In app note "Power Management Optimizations – Low Cost LC Filter Solution" (swra577a.pdf), customer found there is information about XWR1xxx Noise Spectral Density.
Would you pls help on below questions?
1. Is there any relationship between Supply Ripple and Noise Spectral Density?
2. There is info of spectral noise density for LDO. If customer plan to use other LDO (not the one on EVM) , should the LDO noise density be less than the number in XWR1xxx Noise Spectral Density table in this app note? Why Noise Spectral Density info is not in the AWR1843 datasheet?
Chris
