DRA726: Boot timing issue
Part Number: DRA726
How do I get rid of the "start job" parts? It looks like it is trying to connect a network on the USB device which is unacceptable since we only support USB-2 flash devices
Those increase the time it takes to  boot.
[***   ] (1 of 3) A start job is running for… mDNS/DNS-SD Stack (6s / 1min 28s)[   18.595026] dwc3 48890000.usb: Failed to get clk 'ref': -2
[   18.702099] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   18.769824] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   18.858875] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ ***  ] (2 of 3) A start job is running for Login Service (14s / 1min 35s)[   18.938028] xhci-hcd xhci-hcd.0.auto: irq 178, io mem 0x48890000
[   18.982067] hub 1-0:1.0: USB hub found
[   19.016856] hub 1-0:1.0: 1 port detected
[   19.045369] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   19.075047] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   19.105623] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   19.131858] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   19.191440] hub 2-0:1.0: USB hub found
[   19.212015] hub 2-0:1.0: 1 port detected
[   19.229414] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[  *** ] (2 of 3) A start job is running for Login Service (14s / 1min 35s)[   19.255837] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   19.291791] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[   19.345733] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[   19.402173] xhci-hcd xhci-hcd.1.auto: irq 179, io mem 0x488d0000
[   19.424917] hub 3-0:1.0: USB hub found
[   19.445557] hub 3-0:1.0: 1 port detected
[   19.462616] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   19.485798] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[   19.514023] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   19.539854] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   19.596304] hub 4-0:1.0: USB hub found
[   19.612848] hub 4-0:1.0: 1 port detected
Also what needs to be done to remove some unwanted  error messages like those :
The supply for the mmc and micro SD card is hardwired to 3.3V
[    3.231581] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.9
[    3.238452] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_3_3v mode
[    3.271316] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    3.279013] sdhci-omap 480ad000.mmc: 480ad000.mmc supply vqmmc not found, using dummy regulator
[    3.287873] sdhci-omap 480ad000.mmc: Linked as a consumer to regulator.0
[    3.294703] sdhci-omap 480ad000.mmc: Dropping the link to regulator.0
[    3.301295] sdhci-omap 480ad000.mmc: Linked as a consumer to regulator.2
[    3.308149] sdhci-omap 480ad000.mmc: no pinctrl state for sdr104 mode
[    3.314842] sdhci-omap 480ad000.mmc: no pinctrl state for ddr50 mode
[    3.321378] sdhci-omap 480ad000.mmc: no pinctrl state for sdr50 mode
[    3.327919] sdhci-omap 480ad000.mmc: no pinctrl state for sdr25 mode
[    3.334470] sdhci-omap 480ad000.mmc: no pinctrl state for sdr12 mode
[    3.340976] sdhci-omap 480ad000.mmc: no pinctrl state for hs mode
[    3.347232] sdhci-omap 480ad000.mmc: no pinctrl state for hs mode
[    3.353506] sdhci-omap 480ad000.mmc: no pinctrl state for hs200_1_8v mode
[    3.367064] mmc0: host does not support reading read-only switch, assuming write-enable
My yocto is based on Automotive SDK 6 but using poky instead of arago
I use the arago recipes that I need. The reason for using poky is that we intend to move to Automotive Grade Linux at some point in time and poky is what is used.
Michel Catudal
ACTIA Corp
