Other Parts Discussed in Thread: UNIFLASH,
today I use uniflash download sW to PGA900 through XDS200 , I finished 28 PCS , but started the 29th , i t failed, the uniflash interface showed below words:
File Loader: Verification failed: Values at address 0x00000003 do not match Please verify target memory and memory map
so I checked the memory , the memory is also blank.
I changed another IC, but unfortunately , this situation appeared 5 times.
I changed another XDS200, NO USE.
And that time I found my notebook was low battery, I doubted may it can effect it...so connected the power adapte,, no use..
Then I checked all the connecting wires , still no use.
but about 30 minutes later, the error situation was disappeared . I can downloaded the sw normally.
I don't know if this error situation will appear again.so , I want to know which can cause this situation,
I eagerly hope someone can help me
many thanks and best regards
