The PDK_c6657_1_1_2_6 nand driver is for 8 bit nand flash. I can certainly port it for the 16bit nand flash. But just wonder whether there is already a nand driver example for the 16bit nand flash?
GanZ
GanZ
There isn`t a ready to go example for 16bot NAND driver in the PDK provided with the MCSDK. You will need to modify the NAND config in the file C6657_nand.c for the 16 bit NAND that you plan to use.
Do let us know if you have issues and we can help you port the driver for the 16 bit NAND that you are using in the design
Rahul
