Part Number: TDA2PXEVM
I am trying to build a new image for TDA2px on a native on Ubuntu 18.04. And following step below:
1. git clone git://arago-project.org/git/projects/oe-layersetup.git
2. ./oe-layertool-setup.sh -f oe-layersetup/configs/processor-sdk/processor-sdk-06.02.00.81-config.txt
3. MACHINE=dra7xx-evm bitbake arago-base-tisdk-image
4. Than I got:
ERROR: arago-base-tisdk-image-1.0-r0 do_rootfs: Unable to install packages. Command '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/opkg.conf -t /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/temp/ipktemp/ -o /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs --force_postinstall install opkg packagegroup-arago-base packagegroup-arago-base-tisdk packagegroup-arago-console packagegroup-arago-test packagegroup-core-boot psplash run-postinsts systemd-initramfs' returned -6:
5. Than I execute:
/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/opkg.conf -t /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/temp/ipktemp/ -o /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs --force_postinstall install opkg packagegroup-arago-base packagegroup-arago-base-tisdk packagegroup-arago-console packagegroup-arago-test packagegroup-core-boot psplash run-postinsts systemd-initramfs Installing libc6 (2.28) on root Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/etc/ld.so.conf': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/ld-2.28.so': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/ld-linux-armhf.so.3': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/libBrokenLocale.so.1': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/libanl.so.1': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/libc.so.6': Can't set UID=0 ...... Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/etc/default/rng-tools': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/etc/udev/rules.d/rngd.rules': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/lib/systemd/system/rngd.service': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/usr/bin/rngtest': Can't set UID=0 Warning when extracting archive entry '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs/usr/sbin/rngd': Can't set UID=0 Installing input-utils (1.0) on root Segmentation fault
I attached error log file.
Thanks for your help!
DEBUG: Executing python function extend_recipe_sysroot NOTE: Direct dependencies are ['/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot', '/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', '/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.6.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-core/update-rc.d/update-rc.d_0.8.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-extended/xz/xz_5.2.4.bb:do_populate_sysroot', '/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', '/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-core/glibc/cross-localedef-native_2.28.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/opkg/opkg_0.3.6.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/ckt1010/oe-layersetup/sources/oe-core/meta/recipes-extended/pigz/pigz_2.4.bb:do_populate_sysroot'] NOTE: Installed into sysroot: [] NOTE: Skipping as already exists in sysroot: ['mklibs-native', 'prelink-native', 'depmodwrapper-cross', 'makedevs-native', 'ldconfig-native', 'opkg-utils-native', 'update-rc.d-native', 'xz-native', 'qemuwrapper-cross', 'cross-localedef-native', 'opkg-native', 'pseudo-native', 'pigz-native', 'systemd-systemctl-native', 'shadow-native', 'libtool-native', 'autoconf-native', 'automake-native', 'gnu-config-native', 'quilt-native', 'gettext-minimal-native', 'binutils-native', 'elfutils-native', 'kmod-native', 'nss-native', 'qemu-native', 'libarchive-native', 'libsolv-native', 'pkgconfig-native', 'openssl-native', 'debianutils-native', 'zlib-native', 'texinfo-dummy-native', 'm4-native', 'flex-native', 'gtk-doc-native', 'python3-native', 'nspr-native', 'sqlite3-native', 'alsa-lib-native', 'dtc-native', 'pixman-native', 'glib-2.0-native', 'bzip2-native', 'lzo-native', 'e2fsprogs-native', 'cmake-native', 'expat-native', 'ninja-native', 'rpm-native', 'gdbm-native', 'readline-native', 'util-macros-native', 'libpng-native', 'gettext-native', 'libffi-native', 'util-linux-native', 'libpcre-native', 'attr-native', 'curl-native', 're2c-native', 'popt-native', 'file-native', 'db-native', 'dbus-native', 'ncurses-native'] DEBUG: Python