Disk /dev/mtdblock0 doesn't contain a valid partition table
I'm using AM335x Linux.When I use the fdisk -l command I get the messages:
root@am335x:~# fdisk -l
Disk /dev/mtdblock0: 0 MB, 131072 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Disk /dev/mtdblock1: 0 MB, 131072 bytes
Disk identifier: 0xffffffff
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 0 MB, 131072 bytes
Disk identifier:[ 40.804260] end_request: I/O error, dev mtdblock5, sector 0
[ 40.811248] Buffer I/O error on device mtdblock5, logical block 0
0xffffffff
D[ 40.818725] end_request: I/O error, dev mtdblock5, sector 8
[ 40.824829] Buffer I/O error on device mtdblock5, logical block 1
isk /dev/mtdblock2 doesn't contain a valid parti[ 40.834167] end_request: I/O error, dev mtdblock5, sector 0
[ 40.841186] Buffer I/O error on device mtdblock5, logical block 0
tion table
Disk /dev/mtdblock3: 0 MB, 131072 bytes
Units = cylinders of 16065 * 51[ 40.858184] end_request: I/O error, dev mtdblock5, sector 0
[ 40.864562] Buffer I/O error on device mtdblock5, logical block 0
2 = 8225280 byte[ 40.871917] end_request: I/O error, dev mtdblock5, sector 8
[ 40.878143] Buffer I/O error on device mtdblock5, logical block 1
s
Sector size (logical/physical): 512 bytes / 5[ 40.887481] end_request: I/O error, dev mtdblock5, sector 0
[ 40.894531] Buffer I/O error on device mtdblock5, logical block 0
12 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 1 MB, 1966080 bytes
Disk identifier: 0xe08ee009
Disk /dev/mtdblock4 doesn't contain a valid partition table
Disk /dev/mtdblock6: 5 MB, 5242880 bytes
Disk identifier: 0xe1a03007
Disk /dev/mtdblock6 doesn't contain a valid partition table
Disk /dev/mtdblock7: 260 MB, 260571136 bytes
255 heads, 63 sectors/track, 31 cylinders
Disk /dev/mtdblock7 doesn't contain a valid partition table
I want to remove the warnings.Can anyone give some advice?
Best Regards
John
  • There are not any partition tables as each mtd block is being used to store single images. These are being used to store MLO, U-Boot, kernel etc. From the board file for the AM335x is a listing of nand partitions.
    root@am335x-evm:~# cat /proc/mtd
    dev:    size   erasesize  name
    mtd0: 00020000 00020000 "SPL"
    mtd1: 00020000 00020000 "SPL.backup1"
    mtd2: 00020000 00020000 "SPL.backup2"
    mtd3: 00020000 00020000 "SPL.backup3"
    mtd4: 001e0000 00020000 "U-Boot"
    mtd5: 00020000 00020000 "U-Boot Env"
    mtd6: 00500000 00020000 "Kernel"
    mtd7: 0f880000 00020000 "File System"
  • The warning can be removed by using the fdisk utility to put a partition on the mtd block.
  • I encounter the same issue. I use the mtdblockX as raw "partition" and don't want to put partitionn info on each part. How to remove the warning messages from fdisk -l ?
  • What is the point in removing the warning? There is nothing wrong with the output of fdisk -l.
  • Renjith,
    I have 13 mtd partitions.  And now I have a USB stick (/dev/sda) attached to USB port.  When I run 'fdisk -l', many "Disk /dev/mtdblockX doesn't contain a valid partition table" appear.  Due to the fact that I use mtd partitions as RAW format (2 SPI FLASH, 16MB each) or UBIFS (mtd11/mtd12, NAND FLASH), I don't want the useless/boring "Disk /dev/mtdblockX doesn't contain a valid partition table" output. How can I accomplish this?
