Part Number: TDA2PXEVM
Dear support team,
Version :PROCESSOR_SDK_VISION_03_07_00_00 --- BIOS --- WIN10;
I have a customer board the MCU is TDA2PX , The RGMII connected a switch(sja1105p) directly, as shown as below:
I did some modifications as per friendly person's advice in this forums. as shown as below :
1)Enable 'Dual MAC' via uncomment below 3 line in file config.bld("C:\PROCESSOR_SDK_VISION_03_07_00_00\ti_components\networking\nsp_gmacsw_4_16_01_01\packages\ti\nsp\drv") and rebuild NSP according to support document.
tiDspCommonCopts += " -DDUAL_MAC_MODE ";
tiArmCommonCopts += " -DDUAL_MAC_MODE ";
gccCommonCopts += " -DDUAL_MAC_MODE ";
2)Modifications in file "ndk_nsp_hooks.c"
add "pGMACSWConfig->macInitCfg[i].mdioModeFlags = MDIO_MODEFLG_NOPHY;"
and "pGMACSWConfig->macInitCfg[i].macConnectionType =MAC_CONNECTION_TYPE_RGMII_FORCE_100_FULL;"
in function "GMACSW_getConfig()";
3)Print some register info via uart , please find the file in attachment
4)Davinci config switch :
after above all modifications ,
Client CANOE send arp package to the static IP "192.168.1.100(static IP for TDA2PX)"
but can not get response from TDA , I can observed "GOOD_RX_FRAMES" was increasing but "GOOD_TX_FRAMES" kept zero:
[HOST ] 70.558348 s: network_ctrl_tsk.c line 281 GOOD_TX_FRAMES Reg: 0 HAHAHAHHAHAH
[HOST ] 70.558348 s: network_ctrl_tsk.c line 282 GOOD_RX_FRAMES Reg: 4F HAHAHAHHAHAH
I want to confirm are these sufficient for TDA2px to work as RGMII?
Is there any direction I should follow to find a solution to resolve this question?
I have uploaded the uart info in attachment.
Any reply is important for me .
Thank you very much.
Best regards.
Lan.
Copyright (c) [2012 - 2017] Texas Instruments Incorporated
All rights reserved not granted herein.
Limited License.
Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
license under copyrights and patents it now or hereafter owns or controls to
make, have made, use, import, offer to sell and sell ("Utilize") this software
subject to the terms herein. With respect to the foregoing patent license,
such license is granted solely to the extent that any such patent is necessary
to Utilize the software alone. The patent license shall not apply to any
combinations which include this software, other than combinations with devices
manufactured by or for TI ("TI Devices"). No hardware patent is licensed
hereunder.
Redistributions must preserve existing copyright notices and reproduce this
license (including the above copyright notice and the disclaimer and
(if applicable) source code license limitations below) in the documentation
and/or other materials provided with the distribution
Redistribution and use in binary form, without modification, are permitted
provided that the following conditions are met:
* No reverse engineering, decompilation, or disassembly of this software
is permitted with respect to any software provided in binary form.
* Any redistribution and use are licensed by TI for use only with TI Devices.
* Nothing shall obligate TI to provide you with source code for the software
licensed and provided to you in object code.
If software source code is provided to you, modification and redistribution of
the source code are permitted provided that the following conditions are met:
* Any redistribution and use of the source code, including any resulting
derivative works, are licensed by TI for use only with TI Devices.
* Any redistribution and use of any object code compiled from the source code
and any resulting derivative works, are licensed by TI for use only with TI
Devices.
Neither the name of Texas Instruments Incorporated nor the names of its
suppliers may be used to endorse or promote products derived from this software
without specific prior written permission.
DISCLAIMER.
