Other Parts Discussed in Thread: TSW14J58EVM
Using the TSW14J58EVM DC182_A7 to connect to the AFE7950EVM DC135 REV A
External ~500 MHz clock into REF_CLK_LOW and ~1.5 GHz clock into LMK_CLK_IN
I can get all Tx, Rx and FB ports working using 204B with the following script:
############## Read me ##############
#In HSDC Pro DAC tab, Select AFE79xx_2x2TX_44210; Data Rate = 491.52M
#In HSDC Pro ADC tab, Select AFE79xx_2x2RX_24410; Data Rate = 245.76M ---> To capture 4 RX channels
#In HSDC Pro ADC tab, Select AFE79xx_1x2FB_44210; Data Rate = 491.52M ---> To capture 2 FB channels
sysParams=AFE.systemParams
sysParams.__init__();sysParams.chipVersion=chipVersion
setupParams.skipFpga = False # setup FPGA (TSW14J58) using HSDC Pro
############## Top Level ##############
sysParams.FRef = 491.52
sysParams.FadcRx = 2949.12
sysParams.FadcFb = 2949.12
sysParams.Fdac = 2949.12*4
sysParams.externalClockRx=False
sysParams.externalClockTx=False
############## Digital Chain ##############
##### RX #####
sysParams.ddcFactorRx = [12,12,12,12] #DDC decimation factor for RX A, B, C and D
sysParams.rxNco0 = [[9500,9500], #Band0, Band1 for RXA
[9500,9500], #Band0, Band1 for RXB
[9500,9500], #Band0, Band1 for RXC
[9500,9500]] #Band0, Band1 for RXD
##### FB #####
sysParams.ddcFactorFb = [6,6] #DDC decimation factor for FB 1 and 2
sysParams.fbNco0 = [9500,9500] #Band0 for FB1 and FB2
##### TX #####
sysParams.ducFactorTx = [24,24,24,24] #DUC interpolation factor for TX A, B, C and D
sysParams.txNco0 = [[9500,9500], #Band0, Band1 for TXA
[9500,9500], #Band0, Band1 for TXB
[9500,9500], #Band0, Band1 for TXC
[9500,9500]] #Band0, Band1 for TXD
############## JESD ##############
##### ADC-JESD #####
sysParams.jesdSystemMode= [1,1]
#SystemMode 0: 2R1F-FDD ; rx1-rx2-fb -fb
#SystemMode 1: 1R1F-FDD ; rx -rx -fb -fb
#SystemMode 2: 2R-FDD ; rx1-rx1-rx2-rx2
#SystemMode 3: 1R ; rx -rx -rx -rx
#SystemMode 4: 1F ; fb -fb- fb -fb
#SystemMode 5: 1R1F-TDD ; rx/fb-rx/fb-rx/fb-rx/fb
sysParams.jesdTxProtocol= [0,0] # 0 - 8b/10b encoding; 2 - 64b/66b encoding
sysParams.LMFSHdRx = ["24410","24410","24410","24410"]
# The 2nd and 4th are valid only for jesdSystemMode values in (0,2).
# For other modes, select 4 converter modes for 1st and 3rd.
sysParams.LMFSHdFb = ["22210","22210"]
sysParams.rxJesdTxScr = [True,True,True,True]
sysParams.fbJesdTxScr = [True,True]
sysParams.rxJesdTxK = [16,16,16,16]
sysParams.fbJesdTxK = [16,16]
sysParams.jesdTxLaneMux = [0,1,2,3,4,5,6,7] # Enter which lanes you want in each location.
# For example, if you want to exchange the first two lines of each 2T,
# this should be [[1,0,2,3],[5,4,6,7]]
##### DAC-JESD #####
sysParams.jesdRxProtocol= [0,0]
sysParams.LMFSHdTx = ["44210","44210","44210","44210"]
sysParams.jesdRxLaneMux = [0,1,2,3,4,5,6,7] # Enter which lanes you want in each location.
