I used to write image processing algorithms using C6Accel on DM8168 but since C6Accel is deprecated, I started to work with Codec Engine (EZSDK 5.04.00.11). I modified image_copy app to make it work with buffersize of 921600 bytes. Here is my new apps/image_copy/app.c file:
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== app.c ========
#include <xdc/std.h>
#include <xdc/runtime/Assert.h>
#include <xdc/runtime/Diags.h>
#include <xdc/runtime/Log.h>
#include <ti/sdo/ce/Engine.h>
#include <ti/sdo/ce/osal/Memory.h>
#include <ti/sdo/ce/image/imgdec.h>
#include <ti/sdo/ce/image/imgenc.h>
#include <string.h> /* for memset */
#include <stdio.h>
#include <stdlib.h>
#include <sys/time.h>
* If an XDAIS algorithm _may_ use DMA, buffers provided to it need to be
* aligned on a cache boundary.
#ifdef CACHE_ENABLED
* If buffer alignment isn't set on the compiler's command line, set it here
* to a default value.
#ifndef BUFALIGN
#define BUFALIGN 128
#endif
#else
/* Not a cached system, no buffer alignment constraints */
#define BUFALIGN Memory_DEFAULTALIGNMENT
#endif
#define NSAMPLES 1280*720 /* must be multiple of 128 for cache/DMA reasons */
#define IFRAMESIZE (NSAMPLES * sizeof(Int8)) /* raw frame (input) */
#define EFRAMESIZE (NSAMPLES * sizeof(Int8)) /* encoded frame */
#define OFRAMESIZE (NSAMPLES * sizeof(Int8)) /* decoded frame (output) */
static XDAS_Int8 *inBuf;
static XDAS_Int8 *encodedBuf;
static XDAS_Int8 *outBuf;
static String decoderName = "imgdec_copy";
static String encoderName = "imgenc_copy";
static Void encode_decode(IMGENC_Handle enc, IMGDEC_Handle dec, FILE *in,
FILE *out);
* ======== createInFileIfMissing ========
static void createInFileIfMissing(char *inFileName)
int i;
FILE *f = fopen(inFileName, "rb");
if (f == NULL) {
printf("Input file '%s' not found, generating one.\n", inFileName);
f = fopen(inFileName, "wb");
for (i = 0; i < NSAMPLES; i++) {
fwrite(&i, sizeof(i), 1, f);
fclose(f);
* ======== smain ========
Int smain(String progName, String procId, String engineName,
String inFile, String outFile)
Engine_Handle ce = NULL;
Engine_Attrs attrs;
IMGDEC_Handle dec = NULL;
IMGENC_Handle enc = NULL;
FILE *in = NULL;
FILE *out = NULL;
Memory_AllocParams allocParams;
createInFileIfMissing(inFile);
Log_print4(Diags_USER1, "[+1] App-> Application started, procId %s "
"engineName %s input-file %s output-file %s.",
(IArg)procId, (IArg)engineName, (IArg)inFile, (IArg)outFile);
/* allocate buffers */
allocParams.type = Memory_CONTIGHEAP;
allocParams.flags = Memory_NONCACHED;
allocParams.align = BUFALIGN;
allocParams.seg = 0;
inBuf = (XDAS_Int8 *)Memory_alloc(IFRAMESIZE, &allocParams);
encodedBuf = (XDAS_Int8 *)Memory_alloc(EFRAMESIZE, &allocParams);
outBuf = (XDAS_Int8 *)Memory_alloc(OFRAMESIZE, &allocParams);
if ((inBuf == NULL) || (encodedBuf == NULL) || (outBuf == NULL)) {
goto end;
/* open file streams for input and output */
if ((in = fopen(inFile, "rb")) == NULL) {
printf("App-> ERROR: can't read file %s\n", inFile);
goto end;
if ((out = fopen(outFile, "wb")) == NULL) {
printf("App-> ERROR: can't write to file %s\n", outFile);