THIS SOFTWARE IS PROVIDED BY TI AND TI�S LICENSORS "AS IS" AND ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL TI AND TI�S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \file networkCtrl_tsk.c
* INCLUDE FILES
#include "network_ctrl_priv.h"
#include <src/rtos/utils_common/include/utils_tsk.h>
#define NETWORK_CTRL_TSK_STACK_SIZE (16*KB)
#define NETWORK_CTRL_TSK_PRI (4)
* \brief Stack
#pragma DATA_ALIGN(gNetworkCtrl_tskStack, 32)
#pragma DATA_SECTION(gNetworkCtrl_tskStack, ".bss:taskStackSection")
UInt8 gNetworkCtrl_tskStack[NETWORK_CTRL_TSK_STACK_SIZE];
* \brief stores all module related information
NetworkCtrl_Obj gNetworkCtrl_obj;
Void NetworkCtrl_cmdHandlerUnsupportedCmd(char *cmd, UInt32 prmSize)
UInt8 *pBuf;
Int32 status;
/* alloc tmp buffer for parameters */
if(prmSize)
pBuf = Utils_memAlloc( UTILS_HEAPID_DDR_CACHED_SR, prmSize, 32);
UTILS_assert(pBuf != NULL);
/* read parameters */
NetworkCtrl_readParams(pBuf, prmSize);
Vps_printf(" NETWORK_CTRL: %s: UNSUPPORTED CMD (prmSize=%d) !!!\n", cmd, prmSize);
status = Utils_memFree( UTILS_HEAPID_DDR_CACHED_SR, pBuf, prmSize);
UTILS_assert(status==0);
/* send response */
NetworkCtrl_writeParams(NULL, 0, (UInt32)-1);
Int32 NetworkCtrl_registerHandler(char *cmd, NetworkCtrl_Handler handler)
NetworkCtrl_Obj *pObj = &gNetworkCtrl_obj;
int i;
int firstFreeIdx;
firstFreeIdx = -1;
/* check if command is already registered */
for(i=0; i<NETWORK_CTRL_MAX_CMDS; i++)
if(pObj->cmdHandler[i].handler)
if(strncmp(
pObj->cmdHandler[i].cmd,
cmd,
NETWORK_CTRL_CMD_STRLEN_MAX)
==0)
/* command already register, exit with error */
return -1;
else
if(firstFreeIdx==-1)
firstFreeIdx = i;
/* no space to register command */
return -1;
/* command not registered, register it */
pObj->cmdHandler[firstFreeIdx].handler = handler;
strcpy(pObj->cmdHandler[firstFreeIdx].cmd, cmd);
return 0;
Int32 NetworkCtrl_unregisterHandler(char *cmd)
int i;
if(strncmp(
cmd,
==0)
/* command found, unregister it */
pObj->cmdHandler[i].handler = NULL;
pObj->cmdHandler[i].cmd[0] = 0;
return 0;
Int32 NetworkCtrl_readParams(UInt8 *pPrm, UInt32 prmSize)
Int32 status = SYSTEM_LINK_STATUS_SOK;
if(prmSize)
status = Network_read(&pObj->sockObj, pPrm, &prmSize);
if(status<0)
Vps_printf(
" NETWORK_CTRL: Network_read() failed to read parameters (port=%d) !!!\n",
pObj->serverPort);
return status;
Int32 NetworkCtrl_writeParams(UInt8 *pPrm, UInt32 prmSize, UInt32 returnStatus)
Int32 status;
pObj->cmdBuf.prmSize = prmSize;
pObj->cmdBuf.returnValue = returnStatus;
pObj->cmdBuf.flags = NETWORK_CTRL_FLAG_ACK;
status = Network_write(&pObj->sockObj, (UInt8*)&pObj->cmdBuf, sizeof(pObj->cmdBuf));
if(status<0)
Vps_printf(
" NETWORK_CTRL: Network_write() failed to write response header (port=%d) !!!\n",
pObj->serverPort);
return status;
if(prmSize)
status = Network_write(&pObj->sockObj, pPrm, prmSize);
if(status<0)
Vps_printf(
" NETWORK_CTRL: Network_write() failed to write parameters (port=%d) !!!\n",
pObj->serverPort);
return status;
#define WR_MEM_32(addr,data) *(volatile unsigned int *)(addr) = (unsigned int)(data)
#define RD_MEM_32(addr) *(volatile unsigned int *)(addr)
Void NetworkCtrl_tskMain(UArg arg0, UArg arg1)
NetworkCtrl_Obj *pObj = (NetworkCtrl_Obj*)arg0;
Int32 status;
volatile UInt32 dataSize;
UInt32 MDIO_CtronlRegValueTemp = 0;
UInt32 CPSW_CONTROLRegValueTemp = 0;
UInt32 CTRL_CORE_SMA_SW_1RegValueTemp = 0;
