Part Number: TDA4VM
MCP79410-I/SN is connected I2C0 interface of J721E SoC. How to enable the same?
Following changes are needed:
J721e:/TDA4VM
diff --git a/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts b/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts
index 6788a3611..9d642eb7a 100644
--- a/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts
+++ b/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts
@@ -593,6 +593,11 @@
#gpio-cells = <2>;
+ rtc@6f {
+ compatible = "microchip,mcp7941x";
+ reg = <0x6f>;
exp2: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
Once you have made the changes in the defconfig & the dts files. All you need to do is:make linux
then copy the kernel and DT binaries to your rootfs:
cp $SDK_INSTALL_DIR:/board-support/linux*/arch/arm64/boot/Image $SDK_INSTALL_DIR:/board-support/linux*/arch/arm64/boot/dts/ti/k3-j721e-common-porc-board.dtb /media/$USER/rootfs/boot
J7200:
diff --git a/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts b/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
--- a/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
+++ b/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
#gpio-cells = <2>;
+ rtc@6f {
+ reg = <0x6f>;
exp2: gpio@22 {
reg = <0x22>;
cp $SDK_INSTALL_DIR:/board-support/linux*/arch/arm64/boot/Image $SDK_INSTALL_DIR:/board-support/linux*/arch/arm64/boot/dts/ti/k3-j7200-common-porc-board.dtb /media/$USER/rootfs/boot
Keerthy