    root@MPU-001:~# cat /proc/mtd
    mtd0: 00080000 00001000 "SPL/MLO(Golden,RO)"
    mtd1: 00080000 00001000 "U-Boot (Golden,RO)"
    mtd2: 00400000 00001000 "Kernel (Golden,RO)"
    mtd3: 00080000 00001000 "U-Boot (Bank-A)"
    mtd4: 00080000 00001000 "U-Boot (Bank-B)"
    mtd5: 00080000 00001000 "U-Boot Env (Bank-A)"
    mtd6: 00080000 00001000 "U-Boot Env (Bank-B)"
    mtd7: 00400000 00001000 "Kernel (Bank-A)"
    mtd8: 00400000 00001000 "Kernel (Bank-B)"
    mtd9: 00100000 00001000 "Reserved (not used)"
    mtd10: 01000000 00001000 "RAMDISK"
    mtd11: 10000000 00020000 "UBIFS (Bank-A)"
    mtd12: 10000000 00020000 "UBIFS (Bank-B)"
    root@MPU-001:~#
    root@MPU-001:~# cat /proc/partitions
    major minor #blocks name
    31 0 512 mtdblock0
    31 1 512 mtdblock1
    31 2 4096 mtdblock2
    31 3 512 mtdblock3
    31 4 512 mtdblock4
    31 5 512 mtdblock5
    31 6 512 mtdblock6
    31 7 4096 mtdblock7
    31 8 4096 mtdblock8
    31 9 1024 mtdblock9
    31 10 16384 mtdblock10
    31 11 262144 mtdblock11
    31 12 262144 mtdblock12
    8 0 1970239 sda
    8 1 1970208 sda1
    root@MPU-001:~# fdisk -l
    Disk /dev/mtdblock0: 0 MB, 524288 bytes
    Disk /dev/mtdblock1: 0 MB, 524288 bytes
    Disk /dev/mtdblock2: 4 MB, 4194304 bytes
    Disk /dev/mtdblock2 doesn't contain a valid partition table
    Disk /dev/mtdblock3: 0 MB, 524288 bytes
    Disk /dev/mtdblock4: 0 MB, 524288 bytes
    Disk /dev/mtdblock5: 0 MB, 524288 bytes
    Disk /dev/mtdblock5 doesn't contain a valid partition table
    Disk /dev/mtdblock6: 0 MB, 524288 bytes
    Disk /dev/mtdblock7: 4 MB, 4194304 bytes
    Disk /dev/mtdblock8: 4 MB, 4194304 bytes
    Disk /dev/mtdblock8 doesn't contain a valid partition table
    Disk /dev/mtdblock9: 1 MB, 1048576 bytes
    Disk /dev/mtdblock9 doesn't contain a valid partition table
    Disk /dev/mtdblock10: 16 MB, 16777216 bytes
    255 heads, 63 sectors/track, 2 cylinders
    Disk /dev/mtdblock10 doesn't contain a valid partition table
    Disk /dev/mtdblock11: 268 MB, 268435456 bytes
    255 heads, 63 sectors/track, 32 cylinders
    Disk /dev/mtdblock11 doesn't contain a valid partition table
    Disk /dev/mtdblock12: 268 MB, 268435456 bytes
    Disk /dev/mtdblock12 doesn't contain a valid partition table
    Disk /dev/sda: 2017 MB, 2017525248 bytes
    255 heads, 63 sectors/track, 245 cylinders
    Device Boot Start End Blocks Id System
    /dev/sda1 * 1 246 1970208 6 FAT16
    Partition 1 has different physical/logical endings:
    phys=(244, 254, 63) logical=(245, 72, 18)
  • Frisky,
    I don't have a proper solution for this. But still, have you tried different options in drivers/mtd/Kconfig related to partitions? Another way is to remove the list of partitions from the board file, where you declare partitions. Just list down only the partition that you want to use. Last but not recommended way out is to modify the fdisk implementation to ignore the unwanted partitions.
  • Hi Renjith,
    I can't find any option in config file and i would like not change fdisk code:(
    I found that my /sbin/fdisk  is from busybox. Then I built fdisk from util-linux-2.22 and run it, everything is ok.  Thank you!
    Disk /dev/mtdblock0: 0 MB, 524288 bytes, 1024 sectors
    Units = sectors of 1 * 512 = 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk /dev/mtdblock1: 0 MB, 524288 bytes, 1024 sectors
    Disk /dev/mtdblock2: 4 MB, 4194304 bytes, 8192 sectors
    Disk /dev/mtdblock3: 0 MB, 524288 bytes, 1024 sectors
    Disk /dev/mtdblock4: 0 MB, 524288 bytes, 1024 sectors
    Disk /dev/mtdblock5: 0 MB, 524288 bytes, 1024 sectors
    Disk /dev/mtdblock6: 0 MB, 524288 bytes, 1024 sectors
    Disk /dev/mtdblock7: 4 MB, 4194304 bytes, 8192 sectors
    Disk /dev/mtdblock8: 4 MB, 4194304 bytes, 8192 sectors
    Disk /dev/mtdblock9: 1 MB, 1048576 bytes, 2048 sectors
    Disk /dev/mtdblock10: 16 MB, 16777216 bytes, 32768 sectors
    Disk /dev/mtdblock11: 268 MB, 268435456 bytes, 524288 sectors
    Disk /dev/mtdblock12: 268 MB, 268435456 bytes, 524288 sectors
    Disk /dev/sda: 2017 MB, 2017525248 bytes, 3940479 sectors
    Disk identifier: 0x0ba248ac
    /dev/sda1 * 63 3940478 1970208 6 FAT16
