Hi, Dear Sir
We designed a board with TI AM4376 + RSZ9031RNX, but we faced a LAN problem repeatedly (Phenomenon: LAN port will be Link UP/Down after using a while and it seems only happened with Giga LAN)
during our testing we found if we added a 100M LAN HUB with the board, this problem will not occur....
So, we would like to use another way to solve the issue, is anybody know how to change the kernel setting based on this structure? Do I need other tools to change the setting?
We're using Linux version 4.9.69 and here is the mill dump information as below:
(We would like to know how to disable A/N and setting the speed to 100Mbps in Kernel code, thanks!!)
=> mii dump 4
0. (1140) -- PHY control register --
(8000:0000) 0.15 = 0 reset
(4000:0000) 0.14 = 0 loopback
(2040:0040) 0. 6,13 = b10 speed selection = 1000 Mbps
(1000:1000) 0.12 = 1 A/N enable
(0800:0000) 0.11 = 0 power-down
(0400:0000) 0.10 = 0 isolate
(0200:0000) 0. 9 = 0 restart A/N
(0100:0100) 0. 8 = 1 duplex = full
(0080:0000) 0. 7 = 0 collision test enable
(003f:0000) 0. 5- 0 = 0 (reserved)
=> mii dump 5
