Other Parts Discussed in Thread: IWR6843AOPEVM, UNIFLASH
Hi team,
If by mistake connect 12v adaptor a few second after that mmwaveicboost is not activated.
How to deal with this situation.
Thank you very much for your help.
Hi team,
Hello
It must have been rendered not working.
Which EVM are your trying to use it with and what are you trying to run?
Thank you
Vaibhav
Hi Vaibhav,
Thank you for your help.
I use with iwr6843aopevm and try to run uniflash.
Is there any other way?
Hello Zhonghui,
Due to over voltage board might have damaged. IWR6843AOPEVM could work standalone operation. could you please check you could operate standalone operation?
If it works then only mmwaveicboost need to be replaced otherwise both the boards need to be replaced.
Thanks and regards,
CHETHAN KUMAR Y.B.
Hi CHETHAN,
IWR6843AOPEVM work standalone operation. so only mmwaveicboost need to be replaced.
Hello Zhonghui,
Thanks for checking on this and confirming.
Thanks and regards,
CHETHAN KUMAR Y.B.
