We use the LDC0851HDSGR in a stacked coil setup. The output however never goes low indicated that metal has been detected.
I used the webench tool to generate the coil and select a capacitor value. I've added the schematic, the pcb layout and the stackup.
The coil diameter is 7.75mm, the tracks have a width of 0.076mm and a clearance of 0.076mm. Any suggestions on how to fix this would be helpful.
