AWR6843ISK: SPI problem
Part Number: AWR6843ISK
I recently purchased AWR6843ISK and use it on DCA1000. In mmwave studio SPI does not connect even with older software version. Switch settings are as per instructions.
.Any help is appriciated.
  • Hello Mladen,
    Sorry for the delay due to holidays.
    Can you send the output log of mmWave Studio for us to understand and debug your issue better? What is the mmWave Studio version you're using? Is the connection of the two boards good from the hardware side?
    This issue has also been addressed on this E2E forum several times in the past, so in case you want to take a look at some previously resolved threads, please go ahead. Just type "Site e2e.ti.com Issues in SPI connect AWR"
    Here is our FAQ page as well: (+) [FAQ] FAQ : Hardware queries related to mmwave devices - Sensors forum - Sensors - TI E2E support forums (Please take a look at Q13).
    Ishita
  • Hello Ishita,
    Thank You for reply.
    Below is output from mmwave radar studio (ver 2.0.0.2) :
    GM: Constructor
    GM: Mon Nov 08 14:33:37 2021
    RSTD.Transmit("/Settings")
    [14:33:38]
    [14:33:38]  ### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
    [14:33:38]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
    [14:33:38]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
    [14:33:38]  Scripter ignored: Attempt to UnBuild() again or before Build.
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
    [14:33:38]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
    [14:33:38]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
    [14:33:38]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
    [14:33:38]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
    [14:33:38]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
    [14:33:38]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
    [14:33:38]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
    [14:33:38]  RSTD.Transmit("/")
    [14:33:38]  RSTD.SaveSettings(): Settings saved to "C:\Users\mlaki\AppData\Roaming\RSTD\config.xml"
    [14:33:38]  RSTD.Build()
    [14:33:38]  RSTD.AL_Build()
    [14:33:38]  RSTD.AL_LoadXml()
    [14:33:38]  RSTD.AL_Init()
    [14:33:38]  RSTD.Clients_Build()
    [14:33:38]  GM: Init
    [14:33:38]  GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
    [14:33:38]  GM: 1 Guest (s) init
    [14:33:38]  GM: 1 Module(s) init
    [14:33:38]  GM: 2 Tab   (s) init
    [14:33:38]  RSTD.Client_LoadXml()
    [14:33:39]  [RadarAPI]: Starting Matlab Engine..
    [14:34:04]  [RadarAPI]: Matlab Engine Started!
    [14:34:09]  [RadarAPI]: ar1.LoadSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [14:34:09]  [RadarAPI]: Error: Index was outside the bounds of the array.
    [14:34:09]  Trace:
    [14:34:09]     at AR1xController.ScriptOps.getMatlabPostProcVersion()
    [14:34:09]  TESTING = false
    [14:34:09]
    [14:34:09]  ***Script completed successfully.***
    [14:34:12]  [RadarAPI]: Opening Gpio Control Port()
    [14:34:12]  [RadarAPI]: Status: Passed
    [14:34:13]  [RadarAPI]: Opening Board Control Port()
    [14:34:13]  [RadarAPI]: Status: Passed
    [14:34:14]  [RadarAPI]: ar1.FullReset()
    [14:34:14]  [RadarAPI]: Status: Passed
    [14:34:14]  [RadarAPI]: Closing Board Control Port()
    [14:34:14]  [RadarAPI]: Closing Gpio Control Port()
    [14:34:14]  [RadarAPI]: ar1.SOPControl(2)
    [14:34:16]  [RadarAPI]: ar1.Connect(5,921600,1000)
    [14:34:18]  [RadarAPI]: Warning: Connected with baudrate 115200
    [14:34:19]  [RadarAPI]: Warning: Disconnected existing BaudRate
    [14:34:20]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
    [14:34:21]  [RadarAPI]: ar1.Calling_IsConnected()
    [14:34:22]  Device Status : UnDetDe/ASIL-B/SOP:2/ES:2
    [14:34:24]  Device Status : UnDetDe/ASIL-B/SOP:2/ES:2
    [14:34:24]  [RadarAPI]: ar1.SaveSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [14:34:25]  Invalid combination configuration..!!!!
