GC4016 - wideband mode - Decimation
I have attached ultra wideband mode configuration file of GC4016. This configuration is working fine for Decimations 8,10 and 16 and not working for 9,11,12,13,14 and 15. Why it is behaving like that.
/* Wideband configuration file */
/* general modes register */
   global_reset 1
  out_blk_reset 1
      pad_reset 1
resampler_reset 1
    edge_write  1
      ck_2x_en  0
    ck_2x_test  0
ck_loss_detect  0
/* general sync */
          lvds  0
 4_bit_address  0
   output_sync  4
     diag_sync  7
/* count sync */
      one_shot  1
       os_mode  1
    count_test  0
  counter_sync  7
   diag_source  0
/* terminal count */
           cnt  0
/* channel configurations */
       channel  0
         phase  0
          freq  0x4CCCCCCD
     cfir_coef  ../Taps/cfir_150.taps
     pfir_coef  ../Taps/pfir_150.taps
      ch_reset  0
     use_shift  1
         shift  4
     freq_sync  7
    phase_sync  7
   dither_sync  0 /* Original is 4 */
      nco_sync  4
       zpad_en  0
     zpad_sync  4
        nzeros  0
    flush_sync  4
      dec_sync  4
           dec  7
      gain_sync 7
        mix20b  1
     big_scale  7
         scale  5 /* Changed - ELSEC */
         qonly  0
         ionly  1
       splitiq  1
       neg_ctl  0
          test  0
        coarse  0
     idly_cfir  0
     qdly_cfir  0
   no_sym_cfir  0
   peak_select  0
     idly_pfir  0 /* Changed - ELSEC */
     qdly_pfir  1
   no_sym_pfir  0
       msb_pol  0
        in_fmt  0
        ab_sel  0
     input_sel  0
     peak_mode  0
 peak_threshold 3
     peak_sync  5
     fine_gain  1070
       channel  1
  /* copy_channel 0 same as 0 */
    /* ch_reset  1*/
         phase  0x4000
          freq  0x4CCCCCCD
      ch_reset  0
     use_shift  1
         shift  4
     freq_sync  7
    phase_sync  7
   dither_sync  0 /* Original is 4*/
      nco_sync  4
       zpad_en  0
     zpad_sync  4
        nzeros  0
    flush_sync  4
      dec_sync  4
           dec  7
      gain_sync 7
        mix20b  1
     big_scale  7
         qonly  1
         ionly  0
       splitiq  1
       neg_ctl  0
          test  0
        coarse  0
     idly_cfir  0
     qdly_cfir  0
   no_sym_cfir  0
   peak_select  0
     qdly_pfir  1
   no_sym_pfir  0
       msb_pol  0
        in_fmt  0
        ab_sel  0
     input_sel  0
     peak_mode  0
 peak_threshold 3
     peak_sync  5
     fine_gain  1070
       channel  2
/*    ch_reset  1*/
       phase  0x0
          freq  0x4CCCCCCD
      ch_reset  0
     use_shift  1
         shift  4
     freq_sync  7
    phase_sync  7
      nco_sync  4
       zpad_en  0
     zpad_sync  4
        nzeros  0
    flush_sync  4
      dec_sync  4
           dec  7
      gain_sync 7
        mix20b  1
     big_scale  7
         qonly  0
         ionly  1
       splitiq  1
       neg_ctl  0
          test  0
        coarse  0
     idly_cfir  0
     qdly_cfir  0
   no_sym_cfir  0
   peak_select  0
     idly_pfir  0
     qdly_pfir  0
   no_sym_pfir  0
       msb_pol  0
        in_fmt  0
        ab_sel  0
     input_sel  0
     peak_mode  0
 peak_threshold 3
     peak_sync  5
     fine_gain  1070
       channel  3
/*ch_reset  1*/
         phase  0x4000
          freq  0x4CCCCCCD
      ch_reset  0
     use_shift  1
         shift  4
     freq_sync  7
    phase_sync  7
   dither_sync  0 /*Original is 4*/
      nco_sync  4
       zpad_en  0
     zpad_sync  4
        nzeros  0
    flush_sync  4
      dec_sync  4
           dec  7
      gain_sync 7
        mix20b  1
     big_scale  7
         qonly  1
         ionly  0
       splitiq  1
       neg_ctl  0
          test  0
        coarse  0
     idly_cfir  0
     qdly_cfir  0
   no_sym_cfir  0
   peak_select  0
     idly_pfir  0
