Part Number: PROCESSOR-SDK-DRA8X-TDA4X
The vision apps, by default, supports outputs in DPI0/vout0 output port. This article explains how it can be changed to output on DPI1/vout1 output port.
Vision apps currently uses vout0/DPI0 output port for HDMI output. This article explains how vision apps can be changed to get the output over vout1.
Vout1/DPI1 output supports 16 data lines and 4 control signals, so it can be used to output BT656, BT1120, BT601 output formats.
Enabling vout1 in vision apps requires few changes in the dss implementation
obj->nodeVpId = APP_DCTRL_NODE_VP2;
obj->nodeDpiId = APP_DCTRL_NODE_DPI_DPI1;
static pinmuxPerCfg_t gVout1PinCfg[] =
/* MyVOUT1 -> VOUT1_DATA0 */
PIN_RGMII5_TX_CTL, PIN_MODE(4) | \
((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE))
/* MyVOUT1 -> VOUT1_DATA1 */
PIN_RGMII5_RX_CTL, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA2 */
PIN_RGMII5_TD3, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA3 */
PIN_RGMII5_TD2, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA4 */
PIN_RGMII5_TD1, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA5 */
PIN_RGMII5_TD0, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA6 */
PIN_RGMII5_TXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA7 */
PIN_RGMII5_RXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA8 */
PIN_RGMII5_RD3, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA9 */
PIN_RGMII5_RD2, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA10 */
PIN_RGMII5_RD1, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA11 */
PIN_RGMII5_RD0, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA12 */
PIN_RGMII6_TX_CTL, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA13 */
PIN_RGMII6_RX_CTL, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA14 */
PIN_RGMII6_TD3, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA15 */
PIN_RGMII6_TD2, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_VSYNC */
PIN_RGMII6_TD1, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_HSYNC */
PIN_RGMII6_TD0, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_PCLK */
PIN_RGMII6_TXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT0_DE */
PIN_RGMII6_RXC, PIN_MODE(4) | \
{PINMUX_END}
static pinmuxModuleCfg_t gDispPinCfg[] =
{0, TRUE, gVout1PinCfg},
{1, TRUE, gI2c1PinCfg},
{PINMUX_END}
Brijesh