    [14:34:26]  [RadarAPI]: ar1.frequencyBandSelection("77G")
    [14:34:28]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr68xx_radarss.bin")
    [14:34:28]  [RadarAPI]: Downloading BSS ROM RPRC Binary..
    [14:34:36]  [RadarAPI]: ar1.GetBSSFwVersion()
    [14:34:36]  [RadarAPI]: BSSFwVersion:(06.01.01.00 (08/04/19))
    [14:34:37]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr68xx_masterss.bin")
    [14:34:38]  [RadarAPI]: Downloading MSS RPRC Binary..
    [14:34:45]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
    [14:34:45]  [RadarAPI]: passed
    [14:34:46]  [RadarAPI]: ar1.Disconnect()
    [14:34:46]  [RadarAPI]: ar1.Calling_ATE_DisconnectTarget()
    [14:34:46]  [RadarAPI]: Debug Port Disconnected
    [14:34:46]  [RadarAPI]: ar1.PowerOn(1, 0, 1, 5)
    [14:34:46]  Status: Failed, Error Type: PROTOCOL ERROR
    [14:34:46]  [RadarAPI]: ar1.SaveSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [14:34:46]  [RadarAPI]: StatusDCCard Event Registered
    [14:34:46]  [RadarAPI]: Status: Passed
    [14:34:46]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
    [14:34:46]  [RadarAPI]: SYSTEM_CONNECT_CMD_CODE Async event recieved(9)
    [14:34:46]  [RadarAPI]: ConnectRFDCCard Status: Passed
    [14:34:46]  [RadarAPI]: CaptureCardConfig_EthInit API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [14:34:46]  [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
    [14:34:46]  [RadarAPI]: READ_FPGA_VERSION_CMD_CODE event recieved(14)
    [14:34:47]  [RadarAPI]: CaptureCardConfig_Mode API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [14:34:47]  [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
    [14:34:47]  [RadarAPI]: CaptureCardConfig_PacketDelay API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [14:34:47]  [RadarAPI]: CONFIG_FPGA_GEN_CMD_CODE Async event recieved(3)
    [14:34:47]  [RadarAPI]: CONFIG_PACKET_DATA_CMD_CODE Async event recieved(11)
    [14:35:13]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
    [14:35:13]  Status: Failed, Error Type: RESP TIMEOUT
    Connection of two boards is OK.
    FAQ Q13. What are some of the debug steps that can be followed if there are issues in SPI Connectivity?
    1. Users must ensure that they are using the correct firmware version for the device. .........see above?
    2. Use SOP5 (mount jumpers on pins SOP0 and SOP2 on the EVM for this mode) to erase the flash using uniflashtool and try again in mmwave studio. .......OK
    3. Please ensure the switch S2 is set to 'SPI' and not “CAN” on the EVM.-............OK
    On TI E2E could not found useful thread.
    Thank You in advance.
  • Hello Mladen,
    I see the device is not getting detected and that is why you're getting this error. One thing you can do is manually choose the Frequency band and the device type in mmWave Studio and then proceed ahead.
    You can also try to run one of the demo DCA1000 scripts present in C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts with the name : DataCaptureDemo_xWR.lua
    Also,
    Ishita
  • Hello Ishita,
    I try both without success.
    Output:
    GM: Constructor
    GM: Thu Nov 11 15:13:52 2021
    [15:13:53]
    [15:13:53]  ### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
    [15:13:53]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
    [15:13:53]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
    [15:13:53]  Scripter ignored: Attempt to UnBuild() again or before Build.
