IWR6843: clarification between frames and subFrames
Part Number: IWR6843
I am currently working on reading data frame by frame from the sensor, however, the concept of Frame and SubFrame is confusing me.
To my understanding, a Frame consists of many subFrames, and to fully get data of a frame, I'll have to read from all the subFrames within a Frame.
If my understanding is correct, how do we know which subFrame belongs to which Frame? And if I am mistaken, please kindly help me with the correct explanation of frames and subFrames, and how to efficiently read data of a frame.
Thank you very much,
Danh Pham
  • Danh:
    Can you please confirm if you are trying to take out processed point cloud data or raw ADC data. ?
    Connor Desmond
  • Hi, I am trying to extract processed point cloud data frame by frame.
    Thank you
  • Danh:
    When specifying the number of sub-frames within an advanced frame or any other parameters related to sub-frames, this is used to configure the RF front end of the device. Theese configurations will effect the structure of the ADC data that is fed to the SDK processing chain. From your perspective you just need to capture a frame of processed or point cloud data. This is demonstrated with our parser example located here:
    C:\ti\mmwave_sdk_03_05_00_04\packages\ti\demo\parser_scripts
    Configuring your chirps or a set of chirps within a subframe or subframes within an advanced subframe will effect the data that is fed into the SDK processing chain and thus effect the point cloud output indirectly. From a data reading perspective you don't need to take that structure into account.
    Connor Desmond
