IWR6843AOPEVM: Link to Multi-Peak High Accuracy Visualizer in RegEx is broken
Part Number: IWR6843AOPEVM
Other Parts Discussed in Thread: IWR6843AOP
Champs,
the user guide of the level sensing lab in Resource Explorer (https://dev.ti.com/tirex/explore/node?node=AHtHIYgt605Dcx0M.fb.cA__VLyFKFf__LATEST&search=IWR6843AOP) tells "
  • If using either the 14xx or 68xx versions of the lab then connect to the Multi-Peak High Accuracy Visualizer.
unfortunately, the link is broken. The High Resolution Visualizer 1.0.1 is found on dev.ti.com, however the UG explicitly says "The High Accuracy Visualizer has been updated as of Industrial Toolbox 4.7.0. Please use the latest visualizer as linked below." I was not able to find out whether the 1.0.1 is the latest UG calls out or not.
Will appreciate your clarifications.
Michael