function extend_recipe_sysroot finished DEBUG: Executing python function do_rootfs NOTE: Initializing intercept dir for /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs DEBUG: Collected intercepts: /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/delay_to_first_boot /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/postinst_intercept /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_font_cache /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_gio_module_cache /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_gtk_immodules_cache /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_icon_cache /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_pixbuf_cache /home/ckt1010/oe-layersetup/sources/oe-core/scripts/postinst-intercepts/update_udev_hwdb NOTE: ###### Generate rootfs ####### NOTE: Executing '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg-make-index -r /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all/Packages -p /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all/Packages -m /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all' ... NOTE: Executing '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg-make-index -r /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/Packages -p /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/Packages -m /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm' ... NOTE: Executing '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg-make-index -r /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/Packages -p /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/Packages -m /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon' ... NOTE: Ignored bad recommendation: 'gdbserver-c6x-dev' is not a package NOTE: Ignored bad recommendation: 'libulm-dev' is not a package NOTE: Ignored bad recommendation: 'opencl-monitor-dev' is not a package NOTE: Ignored bad recommendation: 'ti-llvm3.6-dev' is not a package NOTE: Installing the following packages: opkg packagegroup-arago-base packagegroup-arago-base-tisdk packagegroup-arago-console packagegroup-arago-test packagegroup-core-boot psplash run-postinsts systemd-initramfs NOTE: /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/opkg.conf -t /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/temp/ipktemp/ -o /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs --force_postinstall install opkg packagegroup-arago-base packagegroup-arago-base-tisdk packagegroup-arago-console packagegroup-arago-test packagegroup-core-boot psplash run-postinsts systemd-initramfs ERROR: Unable to install packages. Command '/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/opkg.conf -t /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/temp/ipktemp/ -o /home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/rootfs --force_postinstall install opkg packagegroup-arago-base packagegroup-arago-base-tisdk packagegroup-arago-console packagegroup-arago-test packagegroup-core-boot psplash run-postinsts systemd-initramfs' returned -6: Installing libc6 (2.28) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libc6_2.28-r0_armv7at2hf-neon.ipk. Installing update-alternatives-opkg (0.3.6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/update-alternatives-opkg_0.3.6-r0_armv7at2hf-neon.ipk. Installing opkg-arch-config (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/opkg-arch-config_1.0-r1_dra7xx_evm.ipk. Installing arago-feed-config (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/arago-feed-config_1.0-r1_dra7xx_evm.ipk. Installing alsa-conf (1.1.6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/alsa-conf_1.1.6-r0_armv7at2hf-neon.ipk. Installing omapconf (1.74) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/omapconf_1.74-r0_armv7at2hf-neon.ipk. Installing cpuloadgen (0.93) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/cpuloadgen_0.93-r1_armv7at2hf-neon.ipk. Installing base-files (3.0.14) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/base-files_3.0.14-r89.arago4_dra7xx_evm.ipk. Installing base-passwd (3.5.29) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/base-passwd_3.5.29-r0_armv7at2hf-neon.ipk. Installing netbase (5.