# For example, if you want to exchange the first two lines of each 2R
sysParams.jesdRxRbd = [4, 4]
sysParams.jesdRxScr = [True,True,True,True]
sysParams.jesdRxK = [16,16,16,16]
##### JESD Common #####
sysParams.jesdABLvdsSync= True
sysParams.jesdCDLvdsSync= True
sysParams.syncLoopBack = False #JESD Sync signal is connected to FPGA
############## GPIO ##############
sysParams.gpioMapping = {
'H8': 'ADC_SYNC0',
'H7': 'ADC_SYNC1',
'N8': 'ADC_SYNC2',
'N7': 'ADC_SYNC3',
'H9': 'DAC_SYNC0',
'G9': 'DAC_SYNC1',
'N9': 'DAC_SYNC2',
'P9': 'DAC_SYNC3',
'P14': 'GLOBAL_PDN',
'K14': 'FBABTDD',
'R6': 'FBCDTDD',
'H15': ['TXATDD','TXBTDD'],
'V5': ['TXCTDD','TXDTDD'],
'E7': ['RXATDD','RXBTDD'],
'R15': ['RXCTDD','RXDTDD']}
############## LMK Params ##############
lmkParams.pllEn = False #True
lmkParams.inputClk = 1474.56 #1500.0 #983.04 # Valid only when lmkParams.pllEn = False
#lmkParams.sysrefFreq = 7.68 #3000/1024
lmkParams.lmkFrefClk = False #True
setupParams.fpgaRefClk = 245.76 # Should be equal to LaneRate/40 for TSW14J56
############## Logging ##############
logDumpInst.setFileName(ASTERIX_DIR+DEVICES_DIR+r"\Afe79xxPg1.txt")
logDumpInst.logFormat=0x0 #Modify to 0x1 to save register scequence to log file. Script takes more time to execute.
logDumpInst.rewriteFile=1
logDumpInst.rewriteFileFormat4=1
device.optimizeWrites=0
device.rawWriteLogEn=1
device.delay_time = 0
AFE.deviceBringup()
AFE.TOP.overrideTdd(15,3,15) # bit-wise; 4R,2F,4T
When I change to 204C, I can get Tx and Rx working but not the FB ports. I've tried many variations of the script below, but no success with the FB ports. No data comes through on the FB ports, just a blank white screen. When I change sysParams.LMFSHdFb to 22210, I get errors:
'list' object has no attribute '__buffer__'
No values received from capture Device
#In HSDC Pro DAC tab, Select AFE79xx_2x2TX_44210; Data Rate = 983.04M
#In HSDC Pro ADC tab, Select AFE79xx_2x2RX_44210; Data Rate = 983.04M ---> To capture 4 RX channels
setupParams.skipFpga = 0 # setup FPGA (TSW14J56) using HSDC Pro
#sysParams.RRFMode = 0 #5 # RRF 0: 4T4R2F FDD Mode
##### RX #####
sysParams.ddcFactorRx = [6,6,6,6] #[3,3,3,3] #DDC decimation factor for RX A, B, C and D
##### FB #####
#sysParams.fbEnable = [True,True]
sysParams.ddcFactorFb = [6,6] #[3,3] #DDC decimation factor for FB 1 and 2
##### TX #####
sysParams.ducFactorTx = [12,12,12,12] #DUC interpolation factor for TX A, B, C and D
sysParams.jesdSystemMode= [1,1] #[3,3]
sysParams.jesdTxProtocol= [2,2] # 0 - 8b/10b encoding; 2 - 64b/66b encoding
sysParams.LMFSHdRx = ["24410","24410","24410","24410"] #["44210","44210","44210","44210"]
sysParams.LMFSHdFb = ["24410","24410"]
sysParams.rxJesdTxScr = [False,False,False,False]
sysParams.fbJesdTxScr = [False,False]
sysParams.rxJesdTxK = [1,1,1,1]
sysParams.fbJesdTxK = [1,1]
sysParams.jesdRxProtocol= [2,2] # 0 - 8b/10b encoding; 2 - 64b/66b encoding
sysParams.jesdRxScr = [False,False,False,False]
sysParams.jesdRxK = [1,1,1,1]
'H8': 'ADC_SYNC0',
'H7': 'ADC_SYNC1',
'N8': 'ADC_SYNC2',
'N7': 'ADC_SYNC3',
'H9': 'DAC_SYNC0',
'G9': 'DAC_SYNC1',
'N9': 'DAC_SYNC2',
'P9': 'DAC_SYNC3',
'K14': 'FBABTDD',
'R6': 'FBCDTDD',
lmkParams.inputClk = 1474.56 #983.04 # Valid only when lmkParams.pllEn = False
AFE.deviceBringup()
AFE.TOP.overrideTdd(15,0,15) # bit-wise; 4R,2F,4T
Can you please advise what settings I need to change in the second script to get FB ports working with 204C?
Thanks, David.
