Part Number: AM6548
Customer reported with PSDK7 with PG2.0, there is ~20s latency when log in as root, there is not such issue on previous PSDK6.
there is not log information, just wait for ~20s to see response.
Part Number: AM6548
Hi Tony,
I will try to reproduce this but before i do that Just for my understanding when you 20S no response
that is after you get to root prompt? Typically Linux propmt takes about 15-20S. A boot log would be really
helpful to see what is happening.
Keerthy
U-Boot SPL 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 17:23:03 +0800)
SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.3():07.00.00.005-dirty
NOTICE: BL31: Built : 00:45:42, Jun 4 2020
U-Boot SPL 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 16:55:23 +0800)
U-Boot 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 16:55:23 +0800)
SoC: AM65X SR2.0
Model: Texas Instruments AM654 Base Board
DRAM: 1 GiB
MMC: sdhci@4f80000: 0, sdhci@04FA0000: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net:
Warning: cpsw_nuss@046000000 using MAC address from ROM
eth0: cpsw_nuss@046000000
Setting bus to 1
Press "zlg" to abort autoboot in 1 seconds
SoC: AM65X SR2.0
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net:
Setting bus to 1
U-Boot SPL 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 17:27:59 +0800)
U-Boot SPL 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 17:27:25 +0800)
U-Boot 2020.01-00008-g740c8b4980-dirty (Sep 03 2020 - 17:27:25 +0800)
SoC: AM65X SR2.0
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net:
Setting bus to 1
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Running zyboot ...
switch to partitions #1, OK
mmc0(part 1) is current device
MMC read: dev # 0, block # 8192, count 1024 ... 1024 blocks read: OK
MMC read: dev # 0, block # 9216, count 23552 ... 23552 blocks read: OK
SoC: AM65X SR2.0
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net:
Setting bus to 1
SoC: AM65X SR2.0
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net:
Setting bus to 1
Running zyboot ...
Uncompressed size: 14948360 = 0xE41808
4370 bytes read in 5 ms (853.5 KiB/s)
2324 bytes read in 5 ms (453.1 KiB/s)
1336 bytes read in 5 ms (260.7 KiB/s)
1738 bytes read in 5 ms (338.9 KiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Loading Device Tree to 00000000bdda8000, end 00000000bdebbfff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.40-g66cf445b76 (zwj@zwj-ubuntu) (gcc version 8. 3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) # 15 SMP PREEMPT Mon Aug 31 17:55:30 CST 2020
[ 0.000000] Machine model: Texas Instruments AM654 Base Board
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, s ize 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatibl e id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, s ize 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatibl e id shared-dma-pool
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 6864
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmi o32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi .u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs) r oot=PARTUUID=d45fd7be-02 rw rootfstype=ext4 rootwait mcu_version=2 board_version =2
[ 0.000000] Dentry cache hash table entries: 65536 (order: 3, 524288 bytes, l inear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 2, 262144 bytes, li near)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 970688K/440320K available (8126K kernel code, 774K rwdata , 3712K rodata, 1600K init, 699K bss, 18446744073709021248K reserved, 0K cma-res erved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 ji ffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @a2800000 (flat , esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000000bfcb0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000bfc0000 0
[ 0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x434 wit h crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000006] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 43980 46511102ns
[ 0.008713] Console: colour dummy device 80x25
[ 0.013326] Calibrating delay loop (skipped), value calculated using timer fr equency.. 400.00 BogoMIPS (lpj=200000)
[ 0.024050] pid_max: default: 32768 minimum: 301
[ 0.028925] LSM: Security Framework initializing
[ 0.033758] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, line ar)
[ 0.041372] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.057614] ASID allocator initialised with 32768 entries
[ 0.065211] rcu: Hierarchical SRCU implementation.
[ 0.072340] Platform MSI: gic-its@1820000 domain created
[ 0.078111] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-it s@1820000 domain created
[ 0.089643] smp: Bringing up secondary CPUs ...
