Other Parts Discussed in Thread: DRA829
We are working on DRA829 using psdk_rtos_auto_j7_06_02_00_21 and we are testing CAN_Profile app present in "psdk_rtos_auto_j7_06_02_00_21/mcusw/mcuss_demos/profiling/can/can_profile.c"
I modified can_profile app as attached -- >
/* * * Copyright (c) 2019-2020 Texas Instruments Incorporated * * All rights reserved not granted herein. * * Limited License. * * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive * license under copyrights and patents it now or hereafter owns or controls to make, * have made, use, import, offer to sell and sell ("Utilize") this software subject to the * terms herein. With respect to the foregoing patent license, such license is granted * solely to the extent that any such patent is necessary to Utilize the software alone. * The patent license shall not apply to any combinations which include this software, * other than combinations with devices manufactured by or for TI ("TI Devices"). * No hardware patent is licensed hereunder. * * Redistributions must preserve existing copyright notices and reproduce this license * (including the above copyright notice and the disclaimer and (if applicable) source * code license limitations below) in the documentation and/or other materials provided * with the distribution * * Redistribution and use in binary form, without modification, are permitted provided * that the following conditions are met: * * * No reverse engineering, decompilation, or disassembly of this software is * permitted with respect to any software provided in binary form. * * * any redistribution and use are licensed by TI for use only with TI Devices. * * * Nothing shall obligate TI to provide you with source code for the software * licensed and provided to you in object code. * * If software source code is provided to you, modification and redistribution of the * source code are permitted provided that the following conditions are met: * * * any redistribution and use of the source code, including any resulting derivative * works, are licensed by TI for use only with TI Devices. * * * any redistribution and use of any object code compiled from the source code * and any resulting derivative works, are licensed by TI for use only with TI Devices. * * Neither the name of Texas Instruments Incorporated nor the names of its suppliers * * may be used to endorse or promote products derived from this software without * specific prior written permission. * * DISCLAIMER. * * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED * OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * \file can_profile.c * * \brief This file implements CAN profiling application */ /* ========================================================================== */ /* Include Files */ /* ========================================================================== */ #include "Std_Types.h" #include "Det.h" #include "Dem.h" #include "Os.h" #include "Can.h" #include "CanIf_Cbk.h" #include "EcuM_Cbk.h" #include "Dio.h" #include <ti/csl/arch/csl_arch.h> #include <ti/csl/soc.h> #include <ti/csl/cslr.h> #include "can_profile.h" /* ========================================================================== */ /* Macros & Typedefs */ /* ========================================================================== */ #define CAN_APP_E_DEM (E_NOT_OK + 1U) /**< Error code to indicate DEM */ #define CAN_APP_E_DET (E_NOT_OK + 2U) /**< Error code to