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/netbase_5.4-r0_armv7at2hf-neon.ipk. Installing update-rc.d (0.8) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all/update-rc.d_0.8-r0_all.ipk. Installing initscripts-functions (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/initscripts-functions_1.0-r155_armv7at2hf-neon.ipk. Installing pciutils-ids (3.6.2) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/pciutils-ids_3.6.2-r0_armv7at2hf-neon.ipk. Installing alsa-states (0.2.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/alsa-states_0.2.0-r5.arago0_armv7at2hf-neon.ipk. Installing fbset-modes (0.1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/fbset-modes_0.1.0-r6_dra7xx_evm.ipk. Installing ncurses-terminfo-base (6.1+20180630) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/ncurses-terminfo-base_6.1+20180630-r0_armv7at2hf-neon.ipk. Installing kselftests-seccomp (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-seccomp_4.10-r0_dra7xx_evm.ipk. Installing kselftests-ftrace (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-ftrace_4.10-r0_dra7xx_evm.ipk. Installing kselftests-lib (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-lib_4.10-r0_dra7xx_evm.ipk. Installing kselftests-pstore (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-pstore_4.10-r0_dra7xx_evm.ipk. Installing kselftests-size (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-size_4.10-r0_dra7xx_evm.ipk. Installing kselftests-user (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-user_4.10-r0_dra7xx_evm.ipk. Installing kselftests-static-keys (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-static-keys_4.10-r0_dra7xx_evm.ipk. Installing kselftests-sysctl (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-sysctl_4.10-r0_dra7xx_evm.ipk. Installing kselftests-firmware (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-firmware_4.10-r0_dra7xx_evm.ipk. Installing busybox-udhcpc (1.29.3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/busybox-udhcpc_1.29.3-r0.arago21.tisdk0_armv7at2hf-neon.ipk. Installing os-release (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all/os-release_1.0-r0_all.ipk. Installing volatile-binds (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/all/volatile-binds_1.0-r0_all.ipk. Installing systemd-conf (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/systemd-conf_1.0-r0_dra7xx_evm.ipk. Installing systemd-serialgetty (1.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/systemd-serialgetty_1.0-r5_dra7xx_evm.ipk. Installing shadow-securetty (4.6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/shadow-securetty_4.6-r3.arago0_dra7xx_evm.ipk. Installing openssl-conf (1.1.1b) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/openssl-conf_1.1.1b-r0_armv7at2hf-neon.ipk. Installing kbd-consolefonts (2.0.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/kbd-consolefonts_2.0.4-r0_armv7at2hf-neon.ipk. Installing kbd-keymaps (2.0.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/kbd-keymaps_2.0.4-r0_armv7at2hf-neon.ipk. Installing kernel-devicetree (4.19.79+git0+77dfab56c6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kernel-devicetree_4.19.79+git0+77dfab56c6-r7a.arago5.tisdk1.9_dra7xx_evm.ipk. Installing goodix-fw (1.0.0.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/goodix-fw_1.0.0.0-r0_dra7xx_evm.ipk. Installing vpdma-fw (03-2012) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/vpdma-fw_03-2012-r1_dra7xx_evm.ipk. Installing kernel-image-zimage-4.19.79-g77dfab56c6 (4.19.79+git0+77dfab56c6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kernel-image-zimage-4.19.79-g77dfab56c6_4.19.79+git0+77dfab56c6-r7a.arago5.tisdk1.9_dra7xx_evm.ipk. Installing kernel-image-uimage-4.19.79-g77dfab56c6 (4.19.79+git0+77dfab56c6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kernel-image-uimage-4.19.79-g77dfab56c6_4.19.79+git0+77dfab56c6-r7a.arago5.tisdk1.9_dra7xx_evm.ipk. Installing flex-libfl (2.6.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/flex-libfl_2.6.0-r0_armv7at2hf-neon.ipk. Installing libmnl0 (1.0.