Other Parts Discussed in Thread: IWR6843
Dear support team,
We are trying to implement I2C interface for source code of "68xx AoP_ODS - Multiple Gesture and Motion Detection", by referring slave.c in below link;
C:\ti\mmwave_sdk_03_05_00_04\packages\ti\drivers\i2c\test
In our system, there is external MCU as master and IWR6843 will be slave device.
We guess that timing of data requirement by master can be confirmed by retVal of I2CSlave_read() and data can be transferred to master by I2CSlave_write().
We are not sure how to use those functions, because we can't find proper document.
Please kindly explain if we are wrong.
Taka
* @file slave.c
* @brief
* Unit Test code for I2C Slave driver
* \par
* NOTE:
* (C) Copyright 2017 Texas Instruments, Inc.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
*************************** Include Files ********************************
/* Standard Include Files. */
#include <stdint.h>
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include <math.h>
/* BIOS/XDC Include Files. */
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/heaps/HeapBuf.h>
#include <ti/sysbios/heaps/HeapMem.h>
#include <ti/sysbios/family/arm/v7a/Pmu.h>
/* mmWave SK Include Files: */
#include <ti/common/sys_common.h>
#include <ti/drivers/soc/soc.h>
#include <ti/drivers/i2c/I2CSlave.h>
#include <ti/drivers/pinmux/pinmux.h>
#include <ti/drivers/esm/esm.h>
#include <ti/utils/testlogger/logger.h>
#include <ti/drivers/osal/HwiP.h>
*************************** Global Definitions ***************************
/** \brief Number of messages sent */
#define I2C_TEST_MESSAGE_COUNT 100
#define I2C_TEST_BLOCKING_MODE 1
* @brief
* Initialize the MCPI Log Message Buffer
MCPI_LOGBUF_INIT(9216);
/* Global Variables */
volatile uint32_t testSelection = 0;
volatile uint32_t gTransferDone = 0;
volatile uint32_t gTransferErrors = 0, gTransferCount = 0;
uint8_t rxData[16];
uint8_t txData[16];
uint32_t rxTicks[I2C_TEST_MESSAGE_COUNT];
uint32_t txTicks[I2C_TEST_MESSAGE_COUNT];
uint32_t minRxTicks;
uint32_t maxRxTicks;
uint32_t minTxTicks;
uint32_t maxTxTicks;
uint32_t totalTxTicks;
uint32_t totalRxTicks;
* @b Description
* @n
* This function starts the PMU counter.
* @param[in] counter
* Counter id used for benchmarking
* @retval
* Not Applicable.
void Test_benchmarkStart(uint32_t counter)
/* Initialize counter to count cycles */
Pmu_configureCounter(counter, 0x11, FALSE);
/* Reset PMU counter */
Pmu_resetCount(counter);
/* Start PMU counter */
Pmu_startCounter(counter);
* @b Description
* @n
* This function stops a PMU counter and returns the current
* counter value.
* @retval
* Current PMU counter value.
uint32_t Test_benchmarkStop(uint32_t counter)
/* Stop PMU counter */
Pmu_stopCounter(counter);
/* Read PMU counter */
return (Pmu_getCount(counter));
* @b Description
* @n
* Platform specific intializations.
* @retval
* Success - 0
* @retval
* Error - <0
static int32_t PlatformInit(void)
#if (defined(SOC_XWR14XX))
/* Setup the PINMUX to bring out the XWR14xx I2C pins */
Pinmux_Set_OverrideCtrl(SOC_XWR14XX_PINR3_PADAH, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR14XX_PINR3_PADAH, SOC_XWR14XX_PINR3_PADAH_I2C_SDA);
Pinmux_Set_OverrideCtrl(SOC_XWR14XX_PINP4_PADAI, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR14XX_PINP4_PADAI, SOC_XWR14XX_PINP4_PADAI_I2C_SCL);
#elif (defined(SOC_XWR16XX))
/* Setup the PINMUX to bring out the XWR16xx I2C pins */
Pinmux_Set_OverrideCtrl(SOC_XWR16XX_PINF13_PADAH, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR16XX_PINF13_PADAH, SOC_XWR16XX_PINF13_PADAH_I2C_SDA);
Pinmux_Set_OverrideCtrl(SOC_XWR16XX_PING14_PADAI, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR16XX_PING14_PADAI, SOC_XWR16XX_PING14_PADAI_I2C_SCL);
#elif (defined(SOC_XWR18XX))
/* Setup the PINMUX to bring out the XWR18xx I2C pins */
Pinmux_Set_OverrideCtrl(SOC_XWR18XX_PINF13_PADAH, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR18XX_PINF13_PADAH, SOC_XWR18XX_PINF13_PADAH_I2C_SDA);
Pinmux_Set_OverrideCtrl(SOC_XWR18XX_PING14_PADAI, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR18XX_PING14_PADAI, SOC_XWR18XX_PING14_PADAI_I2C_SCL);