Vps_printf(
" NETWORK_CTRL: Starting Server (port=%d) !!!\n", pObj->serverPort
Network_sessionOpen(NULL);
status = Network_open(&pObj->sockObj, pObj->serverPort);
Vps_printf(
" NETWORK_CTRL: Starting Server ... DONE (port=%d) !!!\n", pObj->serverPort
while(!gNetworkCtrl_obj.tskExit)
status = Network_waitConnect(&pObj->sockObj, 1000);
MDIO_CtronlRegValueTemp = RD_MEM_32(0x48485004);
Vps_printf("network_ctrl_tsk.c line 274 MDIO_Control Reg : %X HAHAHAHHAHAH",MDIO_CtronlRegValueTemp);//Lan
Vps_printf("network_ctrl_tsk.c line 275 CTRL_CORE_PAD_RGMII0_RXC Reg : %X HAHAHAHHAHAH",RD_MEM_32(0x4A003668));//Lan
Vps_printf("network_ctrl_tsk.c line 276 CTRL_CORE_PAD_RGMII0_TXC Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x4A003650));//Lan
Vps_printf("network_ctrl_tsk.c line 277 CONFIG_REG_2 IODelay Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x4844A014));//Lan
Vps_printf("network_ctrl_tsk.c line 278 RX_CRC_ERRORS Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484910));
Vps_printf("network_ctrl_tsk.c line 279 RX_DMA_OVERRUNS Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x4848498C));
Vps_printf("network_ctrl_tsk.c line 280 TX_UNDERRUN Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x4848495C));
Vps_printf("network_ctrl_tsk.c line 281 GOOD_TX_FRAMES Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484934));
Vps_printf("network_ctrl_tsk.c line 282 GOOD_RX_FRAMES Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484900));
Vps_printf("network_ctrl_tsk.c line 283 CPSW_SOFT_IDLE Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484014));
CTRL_CORE_SMA_SW_1RegValueTemp = RD_MEM_32(0x4A002534);
Vps_printf("network_ctrl_tsk.c line 285 CTRL_CORE_SMA_SW_1 Reg: %X HAHAHAHHAHAH",CTRL_CORE_SMA_SW_1RegValueTemp);
// if((CTRL_CORE_SMA_SW_1RegValueTemp & 0x06000000) == 0)
// CTRL_CORE_SMA_SW_1RegValueTemp |= 0x06000000;
// WR_MEM_32(0x4A002534,CTRL_CORE_SMA_SW_1RegValueTemp);//enable RGMII port1 and port2 Internal delay
/*CPSW_CONTROL*/
CPSW_CONTROLRegValueTemp = RD_MEM_32(0x48484004);
Vps_printf("network_ctrl_tsk.c line 294 CPSW_CONTROL Reg: %X HAHAHAHHAHAH",CPSW_CONTROLRegValueTemp);
// if((CPSW_CONTROLRegValueTemp & 0x01) == 0)
// CPSW_CONTROLRegValueTemp |= 0x01;//FIFO_LOOPBACK
// WR_MEM_32(0x48484004,CPSW_CONTROLRegValueTemp);
// if((MDIO_CtronlRegValueTemp & (UInt32)0x40000000) != 0)
// MDIO_CtronlRegValueTemp &= 0xBFFFFFFF;
// WR_MEM_32(0x48485004,0x40000000);
Vps_printf("network_ctrl_tsk.c line 305 ALE_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D08));
Vps_printf("network_ctrl_tsk.c line 306 CPSW_FLOW_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484024));
Vps_printf("network_ctrl_tsk.c line 307 CPDMA_TX_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484804));
Vps_printf("network_ctrl_tsk.c line 308 CPDMA_RX_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484814));
Vps_printf("network_ctrl_tsk.c line 309 CPDMA_DMASTATUS Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484824));
Vps_printf("network_ctrl_tsk.c line 310 ALE_PORTCTL0 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D40));
Vps_printf("network_ctrl_tsk.c line 311 ALE_PORTCTL1 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D44));
Vps_printf("network_ctrl_tsk.c line 312 ALE_PORTCTL2 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D48));
Vps_printf("network_ctrl_tsk.c line 313 ALE_PORTCTL3 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D4C));
