Other Parts Discussed in Thread: LMX2571
Hi all
This is very new for me. I have been given a task, that is not my usual area of expertise.
I need to generate a FM modulated signal, i need to be able to gate the following:
A sine carrier signal at a specific frequency. for simplicity 100 MHz.
Frequency modulate the signal by +/-5 MHz with a bandwidth of 100 KHz or more.
in some cases the center frequency will be 80 MHz, others 120MHz or more.
Ideally the center frequency should be selectable from 50 MHz to 500 MHz.
But as a minimum 70 MHz to 120 MHz.
I have been looking at various RF parts, but it is not clear to me if they generate a sine wave or square wave on the output of the device.
Further more it is not clear to me if all parts support FM modulation via an analog signal.
I would appreciate some input on how to get started and figuring out if the output is indeed sine.
Simply put: how would one go about generating a 100 MHz sine with +/-5 MHz modulation depth and a constant sine amplitude?
Best regards
Kristian K