[ 0.102938] Detected VIPT I-cache on CPU1
[ 0.102983] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.103000] GICv3: CPU1: using allocated LPI pending table @0x00000000bfc1000 0
[ 0.103052] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.111120] Detected VIPT I-cache on CPU2
[ 0.111168] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[ 0.111185] GICv3: CPU2: using allocated LPI pending table @0x00000000bfc2000 0
[ 0.111244] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
[ 0.120183] Detected VIPT I-cache on CPU3
[ 0.120220] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[ 0.120235] GICv3: CPU3: using allocated LPI pending table @0x00000000bfc3000 0
[ 0.120279] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
[ 0.120467] smp: Brought up 1 node, 4 CPUs
[ 0.200933] SMP: Total of 4 processors activated.
[ 0.205773] CPU features: detected: 32-bit EL0 Support
[ 0.211054] CPU features: detected: CRC32 instructions
[ 0.218019] CPU: All CPU(s) started at EL2
[ 0.222269] alternatives: patching kernel code
[ 0.228373] devtmpfs: initialized
[ 0.246793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 1911260446275000 ns
[ 0.256833] futex hash table entries: 1024 (order: 0, 65536 bytes, linear)
[ 0.264293] pinctrl core: initialized pinctrl subsystem
[ 0.270806] NET: Registered protocol family 16
[ 0.276147] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.283559] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.324249] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.331165] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.337985] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.349887] cryptd: max_cpu_qlen set to 1000
[ 0.367619] iommu: Default domain type: Translated
[ 0.373292] SCSI subsystem initialized
[ 0.377417] usbcore: registered new interface driver usbfs
[ 0.383114] usbcore: registered new interface driver hub
[ 0.388673] usbcore: registered new device driver usb
[ 0.394485] mc: Linux media interface: v0.10
[ 0.398921] videodev: Linux video capture interface: v2.00
[ 0.404593] pps_core: LinuxPPS API ver. 1 registered
[ 0.409699] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.419099] PTP clock support registered
[ 0.423163] EDAC MC: Ver: 3.0.0
[ 0.427967] FPGA manager framework
[ 0.431616] Advanced Linux Sound Architecture Driver Initialized.
[ 0.439120] clocksource: Switched to clocksource arch_sys_counter
[ 0.445649] VFS: Disk quotas dquot_6.6.0
[ 0.449837] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.466323] thermal_sys: Registered thermal governor 'step_wise'
[ 0.466328] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.473245] NET: Registered protocol family 2
[ 0.485103] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 6553 6 bytes, linear)
[ 0.494025] TCP established hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.502073] TCP bind hash table entries: 8192 (order: 1, 131072 bytes, linear )
[ 0.509642] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.516312] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.523327] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.530982] NET: Registered protocol family 1
[ 0.536308] RPC: Registered named UNIX socket transport module.
[ 0.542418] RPC: Registered udp transport module.
[ 0.547261] RPC: Registered tcp transport module.
[ 0.552111] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.558743] PCI: CLS 0 bytes, default 64
[ 0.564327] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 0.587438] Initialise system trusted keyrings
[ 0.592387] workingset: timestamp_bits=46 max_order=14 bucket_order=0
[ 0.608359] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.615342] NFS: Registering the id_resolver key type
[ 0.620585] Key type id_resolver registered
[ 0.624896] Key type id_legacy registered
[ 0.629036] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.636276] 9p: Installing v9fs 9p2000 file system support
[ 0.662444] Key type asymmetric registered
[ 0.666675] Asymmetric key parser 'x509' registered
[ 0.671746] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 44)
[ 0.679358] io scheduler mq-deadline registered
[ 0.684017] io scheduler kyber registered
[ 0.691690] pinctrl-single 4301c000.pinmux: 70 pins, size 280
[ 0.698405] pinctrl-single 11c000.pinmux: 185 pins, size 740
[ 0.704430] pinctrl-single 11c2e8.pinmux: 9 pins, size 36
[ 0.711605] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[ 0.727315] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.733733] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.745920] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.758513] panel-lvds display0: failed to request enable GPIO: -517
[ 0.782575] brd: module loaded
[ 0.797024] loop: module loaded
[ 0.805189] libphy: Fixed MDIO Bus: probed
[ 0.810192] tun: Universal TUN/TAP device driver, 1.6
[ 0.816324] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.824378] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.830530] sky2: driver version 1.30
[ 0.836020] VFIO - User Level meta-driver version: 0.3
[ 0.842166] i2c /dev entries driver
[ 0.847699] sdhci: Secure Digital Host Controller Interface driver
[ 0.854055] sdhci: Copyright(c) Pierre Ossman
[ 0.859293] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.866986] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.873299] ti-sci interconnect@100000:interconnect@28380000:interconnect@420 40000:dmsc: invalid resource
[ 0.883567] usbcore: registered new interface driver usbhid
[ 0.889303] usbhid: USB HID core driver
[ 0.894889] optee: probing for conduit method from DT.