Vps_printf("network_ctrl_tsk.c line 314 ALE_PORTCTL4 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D50));
Vps_printf("network_ctrl_tsk.c line 315 ALE_PORTCTL5 Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484D54));
Vps_printf("network_ctrl_tsk.c line 316 SL_MACCONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484DC4));
Vps_printf("network_ctrl_tsk.c line 317 SL_MACSTATUS Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484DC8));
Vps_printf("network_ctrl_tsk.c line 318 MDIO_ALIVE Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48485008));
Vps_printf("network_ctrl_tsk.c line 319 WR_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48485208));
Vps_printf("network_ctrl_tsk.c line 320 P0_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484100));
Vps_printf("network_ctrl_tsk.c line 321 P0_TX_IN_CTL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484110));
Vps_printf("network_ctrl_tsk.c line 322 P0_PORT_VLAN Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484114));
Vps_printf("network_ctrl_tsk.c line 323 P1_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484200));
Vps_printf("network_ctrl_tsk.c line 324 P1_TX_IN_CTL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484210));
Vps_printf("network_ctrl_tsk.c line 325 P1_PORT_VLAN Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484214));
Vps_printf("network_ctrl_tsk.c line 326 P2_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484300));
Vps_printf("network_ctrl_tsk.c line 327 P2_TX_IN_CTL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484310));
Vps_printf("network_ctrl_tsk.c line 328 P2_PORT_VLAN Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484314));
Vps_printf("network_ctrl_tsk.c line 329 WR_C0_TX_IMAX Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48485274));
Vps_printf("network_ctrl_tsk.c line 330 WR_RGMII_CTL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48485288));
Vps_printf("network_ctrl_tsk.c line 331 WR_STATUS Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x4848528C));
Vps_printf("network_ctrl_tsk.c line 332 CPTS_CONTROL Reg: %X HAHAHAHHAHAH",RD_MEM_32(0x48484C04));
UInt32 ALE_PORTCTL1L_RegTemp = RD_MEM_32(0x48484D44);
if((ALE_PORTCTL1L_RegTemp & 0x03) == 0)
ALE_PORTCTL1L_RegTemp |= 0x03;
WR_MEM_32(0x48484D44,ALE_PORTCTL1L_RegTemp);
// UInt32 ALE_PORTCTL2L_RegTemp = RD_MEM_32(0x48484D48);
// if((ALE_PORTCTL2L_RegTemp & 0x03) == 0)
// ALE_PORTCTL2L_RegTemp |= 0x03;
// WR_MEM_32(0x48484D48,ALE_PORTCTL2L_RegTemp);
if(status<0)
break;
if(status==0)
continue;
Vps_printf("network_ctrl_tsk.c line274 Connected successfulHAHAHAHAHAHHAHAHAHAH ");
dataSize = sizeof(pObj->cmdBuf);
/* read command header */
status = Network_read(&pObj->sockObj, (UInt8*)&pObj->cmdBuf, (UInt32*)&dataSize);
if(status==SYSTEM_LINK_STATUS_SOK && dataSize==sizeof(pObj->cmdBuf))
/* handle command */
if(pObj->cmdBuf.header != NETWORK_CTRL_HEADER)
Vps_printf(" NETWORK_CTRL: Invalid header received (port=%d) !!!\n", pObj->serverPort);
else
Bool isCmdHandled;
int i;
isCmdHandled = FALSE;
/* valid header received */
if(strncmp(
pObj->cmdBuf.cmd,
==0)
/* matched a register command */
Vps_printf(" NETWORK_CTRL: Received command [%s], with %d bytes of parameters\n",
pObj->cmdBuf.cmd,
pObj->cmdHandler[i].handler(
pObj->cmdBuf.cmd,
