AWR1843: Compiling gtrack library in mmwave sdk
Part Number: AWR1843
I'm trying to compile the gtrack library in mmwave_sdk_03_05_00_04 with xwr 1843 model.  While compiling the make file , I'm facing the following error
/bin/sh: 1: xdc.tools.configuro: not found.
This xdc tools needs to be installed seperately or how to compile this gtrack lib?
Any help would be appreciated .
Thanks in advance.
    Are you setting the variables needed in the shell? This is done by the setenv.sh file for Linux. You would need to change the device type, install root location (if you aren't using the default) in setenv.sh before running it.
    Aayush
