Hello, TI Community.
I'm trying to launch project "Example 3 - Running from external memory (DDR)" from BIOS MCSDK 2.0 User Guide. I've attached the .gel file, but program is not launching after debug state. The console messages were like:
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
C66xx_0: GEL Output: No initialization performed since bootmode = 0x00000005
C66xx_0: GEL Output: You can manually initialize with GlobalDefaultSetup
C66xx_0: GEL Output: Invalidate All Cache...
C66xx_0: GEL Output: Invalidate All Cache... Done.
C66xx_0: GEL Output: GEL Reset...
C66xx_0: GEL Output: GEL Reset... Done.
I did the GlobalDefaultSetup and it worked. But i want to do it automatically, because it's annoying to do it every time. How could this problem be solved?
With best regards, Semen Jarov.
