Hello
I'm trying to test repeater mode with AFE7686EVM.
I loaded the RX_to_TX_LoopBack.cfg file after initialization as shown below, but it does not work.
How do I test repeater mode on AFE7686EVM?
I need a detailed explanation.
Best regards
Hello
Best regards
Hi kang
Thanks for your support.
I checked the app notes but couldn't find a way to test the repeater mode.
Only testing requirements and test results are indicated in the app note.
I need detail data on how to test of repeater mode.
best regards.
Louis,
You will need to first configure the ADC/DAC with the same JESD204 mode and the same LMFS, same data rate. Once configured, you may use the loopback script to enable JESDTX to talk to internal JESDRX. It is described in the application note.
-Kang
