Other Parts Discussed in Thread: TDA2
Tool/software: TI-RTOS
Hi Expert,
I'm running PROCESSOR SDK VISION v03.04.00 rtos on tda2eg.
TDA2 EVM and custom board both have.
I modify and run CSL uart test present here:
PROCESSOR_SDK_VISION_03_04_00_00\ti_components\drivers\pdk_01_10_00_08\packages\ti\csl\example\uart\uart_test
I call UARTConfigInit() to initial UART2 engine after pin mux setting finish.
but system get stuck problem when I call UARTConfigInit() API.
Could you please give me some advise?
Thanks in advance.
attach is source file.
* Copyright (C) 2013-2017 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \file main.c
* \brief This file demonstrates UART console input and output.
* Expects user to enter an input string and outputs the same
* on console.
/* Include Files */
#include <stdint.h>
#include <stdio.h>
#include <ti/csl/hw_types.h>
#include <ti/csl/soc.h>
#include <ti/csl/example/utils/uart_console/inc/uartConfig.h>
#if defined (SOC_AM574x) || defined (SOC_AM572x) || defined (SOC_AM571x)
#include <ti/board/board.h>
#endif
/* Macros */
/* Commented define TESTCASE_ID to test with default settings of
* BAUD_RATE = 115200,
* WORD_LENGTH = 8Bits,
* STOP_BIT = 1,
* PARITY = None.
* Uncomment below define and set to appropriate test case number to test
* specific configuration.
#define TESTCASE_ID UART_19
#if (TESTCASE_ID == UART_1)
#define BAUD_RATE BAUD_RATE_9600
#endif
#if (TESTCASE_ID == UART_2)
#define BAUD_RATE BAUD_RATE_14400
#endif
#if (TESTCASE_ID == UART_3)
#define BAUD_RATE BAUD_RATE_19200
#endif
#if (TESTCASE_ID == UART_4)
#define BAUD_RATE BAUD_RATE_38400
#endif
#if (TESTCASE_ID == UART_5)
#define BAUD_RATE BAUD_RATE_57600
#endif
#if (TESTCASE_ID == UART_6)
#define BAUD_RATE BAUD_RATE_115200
#endif
#if (TESTCASE_ID == UART_7)
#define BAUD_RATE BAUD_RATE_230400
#endif
#if (TESTCASE_ID == UART_8)
#define BAUD_RATE BAUD_RATE_460800
#define UART_MODE UART_13x_MODE
#endif
#if (TESTCASE_ID == UART_9)
#define BAUD_RATE BAUD_RATE_921600
#endif
#if (TESTCASE_ID == UART_10)
#define WORD_LENGTH UART_WORD_LENGTH_5
#endif
#if (TESTCASE_ID == UART_11)
#define WORD_LENGTH UART_WORD_LENGTH_6
#endif
#if (TESTCASE_ID == UART_12)
#define WORD_LENGTH UART_WORD_LENGTH_7
#endif
#if (TESTCASE_ID == UART_13)
#define WORD_LENGTH UART_WORD_LENGTH_8
#endif
#if (TESTCASE_ID == UART_14)
#define STOP_BIT UART_STOP_BIT_1
#endif
#if (TESTCASE_ID == UART_15)
#define STOP_BIT UART_STOP_BIT_1_5_2
#endif
#if (TESTCASE_ID == UART_16)
#endif
#if (TESTCASE_ID == UART_17)
#define PARITY UART_NO_PARITY
#endif
#if (TESTCASE_ID == UART_18)
#define PARITY UART_PARITY_ODD
#endif
#if (TESTCASE_ID == UART_19)
#define PARITY UART_PARTY_EVEN
#endif
#ifndef BAUD_RATE
#endif
#ifndef WORD_LENGTH
#endif
#ifndef STOP_BIT
#endif
#ifndef PARITY
#endif
#ifndef UART_MODE
#define UART_MODE UART_16x_MODE
#endif
#define UART_INST_NUM (1U)
uint32_t uartBaseAddr;
uint32_t uart2Addr;
#define df_uart1 1
#define df_uart2 1
/* Global Variables */
/* None */
/* Function Definitions */
#if 1
void delay(void)
volatile uint32_t i;
for (i = 0; i < 1000000; i++)
#endif
void padConfig_prcmEnable()
// Pad configurations
Board_initCfg boardCfg;
boardCfg = BOARD_INIT_UNLOCK_MMR | BOARD_INIT_UART_STDIO |
BOARD_INIT_MODULE_CLOCK | BOARD_INIT_PINMUX_CONFIG;
Board_init(boardCfg);
#endif
#if defined (SOC_TDA2XX) || defined (SOC_TDA2PX) || defined (SOC_TDA2EX) || defined (SOC_DRA72x) || defined (SOC_DRA75x)
#if df_uart1 //' uart1
/*Pad configurations */
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_UART1_RXD,0x00040000);
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_UART1_TXD,0x00000000);
/* Set the UART Parameters */
UARTConfigInit(uartBaseAddr, BAUD_RATE, WORD_LENGTH, STOP_BIT, PARITY, UART_MODE);
#endif
#if df_uart2 //' uart2
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_UART2_RXD,0x00040000);
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_UART2_TXD,0x00000000);
UARTConfigInit(uart2Addr, BAUD_RATE, WORD_LENGTH, STOP_BIT, PARITY, UART_MODE);
#endif
#endif
#if defined (SOC_TDA3XX) || defined (SOC_DRA78x)
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_IO_SPI1_SCLK,0x00040001);
HW_WR_REG32(SOC_CORE_PAD_IO_REGISTERS_BASE+CTRL_CORE_PAD_IO_SPI1_CS0,0x00000001);
// Set the UART Parameters
UART_MODE);
#endif
int main(void)
char dataBuffer[100];
uartBaseAddr = SOC_UART1_BASE;
uart2Addr = SOC_UART2_BASE;
uartBaseAddr = SOC_UART3_BASE;
#endif
#if (defined (SOC_AM574x) || defined (SOC_AM572x)) || (defined (SOC_AM571x))
#endif
/*Pad configuration and PRCM enable*/
padConfig_prcmEnable();
while(1){
#if df_uart1
UARTConfigPuts(uartBaseAddr, "--tnzaku02------ uart1\n", -1);
#endif
#if df_uart2
UARTConfigPuts(uart2Addr, "--tnzaku02------ uart2\n", -1);
#endif
delay();
/* UART receive and transmit operation */
UARTConfigPuts(uartBaseAddr, "\nUART Test", -1);
UARTConfigPuts(uartBaseAddr, "\nEnter some data to transmit:", -1);
UARTConfigGets(uartBaseAddr, &dataBuffer[0], -1);
UARTConfigPuts(uartBaseAddr, "\nData Received:", -1);
UARTConfigPuts(uartBaseAddr, &dataBuffer[0], -1);
UARTConfigPuts(uartBaseAddr, "\nUART Test Completed", -1);
return 0;
/********************************* End of file ******************************/