[ 0.900219] optee: revision 3.8 (199fca17)
[ 0.901032] optee: initialized driver
[ 0.911305] NET: Registered protocol family 17
[ 0.916079] 9pnet: Installing 9P2000 support
[ 0.920550] Key type dns_resolver registered
[ 0.925498] registered taskstats version 1
[ 0.929725] Loading compiled-in X.509 certificates
[ 0.947696] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.954321] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.962651] panel-lvds display0: failed to request enable GPIO: -517
[ 0.975617] ti-sci interconnect@100000:interconnect@28380000:interconnect@420 40000:dmsc: invalid resource
[ 0.985690] ti-sci interconnect@100000:interconnect@28380000:interconnect@420 40000:dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[ 1.037177] random: fast init done
[ 1.056276] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.063184] ds2460 1-0040: byte_len looks suspicious (no power of 2)!
[ 1.069826] ds2460 1-0040: 18 byte ds2460 EEPROM (writable)
[ 1.075617] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.095281] rtc rtc0: Power loss detected, invalid time
[ 1.100834] rtc-pcf85063 2-0051: registered as rtc0
[ 1.105921] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.113049] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.119921] ti-sci-intr interconnect@100000:interconnect@28380000:interconnec t@42040000:interrupt-controller2: Interrupt Router 156 domain created
[ 1.133658] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 100 domain created
[ 1.143450] ti-sci-intr interconnect@100000:navss@30800000:interrupt-controll er1: Interrupt Router 182 domain created
[ 1.154707] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator d omain 179 created
[ 1.172484] keystone-pcie 5500000.pcie: host bridge /interconnect@100000/pcie @5500000 ranges:
[ 1.181299] keystone-pcie 5500000.pcie: IO 0x10020000..0x1002ffff -> 0x000 00000
[ 1.189125] keystone-pcie 5500000.pcie: MEM 0x10030000..0x17ffffff -> 0x100 30000
[ 2.197440] keystone-pcie 5500000.pcie: Phy link never came up
[ 2.203623] keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00
[ 2.210361] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.216012] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.222374] pci_bus 0000:00: root bus resource [mem 0x10030000-0x17ffffff]
[ 2.229477] pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400
[ 2.235695] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 2.242665] pci 0000:00:00.0: supports D1
[ 2.246794] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.260593] pci 0000:00:00.0: BAR 6: assigned [mem 0x10030000-0x1003ffff pref ]
[ 2.268031] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.273894] pcieport 0000:00:00.0: PME: Signaling with IRQ 42
[ 2.280273] pcieport 0000:00:00.0: AER: enabled with IRQ 42
[ 2.289356] keystone-pcie 5600000.pcie: host bridge /interconnect@100000/pcie @5600000 ranges:
[ 2.298167] keystone-pcie 5600000.pcie: IO 0x18020000..0x1802ffff -> 0x000 00000
[ 2.305975] keystone-pcie 5600000.pcie: MEM 0x18030000..0x1fffffff -> 0x180 30000
[ 2.413917] keystone-pcie 5600000.pcie: Link up
[ 2.418734] keystone-pcie 5600000.pcie: PCI host bridge to bus 0001:00
[ 2.425458] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 2.431117] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus add ress [0x0000-0xffff])
[ 2.440333] pci_bus 0001:00: root bus resource [mem 0x18030000-0x1fffffff]
[ 2.447430] pci 0001:00:00.0: [104c:b00c] type 01 class 0x060400
[ 2.453643] pci 0001:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 2.460610] pci 0001:00:00.0: supports D1
[ 2.464740] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 2.474880] pci 0001:01:00.0: [197b:0585] type 00 class 0x010601
[ 2.481181] pci 0001:01:00.0: reg 0x10: [io 0x10000-0x1007f]
[ 2.487131] pci 0001:01:00.0: reg 0x14: [io 0x10000-0x1007f]
[ 2.493067] pci 0001:01:00.0: reg 0x18: [io 0x10000-0x1007f]
[ 2.499002] pci 0001:01:00.0: reg 0x1c: [io 0x10000-0x1007f]
[ 2.504939] pci 0001:01:00.0: reg 0x20: [io 0x10000-0x1007f]
