Part Number: PROCESSOR-SDK-AM65X
I get fetch errors when I run bitbake, how can I resolve these error?
It was carried out with reference to the procedure in the guide below.
1.2.2.2. Build Steps( downloads.ti.com/.../Overview_Building_the_SDK.html )
I'm using the SDK below:
ti-processor-sdk-linux-am65xx-evm-07_00_01_06
I'm using the toolchain below:
gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu
gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf
The details of the first fetch error are as follows:
WARNING: mtd-utils-2.1.1-r0.arago1 do_fetch: Failed to fetch URL git://git.infradead.org/mtd-utils.git, attempting MIRRORS if available
ERROR: mtd-utils-2.1.1-r0.arago1 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; unset _PYTHON_SYSCONFIGDATA_NAME; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1491"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_PROXY_COMMAND="oe-git-proxy"; export all_proxy="socks://www-proxy.bb.tdi.co.jp:10080/"; export ALL_PROXY="socks://www-proxy.bb.tdi.co.jp:10080/"; export no_proxy="bb.tdi.co.jp"; export NO_PROXY="bb.tdi.co.jp"; export ftp_proxy="www-proxy.bb.tdi.co.jp:10080/"; export https_proxy="www-proxy.bb.tdi.co.jp:10080/"; export http_proxy="www-proxy.bb.tdi.co.jp:10080/"; export PATH="/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/sources/oe-core/scripts:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot-native/usr/bin/aarch64-linux:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot/usr/bin/crossscripts:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot-native/usr/sbin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot-native/usr/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot-native/sbin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/mtd-utils/2.1.1-r0.arago1/recipe-sysroot-native/bin:/home/tomita/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/sources/bitbake/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/hosttools"; export HOME="/home/tomita"; LANG=C git -c core.fsyncobjectfiles=0 fetch -f --prune --progress git://git.infradead.org/mtd-utils.git refs/*:refs/* failed with exit code 128, output:
fatal: repository 'git.infradead.org/.../' not found
ERROR: mtd-utils-2.1.1-r0.arago1 do_fetch: Fetcher failure for URL: 'git://git.infradead.org/mtd-utils.git'. Unable to fetch URL from any source.
The details of the second fetch error are as follows:
WARNING: stream-5.10-r0.arago1 do_fetch: Failed to fetch URL git://git.ti.com/sitara-linux/stream;branch=sdk, attempting MIRRORS if available
ERROR: stream-5.10-r0.arago1 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; unset _PYTHON_SYSCONFIGDATA_NAME; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1491"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_PROXY_COMMAND="oe-git-proxy"; export all_proxy="socks://www-proxy.bb.tdi.co.jp:10080/"; export ALL_PROXY="socks://www-proxy.bb.tdi.co.jp:10080/"; export no_proxy="bb.tdi.co.jp"; export NO_PROXY="bb.tdi.co.jp"; export ftp_proxy="www-proxy.bb.tdi.co.jp:10080/"; export https_proxy="www-proxy.bb.tdi.co.jp:10080/"; export http_proxy="www-proxy.bb.tdi.co.jp:10080/"; export PATH="/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/sources/oe-core/scripts:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot-native/usr/bin/aarch64-linux:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot/usr/bin/crossscripts:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot-native/usr/sbin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot-native/usr/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot-native/sbin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/recipe-sysroot-native/bin:/home/tomita/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/sources/bitbake/bin:/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/hosttools"; export HOME="/home/tomita"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://git.ti.com/sitara-linux/stream /home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/downloads/git2/git.ti.com.sitara-linux.stream --progress failed with exit code 128, output:
Cloning into bare repository '/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/downloads/git2/git.ti.com.sitara-linux.stream'...
fatal: repository 'git.ti.com/.../' not found
ERROR: stream-5.10-r0.arago1 do_fetch: Fetcher failure for URL: 'git://git.ti.com/sitara-linux/stream;branch=sdk'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/stream/5.10-r0.arago1/temp/log.do_fetch.26261
ERROR: Task (/home/tomita/ti-processor-sdk-linux-am65xx-evm-07_00_01_06/yocto-build/sources/meta-arago/meta-arago-extras/recipes-benchmark/stream/stream_5.10.bb:do_fetch) failed with exit code '1'
