DRV5055: Spice model
Part Number: DRV5055
Hi
Is there a spice model available for the DRV5055 series of analog hall sensors.
Ian
  • Ian,
    Thank you for reaching out.  Presently we don't have any published models for DRV5055.
    Since there is not really a  In spice you could emulate this using a voltage controlled voltage source.  The goal would be to set the output at Vcc/2 with no input and then to have the output adjust per the datasheet spec for the particular sensitivity variation in use.  To best emulate the device you would also want to include noise and bandwidth in the simulation to mimic device functionality.
    Scott