[ 2.510873] pci 0001:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[ 2.517346] pci 0001:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 2.524530] pci 0001:01:00.0: PME# supported from D3hot
[ 2.530057] pci 0001:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5 GT/s x1 link at 0001:00:00.0 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[ 2.548020] pci 0001:00:00.0: BAR 14: assigned [mem 0x18100000-0x181fffff]
[ 2.555095] pci 0001:00:00.0: BAR 15: assigned [mem 0x18200000-0x182fffff pre f]
[ 2.562614] pci 0001:00:00.0: BAR 6: assigned [mem 0x18030000-0x1803ffff pref ]
[ 2.570042] pci 0001:00:00.0: BAR 13: assigned [io 0x10000-0x10fff]
[ 2.576585] pci 0001:01:00.0: BAR 6: assigned [mem 0x18200000-0x1820ffff pref ]
[ 2.584014] pci 0001:01:00.0: BAR 5: assigned [mem 0x18100000-0x18101fff]
[ 2.591009] pci 0001:01:00.0: BAR 0: assigned [io 0x10000-0x1007f]
[ 2.597469] pci 0001:01:00.0: BAR 1: assigned [io 0x10080-0x100ff]
[ 2.603924] pci 0001:01:00.0: BAR 2: assigned [io 0x10100-0x1017f]
[ 2.610380] pci 0001:01:00.0: BAR 3: assigned [io 0x10180-0x101ff]
[ 2.616840] pci 0001:01:00.0: BAR 4: assigned [io 0x10200-0x1027f]
[ 2.623301] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 2.628678] pci 0001:00:00.0: bridge window [io 0x10000-0x10fff]
[ 2.635127] pci 0001:00:00.0: bridge window [mem 0x18100000-0x181fffff]
[ 2.642119] pci 0001:00:00.0: bridge window [mem 0x18200000-0x182fffff pref ]
[ 2.649972] pcieport 0001:00:00.0: PME: Signaling with IRQ 45
[ 2.656294] pcieport 0001:00:00.0: AER: enabled with IRQ 45
[ 2.670887] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, g p-rings[96,160] sci-dev-id:195
[ 2.680934] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 2.687738] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66348100, num_proxies: 64
[ 2.714408] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, g p-rings[304,464] sci-dev-id:187
[ 2.724546] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 2.731355] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66348100, num_proxies: 64
[ 2.739642] omap8250 42300000.serial: PM domain pd:150 will not be powered of f
[ 2.747556] 42300000.serial: ttyS0 at MMIO 0x42300000 (irq = 7, base_baud = 6 000000) is a 8250
[ 2.757101] pinctrl-single 4301c000.pinmux: pin PIN17 already requested by 56 00000.pcie; cannot claim for 40a00000.serial
[ 2.768403] pinctrl-single 4301c000.pinmux: pin-17 (40a00000.serial) status - 22
[ 2.775926] pinctrl-single 4301c000.pinmux: could not request pin 17 (PIN17) from group mcu-uart0-pins-default on device pinctrl-single
[ 2.788529] omap8250 40a00000.serial: Error applying setting, reverse things back
[ 2.796243] omap8250: probe of 40a00000.serial failed with error -22
[ 2.803877] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 30 00000) is a 8250
[ 2.812699] printk: console [ttyS2] enabled
[ 2.821173] printk: bootconsole [ns16550a0] disabled
[ 2.832331] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 22, base_baud = 30 00000) is a 8250
[ 2.841913] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 23, base_baud = 30 00000) is a 8250
[ 2.851073] panel-lvds display0: failed to request enable GPIO: -517
[ 2.902165] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1 000000
[ 2.909845] libphy: 46000f00.mdio: probed
[ 2.915408] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driv er TI DP83867
[ 2.923735] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss ver sion 0x6BA00102, cpsw version 0x6BA80102 Ports: 2
[ 2.935251] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channe l -517
[ 2.945369] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add _val:4 pps:0
[ 2.955277] mmc0: CQHCI version 5.10
[ 2.990231] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADM A 64-bit
[ 2.999083] mmc1: CQHCI version 5.10
[ 3.034127] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADM A 64-bit
[ 3.057961] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 3.065084] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 3.076529] mmc0: new HS200 MMC card at address 0001
[ 3.082567] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 3.087539] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 3.094642] ti-udma 285c0000.dma-controller: Channels: 96 (tchan: 48, rchan: 48, gp-rflow: 48)