     qdly_pfir  0
   no_sym_pfir  0
       msb_pol  0
        in_fmt  0
        ab_sel  0
     input_sel  0
     peak_mode  0
 peak_threshold 3
     peak_sync  5
     fine_gain  1070
/* resampler parameters */
       ratio_0  0x04000000
       ratio_1  0x04000000
       ratio_2  0x04000000
       ratio_3  0x04000000
      res_coef  0 ../Taps/res_bypass_1024.taps
      res_sync  4
            nf  0
            nc  0
    no_sym_res  1
            nm  6
  filter_sel_3  0
  filter_sel_2  0
  filter_sel_1  0
  filter_sel_0  0
        tag_22  0
         round  3
   final_shift  4
    chan_map_d  0
    chan_map_c  0
    chan_map_b  0
    chan_map_a  0
    ratio_sync  7
    add_c_to_d  0
    add_b_to_c  0
    add_a_to_b  0
   res_clk_div  0
     ratio_map  0x00
/* output control */
        en_par  1
         en_p3  1
         en_p2  1
         en_p1  1
         en_p0  1
        en_sfs  1
        en_rdy  1
        en_sck  1
/* outsync */
  out_blk_sync  2
     rdy_width  0
        tag_en  0
       inv_sfs  0
       inv_rdy  0
       inv_sck  0
/* out format */
    reverse_iq  0
   output_mode  3
     real_only  0
        master  1
      parallel  1
        nibble  0
          link  0
/* out frame length */
      sfs_mode  2
  frame_length  0
/* out word size */
    block_size  0
 bits_per_word  5
words_per_frame 0
/* out clock */
  output_order  0
       nserial  0
      sck_rate  0
/* serial port selection */
        smux_3  3
        smux_2  2
        smux_1  1
        smux_0  0
/* tags */
        tag_ai  0
        tag_aq  1
        tag_bi  2
        tag_bq  3
        tag_ci  4
        tag_cq  5
        tag_di  6
        tag_dq  7
/* miscellaneous */
         en_so  1
       en_4_fs  0
    The GC4016 in wideband downconvert mode uses a CIC in splitIQ mode, CFIR in splitIQ mode, and PFIR in a polyphase mode.  In this case, the CFIR decimates by 2, the
    CIC decimates by values from 4 to 1024.  The two splitIQ channels in a polyphase mode, cause the PFIR to decimate by 1 between the two pairs of splitIQ channels.
    This means that the decimation is based on CICdec * cfir_dec = (4 to 1024) * 2 * 1.  The decimation range is 8 to 2048 in steps of 2.  So decimation of 9, 11, 13, 15 are not
    possible in the CIC, CFIR, PFIR structure.  The values 8, 10, 12, 14, 16 are all possible.
    Under the CIC programming description, the value for CIC is 2N-1 for splitIQ mode, so for a CIC decimation of 4, we put in a value of 7.
        dec pgm value,  desired CIC decimation, desired wideband decimation
        7,                           4,                                         8,
        9,                           5,                                         10,
       11,                          6,                                         12,
        13,                         7,                                         14,
         15,                        8,                                         16
    When you change these decimations the CIC scaling parameters also need to be recomputed for BIG_SCALE and SCALE.    The CFIR coefficients
    have both a Low pass filter, and High pass CIC compensation.  As you change the CIC decimation, the High pass CIC compensation can be recomputed to
    generate a flatter passband response.
    I have run the wideband decimations 8, 10, 12, 14, and 16 through the cmd4016 tool.
    Radio Joe
    I have attached my configuration for SPLIT I/Q mode configuration file of GC4016. I am trying to run this configuration for decimation rate of 2,6, and 12. It does not work for
    decimation rate 6 and 12, but i get some result for 2. I am running the chip in Nibble Mode, with Output Order of 0, and the resampler is bypassed.
