Part Number: AFE7769
Other Parts Discussed in Thread: AFE7799
Hi Team,
When we use more than one AFE7799 on the same PCB, there may be phase differences between the signals at the RF outputs of these different AFE7799 transceivers due to some uncertainities of the clock distribution network (for example the mismatch between transmission lines distributing LO to the transceivers and this mismatch may be temperature dependent). Do you have any solution for multichip RF synchronization to overcome this problem? By this way we can make sure that the outputs of all transceivers on the PCB will be phase synchronized. If you have a solution, can you please share a block diagram of the recommanded multichip synchronization solution.
Dr. Tamer Güdü
ASELSAN A.S
Turkey