[ 3.103720] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 3.117521] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB, chardev (240:0 )
[ 3.137603] ti-udma 31150000.dma-controller: Channels: 267 (tchan: 119, rchan : 148, gp-rflow: 150)
[ 3.146642] mmcblk0: p1 p2
[ 3.174724] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.181368] [drm] No driver support for vblank timestamp query.
[ 3.190508] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 4.245669] mmc1: new high speed SDHC card at address 0002
[ 4.246631] mmcblk1: mmc1:0002 N/A 3.83 GiB
[ 4.251567] mmcblk1: p1
[ 37.624604] Console: switching to colour frame buffer device 100x30
[ 37.661432] tidss 4a00000.dss: fb0: tidssdrmfb frame buffer device
[ 37.703152] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 37.710826] libphy: 46000f00.mdio: probed
[ 37.716555] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 37.724887] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2
[ 37.737757] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 37.746028] pps pps0: new PPS source ptp1
[ 37.750521] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:1
[ 37.759502] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[ 37.766817] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 37.776866] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
[ 37.784293] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
[ 37.822690] rtc rtc0: Power loss detected, invalid time
[ 37.827941] rtc-pcf85063 2-0051: hctosys: unable to read the hardware clock
[ 37.849588] ALSA device list:
[ 37.852580] No soundcards found.
[ 38.182650] EXT4-fs (mmcblk0p2): recovery complete
[ 38.188253] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 38.196466] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 38.203328] devtmpfs: mounted
[ 38.207108] Freeing unused kernel memory: 1600K
[ 38.211764] Run /sbin/init as init process
[ 38.308762] systemd[1]: System time before build time, advancing clock.
[ 38.354899] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 38.377347] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.05!
[ 38.428727] systemd[1]: Set hostname to <am65xx-evm>.
[ 38.742631] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 38.751626] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 38.914539] random: systemd: uninitialized urandom read (16 bytes read)
[ 38.921487] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 38.933849] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 38.946776] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 38.960401] random: systemd: uninitialized urandom read (16 bytes read)
[ 38.968697] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 38.982320] random: systemd: uninitialized urandom read (16 bytes read)
[ 38.990328] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 39.003657] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password ��ts to Console Directory Watch.
[ 39.021547] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R��uests to Wall Directory Watch.
[ 39.039468] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 39.051312] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 39.064275] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 39.076298] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 39.092866] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 39.107341] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 39.126573] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 39.140651] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 39.163884] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 39.172954] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 39.186949] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 39.200080] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 39.214796] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 39.227618] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 39.247295] systemd[1]: Mounting Huge Pages File System...
