66AK2G12: Need example projects for 66AK2G12? How to flash QSPI through UART terminal?
Part Number: 66AK2G12
Other Parts Discussed in Thread: OMAP-L138, OMAPL138, UNIFLASH
I need example projects for 66Ak2g12 SoC.
Secondly, how will I program QSPI flash using UART terminal. I have been using OMAPL-138 for more than 2 years.
The OMAPL-138 programming method is given below,
First compile the ARM and DSP projects.
Enter the entry addresses of ARM and DSP projects from their respective mak file into the bootloader project and compile that bootloader project.
Convert the bootloader project's .out file into .ais file using AISgen utility.
Convert the .out files of both ARM and DSP projects into a combined single .bin file using out2rprc.exe application.
Change the boot pins of OMAPl-138 to UART2 and program the NAND flash through sfh_OMAP-L138.exe utility by mentioning the location of .bin and .ais file and com port of UART terminal.
Will its programming method is same as OMAPL-138.
I am really confused about 66AK2g12 programming method.
Thanks.