goto end;
/* Initialize attrs fields to default values, and set the procId */
Engine_initAttrs(&attrs);
attrs.procId = procId;
/* reset, load, and start DSP Engine */
if ((ce = Engine_open(engineName, &attrs, NULL)) == NULL) {
fprintf(stderr, "%s: error: can't open engine %s\n",
progName, engineName);
goto end;
/* allocate and initialize video decoder on the engine */
dec = IMGDEC_create(ce, decoderName, NULL);
if (dec == NULL) {
printf( "App-> ERROR: can't open codec %s\n", decoderName);
goto end;
/* allocate and initialize video encoder on the engine */
enc = IMGENC_create(ce, encoderName, NULL);
if (enc == NULL) {
fprintf(stderr, "%s: error: can't open codec %s\n",
progName, encoderName);
goto end;
/* use engine to encode, then decode the data */
encode_decode(enc, dec, in, out);
end:
/* teardown the codecs */
if (enc) {
IMGENC_delete(enc);
if (dec) {
IMGDEC_delete(dec);
/* close the engine */
if (ce) {
Engine_close(ce);
/* close the files */
if (in) {
fclose(in);
if (out) {
fclose(out);
/* free buffers */
if (inBuf) {
Memory_free(inBuf, IFRAMESIZE, &allocParams);
if (encodedBuf) {
Memory_free(encodedBuf, EFRAMESIZE, &allocParams);
if (outBuf) {
Memory_free(outBuf, OFRAMESIZE, &allocParams);
Log_print0(Diags_USER1, "[+1] app done.");
return (0);
double calc_time(struct timeval *before, struct timeval *after)
if (before->tv_usec > after->tv_usec)
return (after->tv_usec - before->tv_usec + 1000000) / (double)1000;
else
return (after->tv_usec - before->tv_usec) / (double)1000;
* ======== encode_decode ========
FILE *out)
struct timeval tbegin, tend;
Int n;
Int32 status;
IMGDEC_InArgs decInArgs;
IMGDEC_OutArgs decOutArgs;
IMGDEC_DynamicParams decDynParams;
IMGDEC_Status decStatus;
IMGENC_InArgs encInArgs;
IMGENC_OutArgs encOutArgs;
IMGENC_DynamicParams encDynParams;
IMGENC_Status encStatus;
XDM_BufDesc inBufDesc;
XDAS_Int8 *src[XDM_MAX_IO_BUFFERS];
XDAS_Int32 inBufSizes[XDM_MAX_IO_BUFFERS];
XDM_BufDesc encodedBufDesc;
XDAS_Int8 *encoded[XDM_MAX_IO_BUFFERS];
XDAS_Int32 encBufSizes[XDM_MAX_IO_BUFFERS];
XDM_BufDesc outBufDesc;
XDAS_Int8 *dst[XDM_MAX_IO_BUFFERS];
XDAS_Int32 outBufSizes[XDM_MAX_IO_BUFFERS];
/* clear and initialize the buffer descriptors */
memset(src, 0, sizeof(src[0]) * XDM_MAX_IO_BUFFERS);
memset(encoded, 0, sizeof(encoded[0]) * XDM_MAX_IO_BUFFERS);
memset(dst, 0, sizeof(dst[0]) * XDM_MAX_IO_BUFFERS);
src[0] = inBuf;
encoded[0] = encodedBuf;
dst[0] = outBuf;
inBufDesc.numBufs = encodedBufDesc.numBufs = outBufDesc.numBufs = 1;
inBufDesc.bufSizes = inBufSizes;
encodedBufDesc.bufSizes = encBufSizes;
outBufDesc.bufSizes = outBufSizes;
inBufSizes[0] = encBufSizes[0] = outBufSizes[0] = NSAMPLES;
inBufDesc.bufs = src;
encodedBufDesc.bufs = encoded;
outBufDesc.bufs = dst;
/* initialize all "sized" fields */
encInArgs.size = sizeof(encInArgs);
decInArgs.size = sizeof(decInArgs);
encOutArgs.size = sizeof(encOutArgs);
decOutArgs.size = sizeof(decOutArgs);
encDynParams.size = sizeof(encDynParams);
decDynParams.size = sizeof(decDynParams);
encStatus.size = sizeof(encStatus);
decStatus.size = sizeof(decStatus);
* Query the encoder and decoder.
