Part Number: TMP513
Other Parts Discussed in Thread: INA3221
TMP513 does not show thermal pad in the pin list, and does not say anywhere in the datasheet that it can or can not be connected to, say, ground...
Is the thermal pad connected at all on the die? If so, to what?
This is also true for the INA3221. Thermal pad not in the pin list, and does not say in the datasheet whether it can or can not be hooked up to, say ground...
It's obviously somewhat common to hook this to ground, but there are cases where the thermal pad is not ground or unconnected, so I won't hook it to anything without knowing it's OK to do.
Thank you,
Austin