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
    [15:13:53]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
    [15:13:53]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
    [15:13:53]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
    [15:13:53]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
    [15:13:53]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
    [15:13:53]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
    [15:13:53]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
    [15:13:53]  RSTD.Transmit("/")
    [15:13:53]  RSTD.SaveSettings(): Settings saved to "C:\Users\mlaki\AppData\Roaming\RSTD\config.xml"
    [15:13:53]  RSTD.Build()
    [15:13:53]  RSTD.AL_Build()
    [15:13:53]  RSTD.AL_LoadXml()
    [15:13:53]  RSTD.AL_Init()
    [15:13:53]  RSTD.Clients_Build()
    [15:13:53]  GM: Init
    [15:13:53]  GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
    [15:13:53]  GM: 1 Guest (s) init
    [15:13:53]  GM: 1 Module(s) init
    [15:13:53]  GM: 2 Tab   (s) init
    [15:13:53]  RSTD.Client_LoadXml()
    [15:13:53]  [RadarAPI]: Starting Matlab Engine..
    [15:13:59]  [RadarAPI]: Matlab Engine Started!
    [15:14:02]  [RadarAPI]: ar1.LoadSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [15:14:02]  [RadarAPI]: Error: Index was outside the bounds of the array.
    [15:14:02]  Trace:
    [15:14:02]     at AR1xController.ScriptOps.getMatlabPostProcVersion()
    [15:14:03]  TESTING = false
    [15:14:03]
    [15:14:03]  ***Script completed successfully.***
    [15:14:14]  LuaLoad("C:/ti/mmwave_studio_02_01_01_00/mmWaveStudio/Scripts/DataCaptureDemo_xWR.lua")
    [15:14:16]
    [15:14:16]  &&&&&&&&&&&&&&&&&&&&
    [15:14:16]  ***Script FAILED!***
    [15:14:16]  Exception message is:
    [15:14:16]  [RadarAPI]: Error: ReadRegister: Object reference not set to an instance of an object.
    [15:14:16]  Trace:
    [15:14:16]     at AR1xController.SerialPortWrapper.SendAndRead(String command, String& response, Int32 timeout)
    [15:14:16]     at AR1xController.SerialPortWrapper.Read(UInt32 addr, UInt32& val)
    [15:14:16]     at AR1xController.SerialPortWrapper.Read(UInt32 addr, UInt32 start_bit, UInt32 end_bit)
    [15:14:16]     at AR1xController.AR1xxxWrapper.ReadRegister(Int32 type, UInt32 address, Int32 start_bit, Int32 end_bit, UInt32& value)
    Attempt for normal setup with device and freq set failed as well:
    GM: Constructor
    [15:13:53]
    [15:13:53]  GM: Init
    [15:14:02]  Trace:
    [15:14:03]
    [15:14:16]
    [15:14:16]  Trace:
    [15:15:51]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
    [15:15:51]  [RadarAPI]: passed
    [15:15:53]  [RadarAPI]: StatusDCCard Event Registered
    [15:15:53]  [RadarAPI]: Status: Passed
    [15:15:53]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
    [15:15:53]  [RadarAPI]: SYSTEM_CONNECT_CMD_CODE Async event recieved(9)
    [15:15:53]  [RadarAPI]: ConnectRFDCCard Status: Passed
    [15:15:53]  [RadarAPI]: CaptureCardConfig_EthInit API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [15:15:53]  [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 0, 1, 2, 3, 30)
    [15:15:53]  [RadarAPI]: READ_FPGA_VERSION_CMD_CODE event recieved(14)
    [15:15:53]  [RadarAPI]: CaptureCardConfig_Mode API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [15:15:53]  [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
    [15:15:53]  [RadarAPI]: CaptureCardConfig_PacketDelay API Status: Failed, Error Type: RRFDCCARD_SUCCESS
    [15:15:53]  [RadarAPI]: CONFIG_FPGA_GEN_CMD_CODE Async event recieved(3)
    [15:15:53]  [RadarAPI]: CONFIG_PACKET_DATA_CMD_CODE Async event recieved(11)
    [15:15:59]  [RadarAPI]: ar1.frequencyBandSelection("60G")
    [15:16:00]  [RadarAPI]: RS232 is not connected ..!!!!