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libmnl0_1.0.4-r0_armv7at2hf-neon.ipk. Installing libpopt0 (1.16) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libpopt0_1.16-r3_armv7at2hf-neon.ipk. Installing libcap-ng0 (0.7.9) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libcap-ng0_0.7.9-r0_armv7at2hf-neon.ipk. Installing libogg0 (1.3.3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libogg0_1.3.3-r0_armv7at2hf-neon.ipk. Installing libltdl7 (2.4.6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libltdl7_2.4.6-r0_armv7at2hf-neon.ipk. Installing libspeexdsp1 (1.2rc3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libspeexdsp1_1.2rc3-r0_armv7at2hf-neon.ipk. Installing libpython2.7-1.0 (2.7.16) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libpython2.7-1.0_2.7.16-r1_armv7at2hf-neon.ipk. Installing libdaemon0 (0.14) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libdaemon0_0.14-r0_armv7at2hf-neon.ipk. Installing libattr1 (2.4.47) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libattr1_2.4.47-r0_armv7at2hf-neon.ipk. Installing libpam (1.3.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libpam_1.3.0-r5_armv7at2hf-neon.ipk. Installing serialcheck (1.0.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/serialcheck_1.0.0-r0_armv7at2hf-neon.ipk. Installing kselftests-memfd (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-memfd_4.10-r0_dra7xx_evm.ipk. Installing kselftests-sync (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-sync_4.10-r0_dra7xx_evm.ipk. Installing kselftests-ptp (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-ptp_4.10-r0_dra7xx_evm.ipk. Installing kselftests-mount (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-mount_4.10-r0_dra7xx_evm.ipk. Installing kselftests-nsfs (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-nsfs_4.10-r0_dra7xx_evm.ipk. Installing kselftests-bpf (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-bpf_4.10-r0_dra7xx_evm.ipk. Installing kselftests-ptrace (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-ptrace_4.10-r0_dra7xx_evm.ipk. Installing kselftests-sigaltstack (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-sigaltstack_4.10-r0_dra7xx_evm.ipk. Installing kselftests-kcmp (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-kcmp_4.10-r0_dra7xx_evm.ipk. Installing kselftests-membarrier (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-membarrier_4.10-r0_dra7xx_evm.ipk. Installing kselftests-timers (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-timers_4.10-r0_dra7xx_evm.ipk. Installing kselftests-exec (4.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/dra7xx_evm/kselftests-exec_4.10-r0_dra7xx_evm.ipk. Installing libperl5 (5.24.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libperl5_5.24.4-r0_armv7at2hf-neon.ipk. Installing libnl-3-200 (3.4.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libnl-3-200_3.4.0-r0.arago0_armv7at2hf-neon.ipk. Installing libaio1 (0.3.111) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libaio1_0.3.111-r0_armv7at2hf-neon.ipk. Installing libavahi-common3 (0.7) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libavahi-common3_0.7-r0_armv7at2hf-neon.ipk. Installing libe2p2 (1.44.3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libe2p2_1.44.3-r0_armv7at2hf-neon.ipk. Installing libcom-err2 (1.44.3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libcom-err2_1.44.3-r0_armv7at2hf-neon.ipk. Installing libturbojpeg0 (2.0.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libturbojpeg0_2.0.0-r0_armv7at2hf-neon.ipk. Installing libusb-1.0-0 (1.0.22) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libusb-1.0-0_1.0.22-r0_armv7at2hf-neon.ipk. Installing libsmartcols1 (2.32.1) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libsmartcols1_2.32.1-r0_armv7at2hf-neon.ipk. Installing libtirpc3 (1.0.3) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libtirpc3_1.0.3-r0_armv7at2hf-neon.ipk. Installing libcap2 (2.25) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libcap2_2.25-r0_armv7at2hf-neon.ipk. Installing libwrap0 (7.6) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libwrap0_7.6-r10_armv7at2hf-neon.ipk. Installing libgcc-s1 (8.3.0) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libgcc-s1_8.3.0-r0_armv7at2hf-neon.ipk. Installing libpcap1 (1.8.1) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libpcap1_1.8.1-r0_armv7at2hf-neon.ipk. Installing libuuid1 (2.32.1) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/libuuid1_2.32.1-r0_armv7at2hf-neon.ipk. Installing liblzo2-2 (2.10) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/arago-base-tisdk-image/1.0-r0/oe-rootfs-repo/armv7at2hf-neon/liblzo2-2_2.10-r0_armv7at2hf-neon.ipk. Installing liblzma5 (5.2.4) on root Downloading file:/home/ckt1010/oe-layersetup/build/arago-tmp-external-arm-toolchain/wocorrupted size vs. prev_size DEBUG: Python function do_rootfs finished ERROR: Function failed: do_rootfs
