Part Number: AM5728
I has written a OpenCV example to test DSP offloading correctness. I try to copy a UMat to another one, unfortunately the operation is not correct.
#include <opencv2/opencv.hpp>
#include <limits>
#include <cstdlib>
#include <time.h>
#include <unistd.h>
using namespace cv;
using Pixel = unsigned char;
/* Time difference calculation, in ms units */
double tdiff_calc(struct timespec &tp_start, struct timespec &tp_end)
return (double)(tp_end.tv_nsec -tp_start.tv_nsec) * 0.000001 + (double)(tp_end.tv_sec - tp_start.tv_sec) * 1000.0;
bool checkZero(const Pixel* buffer, int size)
for (int i = 0; i < size; ++i) {
if (buffer[i]) {
return false;
return true;
void writeZero(Pixel* buffer, int size)
buffer[i] = 0;
int main(int argc, const char** argv)
int width = 21;
int height = 21;
if (argc != 3) {
std::cout << "Invalid parameters!" << std::endl;
return -1;
try {
width = std::stoi(argv[1]);
height = std::stoi(argv[2]);
std::cout << "Width = " << width << std::endl;
std::cout << "Height = " << height << std::endl;
std::cout << "---" << std::endl;
catch (const std::exception& e) {
std::cerr << e.what() << '\n';
return -2;
int size = width * height;
auto inputBuffer = new Pixel[size]{0};
auto outputBuffer = new Pixel[size]{0};
writeZero(inputBuffer, size);
writeZero(outputBuffer, size);
if (checkZero(outputBuffer, size)) {
printf("Zero, Ok\n");
else {
printf("Not Zero, Not Ok!\n");
return -1;
struct timespec tp0, tp1, tp2, tp3;
Mat input(height, width, CV_8UC1, inputBuffer);
Mat output(height, width, CV_8UC1, outputBuffer);
randu(input, Scalar::all(std::numeric_limits<Pixel>::min()), Scalar::all(std::numeric_limits<Pixel>::max()));
UMat in;
UMat out;
clock_gettime(CLOCK_MONOTONIC, &tp0);
// input.copyTo(in);
in = input.getUMat(ACCESS_RW);
clock_gettime(CLOCK_MONOTONIC, &tp1);
// output.copyTo(out);
out = output.getUMat(ACCESS_RW);
clock_gettime(CLOCK_MONOTONIC, &tp2);
in.copyTo(out);
clock_gettime(CLOCK_MONOTONIC, &tp3);
bool equalFlag = true;
for (unsigned i = 0; i < size; ++i) {
if (inputBuffer[i] != outputBuffer[i]) {
equalFlag = false;
break;
if (equalFlag) {
printf("Equal!\n");
else {
printf("Not Equal!\n");
printf("---\n");
printf("in = input.getUMat(ACCESS_RW); -> tdiff=%lf ms \n", tdiff_calc(tp0, tp1));
printf("out = output.getUMat(ACCESS_RW); -> tdiff=%lf ms \n", tdiff_calc(tp1, tp2));
printf("in.copyTo(out); -> tdiff=%lf ms \n", tdiff_calc(tp2, tp3));
return 0;
If I disable the offloading, the input and output UMats are same. If I enable the offloading these aren't same.
You can also find the example via the link below:
I appreciate if you can help me regarding the issue.
Kind regards,
Mustafa
