Part Number: OPT3004EVM
Hi sir
DUT will be placed on the holder and ALS PCB will be installed below the holder.
When I adjust ALS PCB to LED distance from 9mm to 35m with different LED driving current, the LUX value should be showing linear curve.
however, the 9mm curve LUX value was smaller than 15mm and 15mm curve had saturation(The ALS was set fix Range= 2620.8 lux).
do you have any suggestion?