    [15:16:02]  [RadarAPI]: Opening Gpio Control Port()
    [15:16:02]  [RadarAPI]: Status: Passed
    [15:16:03]  [RadarAPI]: Opening Board Control Port()
    [15:16:03]  [RadarAPI]: Status: Passed
    [15:16:04]  [RadarAPI]: ar1.FullReset()
    [15:16:04]  [RadarAPI]: Status: Passed
    [15:16:04]  [RadarAPI]: Closing Board Control Port()
    [15:16:04]  [RadarAPI]: Closing Gpio Control Port()
    [15:16:04]  [RadarAPI]: ar1.SOPControl(2)
    [15:16:05]  [RadarAPI]: ar1.Connect(5,921600,1000)
    [15:16:08]  [RadarAPI]: Warning: Connected with baudrate 115200
    [15:16:09]  [RadarAPI]: Warning: Disconnected existing BaudRate
    [15:16:09]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
    [15:16:11]  [RadarAPI]: ar1.Calling_IsConnected()
    [15:16:12]  Device Status : UnDetDe/ASIL-B/SOP:2/ES:2
    [15:16:13]  Device Status : UnDetDe/ASIL-B/SOP:2/ES:2
    [15:16:14]  [RadarAPI]: ar1.SaveSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [15:16:15]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr12xx_xwr14xx_radarss.bin")
    [15:16:15]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
    [15:16:17]  [RadarAPI]: ar1.GetBSSFwVersion()
    [15:16:17]  [RadarAPI]: BSSFwVersion:(06.01.01.00 (08/04/19))
    [15:16:18]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [15:16:18]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
    [15:16:19]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr12xx_xwr14xx_masterss.bin")
    [15:16:19]  [RadarAPI]: Downloading MSS RPRC Binary..
    [15:16:45]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
    [15:16:45]  Status: Failed, Error Type: RESP TIMEOUT
    [15:16:48]  [RadarAPI]: ar1.RfEnable()
    [15:16:48]  Status: Failed, Error Type: INVALID INPUT
    [15:16:49]  [RadarAPI]: ar1.GetBSSFwVersion()
    [15:16:49]  [RadarAPI]: BSSFwVersion:(06.01.01.00 (08/04/19))
    [15:16:50]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
    [15:16:50]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
    [15:17:04]  [RadarAPI]: ar1.Disconnect()
    [15:17:04]  [RadarAPI]: ar1.Calling_ATE_DisconnectTarget()
    [15:17:05]  [RadarAPI]: Debug Port Disconnected!
    [15:17:05]  [RadarAPI]: ar1.PowerOn(1, 0, 1, 5)
    [15:17:05]  Status: Failed, Error Type: PROTOCOL ERROR
    [15:17:05]  [RadarAPI]: ar1.SaveSettings('C:\Users\mlaki\AppData\Roaming\RSTD\ar1gui.ini')
    [15:17:05]  [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
    [15:17:05]  Status: Failed, Error Type: INVALID INPUT
    [15:17:05]  [RadarAPI]: ar1.LPModConfig(0, 0)
    [15:17:06]  [RadarAPI]: Status: Failed, Error Type: INVALID INPUT
    [15:17:06]  [RadarAPI]: Error Occurred in Port open close
    [15:17:07]  [RadarAPI]: ar1.RfInit()
    [15:17:07]  [RadarAPI]: Status: Failed, Error Type: INVALID INPUT
    [15:17:11]  [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
    [15:17:11]  Status: Failed, Error Type: INVALID INPUT
    [15:17:15]  [RadarAPI]: ar1.LvdsClkConfig(1, 1)
    [15:17:15]  Status: Failed, Error Type: INVALID INPUT
    [15:17:16]  [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 1, 1, 1, 0, 0)
    [15:17:16]  Status: Failed, Error Type: INVALID INPUT
    [15:17:21]  [RadarAPI]: ar1.ProfileConfig(0, 60,25, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29,982, 0, 256, 10000, 0, 131072, 30)
    [15:17:21]  Status: Failed, Error Type: INVALID INPUT
    [15:17:21]  [RadarAPI]: Error Occurred in Port open close
    [15:17:22]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
    [15:17:22]  Status: Failed, Error Type: INVALID INPUT
    [15:17:25]  Test Source Already Disabled...!!!
