FDC2214EVM: Using 2 channels in differential sensor configuration
Part Number: FDC2214EVM
Other Parts Discussed in Thread: FDC2214
Is it possible to use FDC2214 in two channels in differential sensor in this configuration?
- Using 3 ‘plates’.
- CH0 and CH1 will be sharing one large plate.
Observation: When IN0A and IN1A connected to the same plate, the capacitance value is very strange and changes drastically. Am I unable to have a shared plate?
  • Eddie,
    Unfortunately the devices' internal connections don't support shared sensors using the differential mode connections described in section 10.1.1 of the data sheet.
    Does your application allow successive single-ended measurements, with capacitances calculated in post-processing?
    John
