Other Parts Discussed in Thread: TRF370417
Hi
I have build a board using the TRF370417 modulator. My serious problem is, that I get no output power. Schematic is as datasheet Figure 47, page 19. The NC pins are grounded.
LO signal = differential 3GHz, 0dBm
BB signal= differential 200Mhz, -10dBm.
I have tried with other signal levels as well feed the LO as single ended signal. Nothing works.
The Vcc= 5.0Volt.
I have tried out two TRF370417 on my board, in case I did have a soldering issue. None of them give any output signal.
Is the schematic in datasheet wrong? Should the NC pins be NC, biased or something else ?
Best Regards
Hans
