IWR6843AOP: Code building: build fails when select variant IWR6843AOP
Part Number: IWR6843AOP
Other Parts Discussed in Thread: IWR6843,
I am trying to build the project "3D_people_count_68xx_mss".  When i select the variant as IWR6843, build goes through.
However when I change the variant to  IWR6843AOP, the linker fails with the below error: I have the  IWR6843AOP board. What should i select in the variant for building a new binary and for debugging.
Building target: "3D_people_count_68xx_mss.xer4f"
Invoking: Arm Linker
"/home/neha/ti/ti-cgt-arm_16.9.6.LTS/bin/armcl" -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --define=SOC_XWR68XX --define=SUBSYS_MSS --define=PLATFORMES2 --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=MMWAVE_L3_CODEMEM_SIZE=0x100 --define=MMWAVE_MSSUSED_L3RAM_SIZE=0x90000 --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --define=_LITTLE_ENDIAN --define=OBJDET_NO_RANGE --define=TRACKERPROC_EN --define=GTRACK_3D --define=APP_RESOURCE_FILE='<'/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/common/pcount3D_hwres.h'>' -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --enum_type=int --abi=eabi --obj_extension=.oer4f -z -m"3D_people_count_68xx_mss.map" --heap_size=0x800 --stack_size=0x800 -i"/home/neha/ti/ti-cgt-arm_16.9.6.LTS/lib" -i"/home/neha/workspace_v10/3D_people_count_68xx_mss" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/control/mmwave/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/control/mmwavelink/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/control/dpm/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/adcbuf/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/crc/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/dma/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/edma/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/esm/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/gpio/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/hwa/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/mailbox/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/osal/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/pinmux/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/soc/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/uart/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/utils/cli/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/utils/mathutils/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpu/rangeproc/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpedma/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/cbuff/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/utils/hsiheader/lib" -i"/home/neha/ti/mmwave_sdk_03_05_00_04/packages/ti/alg/gtrack/lib" -i"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/common/src/dpu/trackerproc_overhead/lib" -i"/home/neha/ti/ti-cgt-arm_16.9.6.LTS/include" --reread_libs --disable_auto_rts --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=MMWAVE_L3_CODEMEM_SIZE=0x100 --define=MMWAVE_MSSUSED_L3RAM_SIZE=0x90000 --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --warn_sections --xml_link_info="xwr68xx_mmw_demo_mss_linkInfo.xml" --rom_model --unused_section_elimination=on -o "3D_people_count_68xx_mss.xer4f" "./objdetrangehwa.oer4f" "./common/mmwdemo_adcconfig.oer4f" "./common/mmwdemo_rfparser.oer4f" "./mss/mss_main.oer4f" "./mss/pcount3D_cli.oer4f" "./mss/tracker_utils.oer4f" "../xwr6843_r4f.cmd" "/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/pcount3D_mss_linker.cmd" "/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd" -l"configPkg/linker.cmd" -llibosal_xwr68xx.aer4f -llibesm_xwr68xx.aer4f -llibgpio_xwr68xx.aer4f -llibsoc_xwr68xx.aer4f -llibpinmux_xwr68xx.aer4f -llibcrc_xwr68xx.aer4f -llibuart_xwr68xx.aer4f -llibmailbox_xwr68xx.aer4f -llibmmwavelink_xwr68xx.aer4f -llibmmwave_xwr68xx.aer4f -llibadcbuf_xwr68xx.aer4f -llibdma_xwr68xx.aer4f -llibedma_xwr68xx.aer4f -llibcli_xwr68xx.aer4f -llibhwa_xwr68xx.aer4f -llibdpm_xwr68xx.aer4f -llibmathutils.aer4f -llibcbuff_xwr68xx.aer4f -llibhsiheader_xwr68xx.aer4f -llibrangeproc_hwa_xwr68xx.aer4f -llibdpedma_hwa_xwr68xx.aer4f -llibgtrack3D.aer4f -llibtrackerproc_xwr68xx.aer4f -lrtsv7R4_T_le_v3D16_eabi.lib -llibc.a
<Linking>
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 20: error #10263: VECTORS memory range has already been specified
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 20: error #10264: VECTORS memory range overlaps existing memory range VECTORS
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 21: error #10263: PROG_RAM memory range has already been specified
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 21: error #10264: PROG_RAM memory range overlaps existing memory range PROG_RAM
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 22: error #10263: DATA_RAM memory range has already been specified
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 22: error #10264: DATA_RAM memory range overlaps existing memory range DATA_RAM
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 23: error #10263: L3_RAM memory range has already been specified
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 23: error #10264: L3_RAM memory range overlaps existing memory range L3_RAM
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 25: error #10263: HS_RAM memory range has already been specified
"/home/neha/ti/mmwave_industrial_toolbox_4_8_0/labs/people_counting/68xx_3D_people_counting/src/mss/r4f_linker.cmd", line 25: error #10264: HS_RAM memory range overlaps existing memory range HS_RAM
error #10010: errors encountered during linking; "3D_people_count_68xx_mss.xer4f" not built