indicate DEM */ /** \brief Message that would be displayed */ #if (CAN_LOOPBACK_ENABLE == STD_ON) #define CAN_TX_RX_MSG "Transmit & Receive " #else #if (CAN_TX_ONLY_MODE == STD_ON) #define CAN_TX_RX_MSG "Transmit " #else #define CAN_TX_RX_MSG "Receive " #endif #endif /* ========================================================================== */ /* Internal Function Declarations */ /* ========================================================================== */ uint64_t CanProfileGetTimeSpent(uint64_t preTs, uint64_t postTs); /* ========================================================================== */ /* Global Variables */ /* ========================================================================== */ uint32 CanApp_ProfileStatus = E_OK; /**< Variable used for Demo status */ Can_PduType CanApp_Pdu, CanApp_Pdu1; Can_PduType CanApp_Pdu2, CanApp_Pdu3, CanApp_Pdu4, CanApp_Pdu5; /**< Variables which contains Can PDU data used in Can transmission */ uint8 CanApp_InputData[64U] = {0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x22, 0x44, }; /**< Variable which contains Can SDU data that is transported inside the PDU */ PduInfoType *CanApp_RxPdu = NULL; /**< Pointer received data */ uint32 CanApp_DemStatus = E_OK; /**< Variable used to track dem notifications */ uint32 CanApp_DetStatus = E_OK; /**< Variable used to track det notifications */ static Dem_EventIdType CanApp_EventId; /**< Variable used to track dem event, reported event id */ static Dem_EventStatusType CanApp_EventStatus; /**< Variable used to track dem event, reported event status */ static uint16 CanApp_ModuleId; /**< Variable used to track det event, reported module id */ static uint8 CanApp_InstanceId; /**< Variable used to track det event, reported instance id */ static uint8 CanApp_ApiId; /**< Variable used to track det event, reported api id */ static uint8 CanApp_ErrorId; /**< Variable used to track det event, reported error id */ #if (CAN_TX_ONLY_MODE == STD_ON) const Can_PduType *CanApp_PduInfo; /**< Pointer to Can PDU used in Can transmission */ uint8 CanApp_Hth = 0U; /**< Hardware Mailbox Number configured to trigger transmission */ uint32 CanApp_Mask = 0x00000000U; /**< Mask is used for checking received message id with transmitted message */ #endif /* ========================================================================== */ /* External Variables */ /* ========================================================================== */ /* Global variables used in callback functions */ extern P2VAR(Can_HwType, CANIF_VAR_CLEARED, CANIF_APPL_DATA) CanIf_Mailbox; extern PduInfoType CanIf_PduInfo; extern SemaphoreP_Handle CanIf_TxConfirmationSemaphore; /**< TX Confirmation semaphore */ extern SemaphoreP_Handle CanIf_RxConfirmationSemaphore; /**< Rx Confirmation semaphore */ //uint64_t CanProfileCumulativeTx; /**< Global used to track cumulative time spent for transmission */ /* ========================================================================== */ /* Function Definitions */ /* ========================================================================== */ sint32 CanApp_ProfileTest(canAppTaskObj_t *testParams) { uint32 ctlr_cnt; Can_ReturnType status; uint32 loopCnt, itr;/* totalCanMsgPerSec; float totalCpuload; float totalTimePerMsg; Utils_PrfLoad computedLoad; uint64_t preTimeStamp, postTimeStamp; volatile uint32 cookie;*/ #if (APP_INSTANCE_1_INST_IN_CFG_ONLY == STD_OFF) const Can_ConfigType *Can_ConfigPtr; #if (STD_ON == CAN_VARIANT_PRE_COMPILE) Can_ConfigPtr = &CAN_INIT_CONFIG_PC; #else Can_ConfigPtr = &CanConfigSet; #endif #endif CanApp_RxPdu = &CanIf_PduInfo; /* Message for CAN-FD(MCU MCAN0 module) */ #if (CAN_TX_ONLY_MODE == STD_ON) CanApp_PduInfo = &CanApp_Pdu; /* Setting Up CAN FD Extended Frame*/ CanApp_Pdu.id = 0xC0 | 0xC0000000U; CanApp_Pdu.length = 64U; CanApp_Pdu.swPduHandle = 1U; CanApp_Pdu.sdu = &CanApp_InputData[0U]; /* Message for CAN-FD(MCU MCAN1 module) */ /* Setting Up CAN FD Extended Frame*/ CanApp_Pdu1.id = 0xB0 | 0xC0000000U; CanApp_Pdu1.length = 64U; CanApp_Pdu1.swPduHandle = 2U; CanApp_Pdu1.sdu = &CanApp_InputData[0U]; /* Message for CAN-FD(MAIN MCAN0 module) */ /* Setting Up CAN FD Frame*/ CanApp_Pdu2.id = 0xC0 | 0xC0000000U; CanApp_Pdu2.length = 64U; CanApp_Pdu2.swPduHandle = 3U; CanApp_Pdu2.sdu = &CanApp_InputData[0U]; /* Message for CAN-FD(MAIN MCAN4 module) */ /* Setting Up CAN FD Frame*/ CanApp_Pdu3.id = 0xD0 | 0xC0000000U; CanApp_Pdu3.length = 64U; CanApp_Pdu3.swPduHandle = 4U; CanApp_Pdu3.sdu = &CanApp_InputData[0U]; /* Message for CAN-FD(MAIN MCAN9 module) */ /* Setting Up CAN FD Frame*/ CanApp_Pdu4.id = 0xE0 | 0xC0000000U; CanApp_Pdu4.length = 64U; CanApp_Pdu4.swPduHandle = 5U; CanApp_Pdu4.sdu = &CanApp_InputData[0U]; /* Message for CAN-FD(MAIN MCAN11 module) */ /* Setting Up CAN FD Frame*/ CanApp_Pdu5.id = 0xF0 | 0xC0000000U; CanApp_Pdu5.length = 64U; CanApp_Pdu5.swPduHandle = 6U; CanApp_Pdu5.sdu = &CanApp_InputData[0U]; CanApp_DemStatus = E_OK; CanApp_DetStatus = E_OK; #endif #if (APP_INSTANCE_1_INST_IN_CFG_ONLY == STD_OFF) uint32 canMaxControllerCnt; canMaxControllerCnt = Can_ConfigPtr->CanMaxControllerCount; for (ctlr_cnt = 0U; ctlr_cnt < canMaxControllerCnt; ctlr_cnt++) #else ctlr_cnt = 0U; #endif { CanApp_ProfileStatus = E_OK; #if (CAN_TX_ONLY_MODE == STD_ON) /* Set Can frame */ CanApp_SetupCanFrame(ctlr_cnt, &CanApp_Hth, &CanApp_Mask); #endif /* Set Controller Mode to Start */ status = Can_SetControllerMode( CanConfigSet_CanController_List_PC[ctlr_cnt]->ControllerId, CAN_T_START); if (status != CAN_OK) { CanApp_ProfileStatus = E_NOT_OK; AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME " Controller not started properly\n"); } else { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME " Controller started properlyy:%d\n",ctlr_cnt); } #if (CAN_LOOPBACK_ENABLE == STD_ON) /* Enable loopback mode in CAN */ Can_TestLoopBackModeEnable( CanConfigSet_CanController_List_PC[ctlr_cnt]->ControllerId, 0U); #endif //#if (CAN_INITIAL_PRINT_DISABLE_BEFORE_CAN_RESPONSE == STD_OFF) AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Will " CAN_TX_RX_MSG "%d Messages, %d times: %d\n", testParams->numTxPackets, testParams->numIterations,ctlr_cnt); //#endif //CanProfileCumulativeTx = 0U; /* Start Time stamp */ /* preTimeStamp = TimerP_getTimeInUsecs(); cookie = Utils_prfLoadCalcReset(); cookie = Utils_prfLoadCalcStart();*/ for (itr = 0U; itr < testParams->numIterations; itr++) { for (loopCnt = 0U; loopCnt < testParams->numTxPackets; loopCnt++) { #if (CAN_LOOPBACK_ENABLE == STD_OFF) /* Do either Tx only or Rx only */ /* Tx Only */ #if (CAN_TX_ONLY_MODE == STD_ON) /* Do Can Write to send the CanApp_InputData on CAN bus */ status = Can_Write(CanApp_Hth, CanApp_PduInfo); if (status == CAN_OK) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "CAN Write is success : Hth=%d, ID = %d,%d\n",CanApp_Hth,CanApp_PduInfo->id,CanApp_PduInfo->length); /*SemaphoreP_pend(CanIf_TxConfirmationSemaphore, SemaphoreP_WAIT_FOREVER);*/ } else { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "CAN Write is Failing : Hth=%d, ID = %d,%d\n",CanApp_Hth,CanApp_PduInfo->id,CanApp_PduInfo->length); CanApp_ProfileStatus = E_NOT_OK; } if (CAN_APP_E_DEM == CanApp_DemStatus) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Dem error was reported, eventId = %d, eventStatus = %d,ctlr_cnt=%d,loopCnt= %d\n", CanApp_EventId, CanApp_EventStatus,ctlr_cnt,loopCnt); CanApp_DemStatus = E_OK; } if (CAN_APP_E_DET == CanApp_DetStatus) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Det error was reported\n"); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ModuleId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_InstanceId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ApiId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ErrorId); CanApp_DetStatus = E_OK; } /* Rx Only */ #else /* Pend on the semaphore posted in Rx indication */ SemaphoreP_pend(CanIf_RxConfirmationSemaphore, SemaphoreP_WAIT_FOREVER); #endif /* Internal loopback */ #else /* Do Can Write to send the CanApp_InputData on CAN bus */ status = Can_Write(CanApp_Hth, CanApp_PduInfo); if (status == CAN_OK) { SemaphoreP_pend(CanIf_TxConfirmationSemaphore, SemaphoreP_WAIT_FOREVER); } else { CanApp_ProfileStatus = E_NOT_OK; } /* Pend on the semaphore posted in Rx indication */ SemaphoreP_pend(CanIf_RxConfirmationSemaphore, SemaphoreP_WAIT_FOREVER); #endif } } #if 0 cookie = Utils_prfLoadCalcStop (); /* End Time stamp */ postTimeStamp = TimerP_getTimeInUsecs(); /* Time for transmission of numIterations*numTxPackets messages */ CanProfileCumulativeTx = CanProfileGetTimeSpent(preTimeStamp, postTimeStamp); #endif if (E_OK == CanApp_ProfileStatus) { // Utils_prfLoadGetTaskLoad(TaskP_self(), &computedLoad); #if (CAN_LOOPBACK_ENABLE == STD_ON) AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "NOTE : Operating in internal loop-back mode\n"); #endif AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME CAN_TX_RX_MSG " %u packets %d times\n", testParams->numTxPackets, testParams->numIterations); /* Number of packets transmitted * number of iterations * 1 or 2 (2 in case of tx & rx) transmitted in msecs (computed above) */ #if 0 AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Average of %lld.%02d usecs per packet \n", CanProfileCumulativeTx / (testParams->numTxPackets * testParams->numIterations), CanProfileCumulativeTx % (testParams->numTxPackets * testParams->numIterations)); totalTimePerMsg = ((float)CanProfileCumulativeTx / ((float)testParams->numTxPackets * (float)testParams->numIterations)); totalCanMsgPerSec = (1000000.0f / totalTimePerMsg); /* Hardware interrupt handler load + Software interrupt handler + task load */ totalCpuload = computedLoad.hwiLoad + computedLoad.swiLoad + computedLoad.tskLoad; AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Average of %u packets in 1 second with CPU Load %f%% \r\n", totalCanMsgPerSec, totalCpuload); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Measured Load: Total CPU: " "%f%%, HWI: %f%%, SWI:%f%% TSK: %f%%\r\n", computedLoad.cpuLoad, computedLoad.hwiLoad, computedLoad.swiLoad, computedLoad.tskLoad); #endif /* Set Controller Mode to Stop*/ status = Can_SetControllerMode( CanConfigSet_CanController_List_PC[ctlr_cnt]->ControllerId, CAN_T_STOP); if (status != CAN_OK) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Controller