* This app expects the encoder to provide 1 buf in and get 1 buf out,
* and the buf sizes of the in and out buffer must be able to handle
* NSAMPLES bytes of data.
status = IMGENC_control(enc, XDM_GETSTATUS, &encDynParams, &encStatus);
if (status != IMGENC_EOK) {
/* failure, report error and exit */
Log_print1(Diags_USER7, "[+7] encode control status = 0x%x",
(IArg)status);
return;
/* Validate this encoder codec will meet our buffer requirements */
if ((inBufDesc.numBufs < encStatus.bufInfo.minNumInBufs) ||
(IFRAMESIZE < encStatus.bufInfo.minInBufSize[0]) ||
(encodedBufDesc.numBufs < encStatus.bufInfo.minNumOutBufs) ||
(EFRAMESIZE < encStatus.bufInfo.minOutBufSize[0])) {
Log_print0(Diags_USER7, "[+7] Error: encoder codec feature conflict");
return;
status = IMGDEC_control(dec, XDM_GETSTATUS, &decDynParams, &decStatus);
if (status != IMGDEC_EOK) {
Log_print1(Diags_USER7, "[+7] decode control status = 0x%x",
(IArg)status);
return;
/* Validate this decoder codec will meet our buffer requirements */
if ((encodedBufDesc.numBufs < decStatus.bufInfo.minNumInBufs) ||
(EFRAMESIZE < decStatus.bufInfo.minInBufSize[0]) ||
(outBufDesc.numBufs < decStatus.bufInfo.minNumOutBufs) ||
(OFRAMESIZE < decStatus.bufInfo.minOutBufSize[0])) {
"[+7] App-> ERROR: decoder does not meet buffer requirements.");
return;
* Read complete frames from in, encode, decode, and write to out.
for (n = 0; n < 10; n++) {
/* Deal with cache issues, if necessary */
#if defined(xdc_target__isaCompatible_64P) || \
defined(xdc_target__isaCompatible_64T)
* fread() on this processor is implemented using CCS's stdio, which
* is known to write into the cache, not physical memory. To meet
* XDAIS DMA Rule 7, we must writeback the cache into physical
* memory. Also, per DMA Rule 7, we must invalidate the buffer's
* cache before providing it to any xDAIS algorithm.
Memory_cacheWbInv(inBuf, IFRAMESIZE);
#else
#error Unvalidated config - add appropriate fread-related cache maintenance
#endif
/* Per DMA Rule 7, our output buffer cache lines must be cleaned */
Memory_cacheInv(encodedBuf, EFRAMESIZE);
#endif
Log_print1(Diags_USER1, "[+1] App-> Processing frame %d...", (IArg)n);
gettimeofday(&tbegin, NULL);
/* encode the frame */
status = IMGENC_process(enc, &inBufDesc, &encodedBufDesc, &encInArgs,
&encOutArgs);
gettimeofday(&tend, NULL);
printf("Processing time: %.3f ms\n", calc_time(&tbegin, &tend));
Log_print2(Diags_USER2,
"[+2] App-> Encoder frame %d process returned - 0x%x)",
(IArg)n, (IArg)status);
/* Writeback this outBuf from the previous call. Also, as encodedBuf
* is an inBuf to the next process call, we must invalidate it also, to
* clean buffer lines.
Memory_cacheWbInv(encodedBuf, EFRAMESIZE);
Memory_cacheInv(outBuf, OFRAMESIZE);
#endif
Log_print3(Diags_USER7,
"[+7] App-> Encoder frame %d processing FAILED, status = 0x%x, "
"extendedError = 0x%x",
(IArg)n, (IArg)status, (IArg)(encOutArgs.extendedError));
break;
/* decode the frame */
decInArgs.numBytes = encOutArgs.bytesGenerated;
status = IMGDEC_process(dec, &encodedBufDesc, &outBufDesc, &decInArgs,
&decOutArgs);
"[+2] App-> Decoder frame %d process returned - 0x%x)",
"[+7] App-> Decoder frame %d processing FAILED, status = 0x%x, "
(IArg)n, (IArg)status, (IArg)(decOutArgs.extendedError));
break;
/* Writeback the outBuf. */
Memory_cacheWb(outBuf, OFRAMESIZE);
#endif
/* write to file */
fwrite(dst[0], OFRAMESIZE, 1, out);
Log_print1(Diags_USER1, "[+1] %d frames encoded/decoded", (IArg)n);
* @(#) ti.sdo.ce.examples.apps.image_copy; 1, 0, 0,1; 2-24-2012 19:27:54; /db/atree/library/trees/ce/ce-t06/src/ xlibrary
loamodules.sh:
modprobe cmemk phys_start=0x96C00000 phys_end=0x98000000
modprobe syslink
So the result time of copying from one buffer to another is 28 ms. When I use C6Accel, it takes 7 ms to copy data. Why does Codec Engine processing works several times slower than C6Accel? I tried Codec Engine project the same way on Beagleboard-xM with DVSDK 4.01.00.09, and there were no decrease of perfomance.
Sergey