[ 39.267088] systemd[1]: Mounting POSIX Message Queue File System...
[ 39.289183] systemd[1]: Mounting Kernel Debug File System...
[ 39.310197] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 39.324731] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 39.342750] systemd[1]: Starting Start psplash boot splash screen...
[ 39.366445] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 39.397036] systemd[1]: Starting RPC Bind...
[ 39.408596] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 39.427666] systemd[1]: Starting Journal Service...
[ 39.450220] systemd[1]: Starting Load Kernel Modules...
[ 39.483413] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 39.516429] systemd[1]: Starting udev Coldplug all Devices...
[ 39.535827] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 39.555298] systemd[1]: Started Start psplash boot splash screen.
[ OK ] Started Start psplash boot splash screen.
[ 39.586921] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 39.604439] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 39.620061] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 39.637225] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 39.655021] systemd[1]: Mounted Temporary Directory (/tmp).
[ OK ] Mounted Temporary Directory (/tmp).
[ 39.669021] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 39.681925] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
[ 39.695363] systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ 39.723166] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
[ OK ] Started Start psplash-syst��progress communication helper.
Starting Flush Journal to Persistent Storage...
[ 39.840643] systemd-journald[240]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Reboot and dump vmcore via kexec...
Starting rc.pvr.service...
[FAILED] Failed to start Login Service.
See 'systemctl status systemd-logind.service' for details.
[ OK ] Started TEE Supplicant.
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started rc.pvr.service.
[ OK ] Reached target Network (Pre).
[ OK ] Stopped Login Service.
Starting Network Service...
Starting weston.service...
[ 41.475250] random: crng init done
[ 41.478727] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
[FAILED] Failed to start Network Name Resolution.
See 'systemctl status systemd-resolved.service' for details.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Permit User Sessions.
[ OK ] Created slice system-weston.slice.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Stopped Network Name Resolution.
[ OK ] Started Weston Wayland Compositor.
[ OK ] Started Synchronize System and HW clocks.
[ 42.973198] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 42.988806] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
NOTICE: This file system contains the following GPLv3 packages:
bash-dev
bash
bc
binutils
cifs-utils
cpio
dosfstools
elfutils
gawk
gdbserver
glmark2
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgmp10
libidn2-0
libreadline-dev
libreadline8
libunistring2
m4-dev
m4
nettle
parted
pdm-anomaly-detection
tar
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Started weston.service.
Starting Matrix GUI...
Starting telnetd.service...
[ OK ] Started Matrix GUI.
[ OK ] Started telnetd.service.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen ��of backlight:lvds-backlight...
[ OK ] Started Load/Save Screen B��s of backlight:lvds-backlight.
[ OK ] Created slice system-systemd\x2dcoredump.slice.
[FAILED] Failed to start Process Core Dump (PID 779/UID 0).
See 'systemctl status systemd-coredump@0-779-0.service' for details.
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1...
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Started File System Check on /dev/mmcblk0p1.
Mounting /run/media/mmcblk0p1...
[ OK ] Mounted /run/media/mmcblk0p1.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am65xx-evm ttyS2
Arago 2020.05 am65xx-evm ttyS2
am65xx-evm login: root
root@am65xx-evm:~#
attach the log, it stuck on the last two line, after input root, waiting for ~20s to prompt the last line.
root@am65xx-evm:~#
and another issue of stuck on DSS initialization for ~33s i post here:
https://e2e.ti.com/support/processors/f/791/t/936129
Dave Bell said:This is independent of the eMMC issue reported in the separate post, correct?
Do you mean eMMC reboot issue? no relate to it. this is another issue.
Dave Bell said:with DSS disabled you are seeing the same?
DSS issue is during dss initialization, this is during log in. and if boot from SD card with the same file system and kernel, no issue, so I think it is not related to DSS.
Hi Tony,
When you say emmc boot, are you booting u-boot, kernel and rootfs from emmc?
Please share the instructions to reproduce the setup/issue at our end.
Thanks & Regards,
Sunita.