not stopped correctlyn"); CanApp_ProfileStatus = E_NOT_OK; } else { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Controller stopped correctlyn"); } #if (CAN_LOOPBACK_ENABLE == STD_ON) Can_TestLoopBackModeDisable( CanConfigSet_CanController_List_PC[ctlr_cnt]->ControllerId, 0U); #endif #if (CAN_LOOPBACK_ENABLE == STD_ON) if ((CanApp_PduInfo->length == CanApp_RxPdu->SduLength) && (CanApp_PduInfo->id == (CanIf_Mailbox->CanId | CanApp_Mask))) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Message Id Received %x Message Length is %u\t \n", CanIf_Mailbox->CanId, CanApp_RxPdu->SduLength); for (loopCnt = 0U; ((loopCnt < CanApp_RxPdu->SduLength)&&(loopCnt < 10U)); loopCnt++) { if (CanApp_RxPdu->SduDataPtr[loopCnt] != CanApp_InputData[loopCnt]) { CanApp_ProfileStatus = E_NOT_OK; AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Transmitted and Received Data miss-match.\n"); break; } else { CanApp_ProfileStatus = E_OK; } } AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Test completed for %u instance \n\n", ctlr_cnt); } else { CanApp_ProfileStatus = E_NOT_OK; } #endif } } AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME " %d bytes used for stack \n", AppUtils_GetStackUsage()); if (E_OK == CanApp_ProfileStatus) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Profiling completes sucessfully!!!\n"); AppUtils_LogResult(APP_UTILS_STATUS_PASS); } else { if (CAN_APP_E_DEM == CanApp_DemStatus) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Dem error was reported, eventId = %d, eventStatus = %d\n", CanApp_EventId, CanApp_EventStatus); CanApp_DemStatus = E_OK; } if (CAN_APP_E_DET == CanApp_DetStatus) { AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "Det error was reported\n"); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ModuleId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_InstanceId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ApiId); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "With Module ID as %d\n", CanApp_ErrorId); CanApp_DetStatus = E_OK; } } return (CanApp_ProfileStatus); } void Dem_ReportErrorStatus(Dem_EventIdType eventId, Dem_EventStatusType eventStatus) { if (DEM_EVENT_STATUS_FAILED == eventStatus) { CanApp_DemStatus = CAN_APP_E_DEM; CanApp_EventId = eventId; CanApp_EventStatus = eventStatus; } return; } uint64_t CanProfileGetTimeSpent(uint64_t preTs, uint64_t postTs) { uint64_t rtnTs; if (postTs >= preTs) { rtnTs = postTs - preTs; } else { rtnTs = postTs + (0xFFFFFFFFFFFFFFFF - preTs); } return (rtnTs); } Std_ReturnType Det_ReportError(uint16 ModuleId, uint8 InstanceId, uint8 ApiId, uint8 ErrorId) { CanApp_DetStatus = CAN_APP_E_DET; CanApp_ModuleId = ModuleId; CanApp_InstanceId = InstanceId; CanApp_ApiId = ApiId; CanApp_ErrorId = ErrorId; return E_OK; } #define CAN_START_SEC_ISR_CODE #include "Can_MemMap.h" CAN_ISR_TEXT_SECTION FUNC(void, CAN_CODE_FAST) CanApp_CanXIsr ( uintptr_t CanPtr) { /*volatile uint64_t preTimeStamp, postTimeStamp; preTimeStamp = TimerP_getTimeInUsecs();*/ CanApp_IsrType canChIsr = (CanApp_IsrType)CanPtr; /* Associated CAN ISR */ canChIsr(); /*postTimeStamp = TimerP_getTimeInUsecs(); CanProfileCumulativeTx += CanProfileGetTimeSpent(preTimeStamp, postTimeStamp);*/ } #define CAN_STOP_SEC_ISR_CODE #include "Can_MemMap.h"
can_write interface returned success(E_OK) for very first time only, after that keeps on returning NOT_OK. Also after first can_write DEM error is reporting.
