I am writing data in the onboard flash memory from the starting sector address(0x18FFE7U). But it is giving hard fault. I don't know what is the issue. Could you please help me solve this.
Hello User,
What is the fault you're getting? Can you give a little more details on this?
Ishita
Are you able to flash the mmWave SDK out of box demo using Uniflash?
Thank you
Cesar
Yes i am able to flash using Uniflash. Other codes are working fine. But when I flashed the code in which iam using write to the flash memory sector using sector address(0x18FFE7U), am getting red LED after finishing flashing using Uniflash and press reset button on the board.
Sai,
In order for the device to be set to flashing mode, both SOP0 and SOP2 must be closed (set to ON position).
Kyle