Vps_printf(" NETWORK_CTRL: Sent response for command [%s], with %d bytes of parameters\n",
pObj->cmdBuf.cmd,
isCmdHandled = TRUE;
break;
if(isCmdHandled == FALSE)
/* if command is not handled, then read the params and ACK it with error */
pObj->cmdBuf.cmd,
else
Vps_printf(" NETWORK_CTRL: recv() failed (port=%d) !!!\n", pObj->serverPort);
/* close socket */
Network_close(&pObj->sockObj, FALSE);
Vps_printf(
" NETWORK_CTRL: Closing Server (port=%d) !!!\n", pObj->serverPort
Network_close(&pObj->sockObj, TRUE);
Network_sessionClose(NULL);
Vps_printf(
" NETWORK_CTRL: Closing Server ... DONE (port=%d) !!!\n", pObj->serverPort
#ifdef ENABLE_NETWORK_LOG
Int32 NetworkCons_init();
Int32 NetworkCons_deInit();
#endif
Int32 NetworkCtrl_init()
memset(&gNetworkCtrl_obj, 0, sizeof(gNetworkCtrl_obj));
gNetworkCtrl_obj.serverPort = NETWORK_CTRL_SERVER_PORT;
NetworkCtrl_registerHandler("echo", NetworkCtrl_cmdHandlerEcho);
NetworkCtrl_registerHandler("mem_rd", NetworkCtrl_cmdHandlerMemRd);
NetworkCtrl_registerHandler("mem_wr", NetworkCtrl_cmdHandlerMemWr);
NetworkCtrl_registerHandler("mem_save", NetworkCtrl_cmdHandlerMemSave);
NetworkCtrl_registerHandler("qspi_wr", NetworkCtrl_cmdHandlerQspiWrite);
NetworkCtrl_registerHandler("mmc_wr_sbl", NetworkCtrl_cmdHandlerMmcsdWrite_proxy);
NetworkCtrl_registerHandler("mmc_wr_appimage", NetworkCtrl_cmdHandlerMmcsdWrite_proxy);
NetworkCtrl_registerHandler("sys_reset", NetworkCtrl_cmdHandlerSysReset);
NetworkCtrl_registerHandler("dev_ctrl", NetworkCtrl_cmdHandlerdevRequest);
#ifndef RADAR_ONLY
NetworkCtrl_registerHandler("iss_raw_save", NetworkCtrl_cmdHandlerIssRawSave);
NetworkCtrl_registerHandler("iss_yuv_save", NetworkCtrl_cmdHandlerIssYuvSave);
NetworkCtrl_registerHandler("iss_isp_save", NetworkCtrl_cmdHandlerIssIspSave);
NetworkCtrl_registerHandler("iss_send_dcc_file", NetworkCtrl_cmdHandlerIssDccSendFile);
NetworkCtrl_registerHandler("iss_save_dcc_file", NetworkCtrl_cmdHandlerIssSaveDccFile);
NetworkCtrl_registerHandler("iss_clear_dcc_qspi_mem", NetworkCtrl_cmdHandlerIssClearDccQspiMem);
NetworkCtrl_registerHandler("iss_write_sensor_reg", NetworkCtrl_cmdHandleIssWriteSensorReg);
NetworkCtrl_registerHandler("iss_read_sensor_reg", NetworkCtrl_cmdHandleIssReadSensorReg);
NetworkCtrl_registerHandler("iss_read_2a_params", NetworkCtrl_cmdHandleIssRead2AParams);
NetworkCtrl_registerHandler("iss_write_2a_params", NetworkCtrl_cmdHandleIssWrite2AParams);
NetworkCtrl_registerHandler("stereo_calib_image_save", NetworkCtrl_cmdHandlerStereoCalibImageSave);
NetworkCtrl_registerHandler("stereo_calib_lut_to_qspi", NetworkCtrl_cmdHandlerStereoWriteCalibLUTToQSPI);
NetworkCtrl_registerHandler("stereo_set_params", NetworkCtrl_cmdHandlerStereoSetParams);
NetworkCtrl_registerHandler("stereo_set_dynamic_params", NetworkCtrl_cmdHandlerStereoSetDynamicParams);
NetworkCtrl_registerHandler("object_detect_set_dynamic_params", NetworkCtrl_cmdHandlerObjectDetectSetDynamicParams);
#endif
* Create task
gNetworkCtrl_obj.task = BspOsal_taskCreate(
(BspOsal_TaskFuncPtr)NetworkCtrl_tskMain,
"Network Control",
NETWORK_CTRL_TSK_PRI,
sizeof(gNetworkCtrl_tskStack),
&gNetworkCtrl_obj,
UTILS_TSK_AFFINITY_CORE0
UTILS_assert(gNetworkCtrl_obj.task != NULL);
NetworkCons_init();
#endif
return SYSTEM_LINK_STATUS_SOK;
Int32 NetworkCtrl_deInit()
#endif
gNetworkCtrl_obj.tskExit = TRUE;
Task_sleep(1);
BspOsal_taskDelete(&gNetworkCtrl_obj.task);
NetworkCtrl_unregisterHandler("echo");
