 s: VPE: Co-effs Loading ... DONE !!!
 [HOST] [IPU1-0] 441.296864 s: VPE: Create Done !!!
 [HOST] [IPU1-0] 441.297261 s: DISPLAY: Create in progress !!!
 [HOST] [IPU1-0] 441.297901 s: DISPLAY: Create Done !!!
 [HOST] [IPU1-0] 441.299945 s:
 [HOST] [IPU1-0] 441.300006 s: ### XDC ASSERT - ERROR CALLBACK START ###
 [HOST] [IPU1-0] 441.300067 s:
 [HOST] [IPU1-0] 441.300219 s: E_hardFault: FORCED
 [HOST] [IPU1-0] 441.300280 s:
 [HOST] [IPU1-0] 441.300311 s: ### XDC ASSERT - ERROR CALLBACK END ###
 [HOST] [IPU1-0] 441.300372 s:
 [HOST] [IPU1-0] 441.300585 s:
 [HOST] [IPU1-0] 441.300616 s: ### XDC ASSERT - ERROR CALLBACK START ###
 [HOST] [IPU1-0] 441.300707 s:
 [HOST] [IPU1-0] 441.300799 s: E_busFault: PRECISERR: Immediate Bus Fault, exact addr known, address: 62c01a58
 [HOST] [IPU1-0] 441.300921 s:
 [HOST] [IPU1-0] 441.300951 s: ### XDC ASSERT - ERROR CALLBACK END ###
 [HOST] [IPU1-0] 441.301012 s:
How to resolve the issue??
Nephil