Dem error was reported, eventId = 65517, eventStatus = 1, Attached logs as well -- >
-------------------EP2000--------------------------- --------------Version : 203300---------------------- -------------R5F_MCU_1_0_CORE----------------------- -------DRV : CAN_TRCV-WdG-IPC-ADC-SPI--------------- -------APP : SOH-TEMP MON-VOLT MON-POWER_MAGR------- -------MOD : IMU_SMI130-POWER_MANGER---------------- ---------------------------------------------------- APTIV VIP-R5F: EP2000 - Tasks initialized !!! CAN TRCV Pin Init:- Read value 118 - 6 -36 Read value 118 - 7 -73 Read value 118 - 2 -255 Read value at 118 - 3 - 255 Read value 119 - 6 -36 Read value 119 - 7 -201 Read value 119 - 2 -255 Read value at 119 - 3 -255 Read value 116 - 6 -36 Read value 116 - 7 -73 Read value 116 - 2 -255 Read value at 116 - 3 - 255 Read value U11 - 7 -247 Read value at U11 - 3 - 247 CAN Profile App:Variant - Pre Compile being used !!! CAN Profile App: GCP-CAN is Initializing !!! WatchDog_Task_Intialize- STARTS !!! WDG MCAL Version Info --------------------- Vendor ID : 44 Module ID : 102 SW Major Version : 0 SW Minor Version : 1 SW Patch Version : 0 Starting WDG test !!! Variant - Pre Compile being used !!! WDG timeout is configured for 20000 millisecs WDG ESM Interrupt will be generated after 20000 * 5 i.e 100000 millisecs APTIV VIP-R5F:SPI Init !!! Temperature_Mon_Initialize APT Profile App: Controller started proCAN Profile App: Controller started properlyy:0 Temp sensor boardcfg Failed -6 IPC_Test_:File Before Resource Table LoadedCAN Profile App:Will Transmit 5 Messages, 5 times: 0 vtm_sensor_init IPC_Test_:File After Resource Table LoadedCAN Profile App:NOTE : CAN Write is successs : ctlr_cnt=0, loopCnt = 0 IPC_Test_:File IPC VirtIO Init DoneCAN Profile App:Dem error was reported, eventId = 65517, eventStatus = 1,ctlr_cnt=0,loopCnt= 0 IPC_Test_:File RPMsg Init DoneCAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 1 IPC_Test_:File Remote_Proc returned mcu1_0!!! IPN Profile App:NOTE : CAN Write is failing : cCAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 2 IPC_Test_:File rpmsg_vdevMonitorFxn mcu1_0!!! CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 3 IPC_Test_:FileInside Vdev Monitor Function IPN Profile App:NOTE : CAN Write is failingCAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 1 CAN R5F MCU_1_0 Alive Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 2 CAN Profile App:Det error was reported CAN Profile App:With Module ID as 102 CAN Profile App:With Module ID as 0 CAN Profile App:With Module ID as 5 CAN Profile App:With Module ID as 16 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=0,loopCnt = 4 CAN Profile App: Controller started properlyy:1 CAN Profile App:Will Transmit 5 Messages, 5 times: 1 CAN Profile App:NOTE : CAN Write is successs : ctlr_cnt=1, loopCnt = 0 CAN Profile App:Dem error was reported, eventId = 65517, eventStatus = 1,ctlr_cnt=1,loopCnt= 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 2 CAN Profile App:NOTE :R5F MCU_1_0 Alive CAN Write is failing : ctlr_cnt=1,loopCnt = 3 CAN Profile App:Det error was reported CAN Profile App:With Module ID as 102 CAN Profile App:With Module ID as 0 CAN Profile App:With Module ID as 5 CAN Profile App:With Module ID as 16 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 1 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 2 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 4 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 0 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 1 CAN Profile App:NOTE : CAN WriteR5F MCU_1_0 Alive is failing : ctlr_cnt=1,loopCnt = 2 CAN Profile App:Det error was reported CAN Profile App:With Module ID as 102 CAN Profile App:With Module ID as 0 CAN Profile App:With Module ID as 5 CAN Profile App:With Module ID as 16 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 3 CAN Profile App:NOTE : CAN Write is failing : ctlr_cnt=1,loopCnt = 4 CAN Profile App: 8192 bytes used for stack R5F MCU_1_0 Alive R5F MCU_1_0 Alive R5F MCU_1_0 Alive Average Temperature 35044 R5F MCU_1_0 Alive R5F MCU_1_0 Alive R5F MCU_1_0 Alive �ͭT��0(�)+����?�T��0(�)+����?�T��0(�)+����?�T��0(�)+���!+�� +-��!�� ?v2���?�T��0(�)+����?�T��0(�)+����?�T��0(�)+����?�T��0(�)+����?�T��0(�)+����?�T��0(�)+���)����3�?�������������/�%��� ��������)����3�?�����2����6�%�������2�8�:�2��������!���5������������������4�%�9���.�����!+�� +-��!�� ?