#elif (defined(SOC_XWR68XX))
/* Setup the PINMUX to bring out the XWR68xx I2C pins */
Pinmux_Set_OverrideCtrl(SOC_XWR68XX_PINF13_PADAH, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR68XX_PINF13_PADAH, SOC_XWR68XX_PINF13_PADAH_I2C_SDA);
Pinmux_Set_OverrideCtrl(SOC_XWR68XX_PING14_PADAI, PINMUX_OUTEN_RETAIN_HW_CTRL, PINMUX_INPEN_RETAIN_HW_CTRL);
Pinmux_Set_FuncSel(SOC_XWR68XX_PING14_PADAI, SOC_XWR68XX_PING14_PADAI_I2C_SCL);
#endif
return 0;
static int32_t i2cBlockingModeTest()
I2CSlave_Handle i2cHandle;
I2CSlave_Params i2cParams;
bool retVal = false;
int32_t errCode = 0;
uint32_t arg;
/* Reset the transmit and receive buffer */
memset(&rxData, 0, sizeof (rxData));
/* Initialize the I2C Slave driver */
I2CSlave_init();
/* Initialize the I2C driver default parameters */
I2CSlave_Params_init(&i2cParams);
i2cParams.transferMode = I2CSLAVE_MODE_BLOCKING;
i2cParams.slaveAddress = 0x48;
/* Open the I2C Slave driver */
i2cHandle = I2CSlave_open(0, &i2cParams);
if (i2cHandle == NULL)
System_printf ("Error: I2C Driver Open failed\n");
return -1;
System_printf ("Debug: I2C Slave Open passed\n");
/* Configure the I2C device in expand address mode. */
arg = 1;
errCode = I2CSlave_control (i2cHandle, I2C_CMD_ADDR_MODE, (void* )&arg);
if (errCode < 0)
System_printf ("Error: I2C control Set XA failed [Error code %d]\n", errCode);
return -1;
System_printf ("Debug: I2C Slave Control passed\n");
txData[0] = 0xA;
/* Slave Write */
retVal = I2CSlave_write(i2cHandle, &txData, 1);
if (retVal == false)
System_printf ("Error: I2C Slave write failed\n");
return -1;
else
System_printf ("Debug: I2C Slave write passed\n");
/* Slave Read */
retVal = I2CSlave_read(i2cHandle, &rxData, 1);
System_printf ("Error: I2C Slave read failed\n");
return -1;
else
System_printf ("Debug: I2C Slave read passed\n");
/* Close I2C Slave driver */
I2CSlave_close(i2cHandle);
return 0;
* @b Description
* @n
* System Initialization Task which initializes the various
* components in the system.
* @retval
* Not Applicable.
static void Test_initTask(UArg arg0, UArg arg1)
int32_t retVal = 0;
/* Initialize the test logger framework: */
MCPI_Initialize ();
/* Initialize the platform */
retVal = PlatformInit();
if (retVal < 0)
MCPI_setFeatureTestResult("Platform initialization failed", MCPI_TestResult_FAIL);
MCPI_setTestResult ();
BIOS_exit(0);
while (1)
System_printf ("*******************************************************\n");
System_printf ("I2C Slave Unit Test Menu \n");
System_printf ("Please select the type of test to execute: \n");
System_printf ("1. I2C Blocking mode test \n");
System_printf ("> Enter your selection: ");
while (testSelection == 0);
/* Validate the selection: */
if (testSelection == I2C_TEST_BLOCKING_MODE)
break;
System_printf("Debug: Blocking mode testing\n");
retVal = i2cBlockingModeTest();
if (retVal == -1)
MCPI_setFeatureTestResult("Blocking mode testing", MCPI_TestResult_FAIL);
else
MCPI_setFeatureTestResult("Blocking mode testing", MCPI_TestResult_PASS);
if (retVal < 0)
System_printf("Debug: I2C Slave testing failed\n");
/* Exit BIOS */
BIOS_exit(0);
return;
* @b Description
* @n
* This is the entry point into the unit test code
* @retval
* Not Applicable.
int32_t main (void)
Task_Params taskParams;
SOC_Handle socHandle;
SOC_Cfg socCfg;
int32_t errCode;
/* Initialize the ESM: Dont clear errors as TI RTOS does it */
ESM_init(0U);
/* Initialize the SOC confiugration: */
memset ((void *)&socCfg, 0, sizeof(SOC_Cfg));
/* Populate the SOC configuration: */
socCfg.clockCfg = SOC_SysClock_INIT;
/* Initialize the SOC Module: This is done as soon as the application is started
* to ensure that the MPU is correctly configured. */
socHandle = SOC_init (&socCfg, &errCode);
if (socHandle == NULL)
System_printf ("Error: SOC Module Initialization failed [Error code %d]\n", errCode);
return -1;
/* Initialize the Task Parameters. */
Task_Params_init(&taskParams);
taskParams.stackSize = 6*1024;
Task_create(Test_initTask, &taskParams, NULL);
/* Start BIOS */
BIOS_start();
return 0;
