DCA1000EVM: Protocol Error
Part Number: DCA1000EVM
Other Parts Discussed in Thread: 4428
Hi E2E,
Our customer is using DCA1000EVM for capturing raw data for finding radar cross-sections of objects and using mmWave studio for capturing raw data.
Attached below are the settings of "connection" tab , "StaticConfig" tab, the board and "log.txt" which contains the "output". When they press the RF Init button, on the StaticConfig page, Protocol Error appears in the output. In the text file uploaded, this error is visible in the last line, [12:49:47]
GM: Constructor
GM: Tue Nov 09 12:47:34 2021
RSTD.Transmit("/Settings")
[12:47:34]
[12:47:34]  ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[12:47:34]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[12:47:34]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[12:47:34]  Scripter ignored: Attempt to UnBuild() again or before Build.
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[12:47:34]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[12:47:34]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[12:47:34]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[12:47:34]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[12:47:34]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[12:47:34]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[12:47:34]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[12:47:34]  RSTD.Transmit("/")
[12:47:34]  RSTD.SaveSettings(): Settings saved to "C:\Users\Admin\AppData\Roaming\RSTD\config.xml"
[12:47:34]  RSTD.Build()
[12:47:34]  RSTD.AL_Build()
[12:47:34]  RSTD.AL_LoadXml()
[12:47:34]  RSTD.AL_Init()
[12:47:34]  RSTD.Clients_Build()
[12:47:34]  GM: Init
[12:47:34]  GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[12:47:34]  GM: 1 Guest (s) init
[12:47:34]  GM: 1 Module(s) init
[12:47:34]  GM: 2 Tab   (s) init
[12:47:34]  RSTD.Client_LoadXml()
[12:47:34]  [RadarAPI]: ar1.selectRadarMode(0)
[12:47:34]  [RadarAPI]: Status: Passed
[12:47:34]  Matlab Runtime Engine is installed
[12:47:34]  [RadarAPI]: Starting Matlab Engine..
[12:47:38]  [RadarAPI]: Matlab Engine Started!
[12:47:40]  [RadarAPI]: ar1.selectCascadeMode(0)
[12:47:40]  [RadarAPI]: Status: Passed
[12:47:40]  [RadarAPI]: ar1.LoadSettings('C:\Users\Admin\AppData\Roaming\RSTD\ar1gui.ini')
[12:47:40]  [RadarAPI]: Error: Dizin, dizi sınırlarının dışındaydı.
[12:47:40]  Trace:
[12:47:40]     konum: AR1xController.ScriptOps.getMatlabPostProcVersion()
[12:47:40]  TESTING = false
[12:47:40]  RstdNet: Port 2777: Listening..
[12:47:40]
[12:47:40]  ***Script completed successfully.***
[12:47:54]  [RadarAPI]: ar1.frequencyBandSelection("77G")
[12:47:55]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[12:47:55]  [RadarAPI]: Status: Passed
[12:47:55]  [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[12:47:57]  [RadarAPI]: Opening Gpio Control Port()
[12:47:57]  [RadarAPI]: Status: Passed
[12:47:57]  [RadarAPI]: Opening Board Control Port()
[12:47:59]  [RadarAPI]: ar1.FullReset()
[12:47:59]  [RadarAPI]: Status: Passed
[12:47:59]  [RadarAPI]: Closing Board Control Port()
[12:47:59]  [RadarAPI]: Closing Gpio Control Port()
[12:47:59]  [RadarAPI]: ar1.SOPControl(2)
[12:48:02]  [RadarAPI]: ar1.Connect(7,921600,1000)
[12:48:05]  [RadarAPI]: Warning: Connected with baudrate 115200
[12:48:06]  [RadarAPI]: Warning: Disconnected existing BaudRate
[12:48:06]  [RadarAPI]: Warning: Trying to connect with baudrate 921600
[12:48:08]  [RadarAPI]: ar1.Calling_IsConnected()
[12:48:09]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[12:48:09]  [RadarAPI]: Status: Passed
[12:48:09]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[12:48:09]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[12:48:09]  [RadarAPI]: ar1.SaveSettings('C:\Users\Admin\AppData\Roaming\RSTD\ar1gui.ini')
[12:48:13]  [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[12:48:14]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
[12:48:15]  [RadarAPI]: ar1.GetBSSFwVersion()
[12:48:15]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[12:48:16]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[12:48:16]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[12:48:22]  [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[12:48:22]  [RadarAPI]: Downloading MSS RPRC Binary..
[12:48:25]  [RadarAPI]: ar1.GetMSSFwVersion()
[12:48:25]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[12:48:26]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[12:48:26]  [RadarAPI]: Status: Passed
[12:48:26]  MSS power up done async event received!
[12:48:28]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[12:48:28]  [RadarAPI]: Status: Passed
[12:48:28]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[12:48:29]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[12:48:29]  [RadarAPI]: ar1.RfEnable()
[12:48:29]  BSS power up done async event received!
[12:48:29]  [RadarAPI]: Status: Passed
[12:48:29]  [RadarAPI]: ar1.GetMSSFwVersion()
[12:48:29]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[12:48:30]  [RadarAPI]: ar1.GetBSSFwVersion()
[12:48:30]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[12:48:30]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[12:48:30]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[12:49:41]  [RadarAPI]: ar1.ChanNAdcConfig(1, 0, 0, 1, 0, 0, 0, 2, 2, 0)
[12:49:41]  [RadarAPI]: Status: Passed
[12:49:43]  [RadarAPI]: ar1.LPModConfig(0, 1)
[12:49:43]  [RadarAPI]: Status: Passed
[12:49:47]  [RadarAPI]: ar1.RfInit()
[12:49:47]  [RadarAPI]: Status: Failed, Error Type: PROTOCOL ERROR
Your assistance is appreciated.
Carlo
