we ordered the TI-HDC3020EVM and I try to use it as data logger for humidity and temperature inside an Inverter. I break the Sensor from board and connect them with 5 meter cables and used the online and offline software for data logging.
After some time the device disconnect without any reason it seems. Sometimes it works for 20 minutes sometimes for 1 minute and it seems the time to disconnect is reducing.
When I remove the Board from USB and connect again to the PC then it works again for some time.
Is there any possibility to check what is the problem?
Thanks in advance!