    [15:17:25]  Status: Failed, Error Type: SUCCESS
    [15:17:25]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
    [15:17:25]  Status: Failed, Error Type: INVALID INPUT
    [15:17:25]  [RadarAPI]: MatlabProc Status: Failed
    [15:17:31]  [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
    [15:17:31]  [RadarAPI]: Status: Passed
    [15:17:31]  [RadarAPI]: RECORD_START_CMD_CODE Async event recieved(5)
    [15:17:33]  [RadarAPI]: ar1.StartFrame()
    [15:17:33]  Status: Failed, Error Type: INVALID INPUT
    [15:17:38]  [RadarAPI]: Packet Reorder Utility Started...please wait...
    [15:17:38]  [RadarAPI]: ar1.PacketReorderZeroFill("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data_Raw_0.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\pktlogfile.txt")
    [15:17:43]  [RadarAPI]: Packet Reorder Utility process completed!
    [15:17:46]  [RadarAPI]: Packet Reorder Utility Started...please wait...
    [15:17:46]  [RadarAPI]: ar1.PacketReorderZeroFill("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data_Raw_0.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\pktlogfile.txt")
    [15:17:51]  [RadarAPI]: Packet Reorder Utility process completed!
    [15:17:54]  [RadarAPI]: Packet Reorder Utility Started...please wait...
    [15:17:54]  [RadarAPI]: ar1.PacketReorderZeroFill("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data_Raw_0.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\pktlogfile.txt")
    [15:17:58]  [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin")
    [15:17:59]  [RadarAPI]: Packet Reorder Utility process completed!
    [15:18:01]  [RadarAPI]: STS_NO_LVDS_DATA Async event recieved(0)
    [15:18:06]  [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin")
    [15:18:14]  [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin")
    [15:18:29]  [RadarAPI]: ar1.ProfileConfig(0, 60,25, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29,982, 0, 256, 10000, 0, 131072, 30)
    [15:18:29]  Status: Failed, Error Type: INVALID INPUT
    [15:18:29]  [RadarAPI]: Error Occurred in Port open close
    [15:18:30]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
    [15:18:30]  Status: Failed, Error Type: INVALID INPUT
    [15:18:35]  Test Source Already Disabled...!!!
    [15:18:35]  Status: Failed, Error Type: SUCCESS
    [15:18:35]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
    [15:18:35]  Status: Failed, Error Type: INVALID INPUT
    [15:18:35]  [RadarAPI]: MatlabProc Status: Failed
    [15:18:38]  [RadarAPI]: ar1.StartFrame()
    [15:18:38]  Status: Failed, Error Type: INVALID INPUT
    [15:18:43]  [RadarAPI]: Packet Reorder Utility Started...please wait...
    [15:18:43]  [RadarAPI]: ar1.PacketReorderZeroFill("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data_Raw_0.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin", "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\pktlogfile.txt")
    [15:18:49]  [RadarAPI]: Packet Reorder Utility process completed!
    [15:19:04]  [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\PostProc\\adc_data.bin")
    Thank You
  • Hello Mladen,
    I see you're using mmWave Studio_02_00_00_02 for all your experiments. The latest version is mmwave_studio_02_01_01_00 and I see you're using the lua scripts from this version.
    Please only use the latest studio version and the corresponding scripts that come with it.
    Also, to use the "DataCaptureDemo_xWR.lua" script, you will have to modify the script a little to make it applicable to your device. From the log, I can see you're downloading the wrong firmware to the device, i.e. for XWR1243 or XWR1443. The script and the device wont work if a wrong firmware is flashed.
    Please also check your ethernet connection. I see you're getting a few errors on connection with the DCA1000 board in your log.
    It would be be good if you could send a picture of your hardware setup. The errors you're getting are corresponding to either an old/wrong version of the FW being used, or incorrect switch/SOP mode settings in hardware. I would recommend you to cross verify them once again according to the user guides.
    Ishita
  • Hello Ishita,
    Sorry for late repply.
    Flashing device with firmare 3.5 version (old 3.4) (from mmwave_industrial_toolbox_4_9_0)  resolved issue. I am able to use both mmwave studio and mmwave_demo_visualiser.
    Thank You on accurate support.
    BR