    Channel Control
    Dec :[0:7] = 7
    SHIFT = 4
    SCALE = 5
    BIG_SCALE = 7
    MIX20B = 1
    Resampler Control Page (Pg 64)
    NC = 1
    NF = 0
    FINAL_SHIFT = 5
    ROUND = 1;
    Output Control Page (98)
    FRAME_LENGTH = 7;
    WORDS_PER_FRAME = 7;
    BITS_PER_WORD = 0;
    BLOCK_SIZE = 2
    NSERIAL = 0
    OUTPUT_ORDER = 0;
    GLOBAL REGISTERS
    Address
    0
    1
    2
    3
    4
    5
    6
    7
    f8
    0
    0
    0
    0
    2
    cf
    f2
    PAGED REGISTERS
    Address
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    CHA
    Pages 0,1
    cFIR Coefficents
    Pages 2-5
    pFIR Coefficents
    Page 6
    0
    0
    FREQ
    Unused
    Page 7
    0c
    44
    4
    0
    22
    7
    70
    7D
    30
    0
    10
    0
    1c
    0
    e0
    8
    CHB
    Pages 8,9
    cFIR Coefficents
    Pages 10-13
    pFIR Coefficents
    Page 14
    0
    40
    FREQ
    Unused
    Page 15
    0c
    44
    4
    0
    22
    7
    70
    7D
    50
    0
    10
    0
    1c
    0
    e0
    8
    CHC
    Pages 16,17
    cFIR Coefficents
    Pages 18-21
    pFIR Coefficents
    Page 22
    0
    0
    FREQ
    Unused
    Page 23
    0c
    44
    4
    0
    22
    7
    70
    7D
    30
    0
    10
    0
    1c
    0
    e0
    8
    CHD
    Pages 24,25
    cFIR Coefficents
    Pages 26-29
    pFIR Coefficents
    Page 30
    0
    40
    FREQ
    Unused
    Page 31
    0c
    44
    4
    0
    22
    7
    70
    7D
    50
    0
    10
    0
    1c
    0
    e0
    8
    RES
    Pages 32-63
    By Pass Resampler
    Page 64
    41
    0e
    0
    15
    50
    70
    0
    0
    Unused
    Page 65
    0
    0
    0
    4
    0
    0
    0
    4
    0
    0
    0
    4
    0
    0
    0
    4
    OUT
    Page 98
    7d
    41
    ca
    7
    87
    0
    0
    21
    43
    65
    87
    0
    2
    Unused
  • Hello
    The GC4016 Wideband Downconvert mode, has a CIC that decimates from 4 - 1024, a CFIR that decimates by 2, and a PFIR that is polyphased to not decimate.
    I have attached a decimate by 8 example, that has worked inthe past with the GC4016 tool.  The allowable decimations would be 8 - 1024 as the CIC increases from 4 to 512.
    In this mode two sets of splitIQ channels are combined.
    I have attached the example configuration file, filter taps, and cmd4016 tool.  This example is decimation of 8.  The general cmd4016 tool is available on the TI website under the GC4016.
    REgards,
    Radio Joe
    gc4016wideband_downconvert.zip
  • Hello
    In our application, we are operating at 100MHz input sampling frequency. We have chosen wideband mode of DDC and decimation factor set to 10.
    With these settings we need a 8MHz filter bandwidth (160%) CFIR and PFIR fitler coefficients.
    Could you please provide coefficients for the above requirement?
    In the previous email, I sent an example for 8Mhz bandwidth with a decimation of 8.  It was also stated that we don't normally provide the ultra wide mode custom coefficients, and the Matlab script was sent with the email.
    I have attached a modified matlab script.  You will need to characterize your filter requirements, passband and stopband, and use the matlab tool to adjust the filter.  Along with the CFIR and PFIR filter design there is a CIC compensation for the droop of the CIC filter.  This is a 3 tap High Pass filter, that can be adjusted for the passband flatness.
        The Matlab script must have a destination folder, it is listed at the beginning of "C:\Temp" Line 11, it must be created before running the script.
         Line 691 - adjust the desired bandwidth in %
         Line 744 - adjust the CFIR 3 tap High Pass filter for system passband flatness,
    When the system bandwidth is > 65% (130% for ultrawide mode), the stopband rejection of the channel is less.   You would get better stopband rejection using the previous example, I sent last time, with a decimation of 8.
    I have included the script, and the desired dec10, bandwidth setting of 160, depending on the actual filter characteristics (transition band) this is not the same as an 8Mhz passband filter, you will need to adjust 691 and 744 to meet your filter requirements.
    Radio Joe
    cfirUW4016_160.taps
  • Here are both the PFIR, CFIR, and matlab script.
    Radio Joe
    pfircfir_uw160.zip
