Part Number: TDA4VM
How to Debug/view the contents of c6x trace buffer in CCS? In the absence of CCS
how to view the trace buffer from Linux side?
HI,
All the above are answered in the pdf:
tda4vm-c6x-trace-buffer-issue.pdf
Patch referenced in the Presentation:
From a1c31c0548037a191333b99ed1d79c4e25f76a6a Mon Sep 17 00:00:00 2001
Date: Sun, 9 Aug 2020 09:57:36 +0530
Subject: [PATCH] pdk: packages: ti: drv: ipc: examples: common: src:
ipc_utils: Cachewb the trace buffer upon a crash
Currently the c6x firmware trace buffer is not written back to DDR after a crash/exception.
This avoids A72/Linux viewing the crash dump. Fix this.
Signed-off-by: Angela Stegmaier <angelabaker@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
.../ti/drv/ipc/examples/common/j721e/ipc_override.cfg | 3 +++
packages/ti/drv/ipc/examples/common/src/ipc_utils.c | 8 ++++++++
packages/ti/drv/ipc/examples/common/src/ipc_utils.h | 1 +
3 files changed, 12 insertions(+)
diff --git a/packages/ti/drv/ipc/examples/common/j721e/ipc_override.cfg b/packages/ti/drv/ipc/examples/common/j721e/ipc_override.cfg
index 60b7e173..0974da04 100644
--- a/packages/ti/drv/ipc/examples/common/j721e/ipc_override.cfg
+++ b/packages/ti/drv/ipc/examples/common/j721e/ipc_override.cfg
@@ -68,6 +68,9 @@ if(coreId=="c66xdsp_1" || coreId=="c66xdsp_2")
/* TraceBuf Idle Function */
Idle.addFunc('&traceBuf_cacheWb');
+ var Exception = xdc.useModule('ti.sysbios.family.c64p.Exception');
+ Exception.exceptionHook = '&traceBuf_cacheWb_Exception';
/* Set ipc/VRing buffer as uncached */
diff --git a/packages/ti/drv/ipc/examples/common/src/ipc_utils.c b/packages/ti/drv/ipc/examples/common/src/ipc_utils.c
index 03d189ad..be4fc2c5 100644
--- a/packages/ti/drv/ipc/examples/common/src/ipc_utils.c
+++ b/packages/ti/drv/ipc/examples/common/src/ipc_utils.c
@@ -114,3 +114,11 @@ Void traceBuf_cacheWb()
+Void traceBuf_cacheWb_Exception()
+ uint8_t *traceBufAddr = 0;
+ traceBufAddr = Ipc_getResourceTraceBufPtr();
+ CacheP_wb((const void *)traceBufAddr, 0x80000);
diff --git a/packages/ti/drv/ipc/examples/common/src/ipc_utils.h b/packages/ti/drv/ipc/examples/common/src/ipc_utils.h
index 0d96062f..27d94f71 100644
--- a/packages/ti/drv/ipc/examples/common/src/ipc_utils.h
+++ b/packages/ti/drv/ipc/examples/common/src/ipc_utils.h
@@ -47,6 +47,7 @@ extern "C" {
void SetManualBreak();
void sysIdleLoop(void);
void traceBuf_cacheWb(void);
+Void traceBuf_cacheWb_Exception();
#ifdef __cplusplus
2.17.1
Crash.txt referenced in the pdf:
File: pdk_jacinto_07_00_00/packages/ti/drv/ipc/examples/common/src/ipc_testsetup.c
Function:Ipc_echo_test
int32_t Ipc_echo_test(void)
uint32_t t;
Task_Params params;
uint32_t numProc = gNumRemoteProc;
Ipc_VirtIoParams vqParam;
uint32_t index = 0;
void (*func)(void) = NULL; /* Declare a function pointer pointing to NULL */
func(); /* Call that to crash c6c */
Keerthy
