Part Number: AMIC110
Do you provide any help for EIP stack Integration after EIP stack purchase from TMG molex?
Vrund
Vrund
Hi Vrund,
Yes, we will help if you experience the integration issue. Please ensure to let TMG Molex know you are planning to integrate their stack to TI Sitara device AMIC110/AM335x so they can point you to the right stack version.
Garrett
Thanks.
Can you tell me how much time does it take to integrate roughly?
Vrund
Vrund,
I would expect the integration effort is minor if you have a correct version from TMG (info@tmgte.de) licensed.
Garrett
Kindly address below queries.
1) I am in contact with TMG regarding EIP stack.
I have informed them about use of TI AMIC with EIP stack.
Can you tell me which EIP stack version I should ask for?
2) I am going through ICSS EIP Adapter Developer Guide.
In that there is no mention of how to check DLR functionality. Can you let me know how to check DLR functionality.(I have DLR based Ethernet Switch, AMIC eval board).
3) I also need to know what is the ring recovery time achieved with how many node for given TI AMIC 110 EIP solution.
Vrund
Vrund,
1) EtherNet/IP 1.0.3 release uses the EtherNet/IP stack version 3.5.0.0, see http://software-dl.ti.com/processor-industrial-sw/esd/docs/indsw/ethernetIP_adapter/01_00_03/PRU_ICSS_EthernetIP.html#system-requirements
2) DLR object attributes can be queried and displayed using EIP tool,
You can set up a ring topology with an PLC and multiple devices to set up a ring topology and test ring fault (break) and normal status, https://processors.wiki.ti.com/index.php/ICSS_EIP_Adapter_Developer_Guide#Communication_between_EtherNet.2FIP_Adapter_and_Scanner_devices
3) Some relevant benchmarks in data sheet:
DLR – Device Level Ring
o 100us beacon interval
o 200us beacon timeout
for Link loss detection.
o Link loss detection in under 200us
o Callback API’s to perform tasks
related to change in network
topology
Garrett
