Other Parts Discussed in Thread: PGA460
Hi
We are working on an ultrasonic project, we are experimenting with an ultrasonic transducer as shown in the attached datasheet. The datasheet shows the following schematic. Is there an alternative option available from TI for achieving the same circuit using one of your AFE devices? And if so what advantage of using an IC compared to the schematic. I have also seen that there could be a transformerless options?
We intend to use a microcontroller, with UART. Is it as simple as TX a message and then waiting for the delayed message to determine the sensing result? Or do we also need to observe the analogue signal?
Please recommend what parts I should consider?
Thank You
DJ
